Question about Intel D875PBZ Motherboard
Intel D875PBZ MB - RAM limit with AGP Video Card Installed
I read in the Intel MB specs that I had to remove the AGP video card when I installed the 4ea 1gb GSkill DDR Dual Channel Memory Modules to get past a 2.5gb RAM limit. (Something about memory retention) I interpreted that to mean that once the RAM was in that I could reinstall the AGP video card. Not so....The BIOS recognizes the 4gb but Windows XP Pro does not with the card installed. Any words of wisdom?
Thanks
Steve
  • 781 Answers
Sorry as far as I know and experienced all 32 bit XP and Vista will only recognize up to 3,4 GB of ram and no more. whether its dual channel or not.
You will have to go to a 64 bit O/S to use it.
Even then there are limits some 64 bit O/S will only use 4 GB others more
Posted on Dec 30, 2008
Hi, I need standard spec info of VGA built on Asus P5GC-MX 1333 whether 64 Mb or 128 Mb. Many thanks & regards, Richard
you can use up to a maximum of 224 mb of your computer's RAM for the onboard video chip to use. You can install a video card with any amount of memory (which would give you a lot better video performance).
Jun 18, 2011 | ASUS P5GC-MX 1333 BULK C2D LGA775 945GC...
I just got a Intel D875PBZ Motherboard from ebay, im told its suposta work fine, i hook the entire thing up to my system, and it boots, all the fans start, my hard drive starts, i can open/close my disk...
You could try reseting it. unhook the cmos battery and put it back. also make sure that MB sits well in the casing without any shorting (grounding that is not supposed to).
Regards
Aug 13, 2010 | Intel D875PBZ Motherboard
Soyo sy-p4vgm motherboard agp slot video card highest MB capacity
Soyo has left the motherboard business. I find only specifications for AGP 4x port. I expect the board will support 512megs video RAM on an AGP card as AGP memory is a card limit.
See for more detail:
http://en.wikipedia.org/wiki/Accelerated_Graphics_Port
Your major worry is the 3.3v and 1.5 volt support.
Mar 21, 2010 | Soyo SY-P4VGM Motherboard
My motherboard is IntelD845PESV. i use 512 mb DDR 1 RAm & 64 mb Nvidia Geforce 2 Mx/Mx 400 AGP card. Now, i want to upgrate the AGP and RAM . In the intel site maximum RAM supported by this...
Look in the BIOS, under the video ram settings. What is the largest RAM it can handle? 128? 256? 512? This will give you an indication as the size of video RAM that you can have on your card.
Hope this helps.
Nov 09, 2009 | Intel D845PESV Motherboard
After ive installed assassin creed it comes up u need bla bla bla so then it says renewing up dates and is now 100% fixed its in folder and on icon yet when i try to plsy it comes on in about 2 flashes and...
Here are the requirements for the game. What graphics card are you trying to use? If your PC doesn't meet the specs, you may have to consider upgrading the RAM and graphics card.
MINIMUM REQUIREMENTS
Assassin's Creed
Processor: Dual core processor 2.6 GHz Intel Pentium D or AMD Athlon 64 X2 3800+
RAM: 2 GB
Video Card: 256 MB DirectX 10.0-compliant video card or DirectX 9.0-compliant card with Shader Model 3.0 or higher
Sound Card: DirectX 9.0 or 10.0 compliant sound card
HDD Space: 12GB
DirectX Version: DirectX 10.0
RECOMMENDED REQUIREMENTS
Assassin's Creed
Processor: Intel Core 2 Duo 2.2 GHz or AMD Athlon 64 X2 4400+ or better
RAM: 3GB
Video Card: 512 MB Card
Sound Card: 5.1 Sound Card
HDD Space: 12GB
Jul 11, 2009 | Computers & Internet
Graphic card problem..?
More ram is always better, in all computers and video cards.
Jun 11, 2009 | IBM ThinkCentre M50 Refurbished Intel...
Need Help !! D865GBF / D865PERC Intel Motherboard No Pictures
While the system may be emitting a memory error beep code, that obviously is not the only issue here. If there is onboard video and it isn't working, try this:
1: Unplug system
2: Open case
3: Look for the CR2032 flat watch-style battery located on the motherboard, usually around where the front panel connections are
4: Remove this battery using a flathead screwdriver to push on the tiny 'hook' of metal holding it in. DO NOT PRY THE BATTERY OUT.
5: Let system sit for 10 seconds and put the battery back in.
6: Power the system back up
What this does is drain the system's memory completely. If it was perhaps set to use the AGP video card (which isn't installed, hence no video), this setting should be cleared and you should get onboard video.
Failing this, really, your only choice is a new motherboard, or to install an AGP card and see if it works. If you don't feel like hunting down a replacement board, I'd just order a cheap AGP card. If the AGP card works, use it. If not, then your motherboard is really pooched and you'll need a new one anyways.
About the memory beep issue:
You can google memtest86 and download that program. Burn it to a bootable CD and run the memory test; it should tell you if the memory is good or not.
hope that helps!
Jan 05, 2009 | E-Machines eMachines Desktop PC
Compatible graphics card for intel d875pbz motherboardboard
Actually the ATI 8500 agp gard should run just fine on that board use to have the same board and I set it up with this card and it ran great
Jan 03, 2009 | Computers & Internet
My hardware upgrade
all your using is outdated only you can use is your 40gb hdd for a new mainboard. your can go with intel core2duo cpu with ddr2 800fsb 2gb ram.
Mar 18, 2008 | Computers & Internet
Intel D875PBZ Motherboard Logo
288 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
