Question about Phase Linear UMP8015 CD Player/Receiver With Detachable Face
Ribbon cable... The face somehow detached from the player and hung loosely before the cable connecting the front panel to the player completely ripped. Can I get a replacement (or repair)?
It would be cheaper to replace the unit. Be more careful next time with your equipment
Posted on Dec 27, 2007
Ge 11-2120 cd stuck behind cd changer
GE 11-2120 CD Stuck. Unplug from power supply, detach speaker wires, detach antennae wires. eject any cassette tapes, remove any CD's you can reach. Then, hold the unit upside down, front panel facing you. agitate to let the CD fall down. With care, roll unit so that front faces downward briefly, then back to the upside down position, facing you. With care, roll it clockwise so that the top is upward, all the while keeping the front panel facing you. Now agitate lightly again, to seat the loose CD in one of the five openings in the revolving tray. set the unit on a table, plug it in to an outlet, open the CD mechanism, hit "skip" on the remote control until CD is visible. remove it.
Mar 07, 2014 | Bosch Audi A4 1.8l Engine Motor Turbo 02...
This color strip is intermittent. It's a 50' Samsung led tv
it looks like the ribbon that is bonded to the panel is damaged. there are a couple of possibilities with that. its either burned or has become partially detached from its seating which can be countered by pressing on it. this happens over time due to warmth of the panel heating the tiny solder pins on the ribbon (this does require taking the tv apart, including the panel). if its burned, there is nothing you can do
Oct 26, 2012 | Televison & Video
How do you replace a laptop screen l555d serial number...its a toshiba.
1. Turn off the computer and remove the battery.
2. Loosen the plastic frame bordering the Toshiba Satellite L555D-S7005 Screen. This frame is attached to the notebook's back shell and holds the screen in place. Pry open two to six small rubber seals from the frame and undo concealed screws.
3. Detach the frame after removing all screws. Hold the bezel from either side of the screen and gently pull it away from the screen and toward you. If the bezel seems to be stuck, find any points of attachment, such as clips or hooks, and undo to detach it from the outer shell. Work with your fingers and go all around the frame to release and completely detach it.
4. Free the LCD panel from its position in the notebook's lid. When you remove the bezel, you will notice that the screen is held in place, enclosed in hinges. Undo screws from either side of the screen to release its attachment to the lid. Place a finger at the top center of the screen to keep it from falling down as you remove the screws. With all screws undone, tilt the panel and lower it face down onto the keyboard.
5. Disconnect the power cable and video cable from the screen. The power cable connects the screen's power source of the lcd inverter to the backlight lamp attached to a side of the panel. Unplug cables from either end of the inverter board and unscrew the board from the base of the screen. Next, find and unplug the video cable a broad, ribbon like arrangement taped to the back of the panel. Pull at the plastic head of the cable to detach it.
6. Remove the screen. With the screen's cables unplugged and inverter board removed, it is completely detached from the notebook's display assembly and may be safely removed. Pick up the panel from the keyboard and keep it to a side.
7. Orient the replacement screen by bringing it to the work area and aligning it to the laptop's shell. Gently rest the screen on the keyboard and attach the power cable and the video cable. Raise the screen and attach the inverter board to its base. Plug in the inverter board's cable to the screen's backlight lamp. Screw the screen in place and reorganize the display assembly.
May 04, 2011 | Toshiba Computers & Internet
A/c
there is a top wire that connects to the compressor in the front engine compartment 2 prong see if this is detached if wire is not detached i would check the switches to see if the electrical under dash below sterio has somehow came undone or jarred loose
check the fuses and or relays
last the compressor could be faulty or failed
May 26, 2008 | 2002 Ford Ranger Regular Cab
Loose front AUX
The wires on the plug. Red, goes to the R terminal. Black goes to the one marked G. And the White goes to L.
Red - R
Black- G
White-L
Mar 21, 2008 | Sony CDX-GT100 CD Player
Lost detachable face panel
To reduce theft, most car stereos with detachable faceplates are keyed together -- that is, they are not interchangeable. It is unlikely that you will be able to find a replacement faceplate, unfortunately.
Feb 25, 2007 | Akai CSV2001 CD Player
Phase Linear UMP8015 CD Player/Receiver With Detachable Face Logo
Top Phase Linear Car Audio & Video Experts
Damen Wong
Damen Wong
Jaime Hernandez
Alli Abiola
Alli Abiola
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
