Sanyo Xacti VPC-HD1000 Flash Media Camcorder
Problem for Sanyo Xacti VPC-HD1000 Flash Media Camcorder
Can' get started
By jollyvogt7 on Dec 30, 2008
The directions seem simple, but when I press the record button, the camera appears to be recording for about 22 seconds and then I get a revolving hour glass symbol that isn't described anywhere in the manual. The camera then begins turning the record button on and off by itself and the hourglass comes and goes. I am not able to turn the camera off whether the hourglass is on the screen or not. This is my second camera. The same problem began with the first camera when I tried to format the 4G SDHC memory card. As soon as I pressed "yes" to format the camera left the set up mode by itself and then when I recorded the problem ocurred as described above. I tried a second new memory card with the same results. I am using the same card as I used in the first camera. The first time I turned this camera on it said the card was full. I followed the simple instructions for deleting files and it told me there were no files to delete. So I started recording with the results above. Why won't it work? Linda Lee
Solution #1
posted on Jan 07, 2009
Not Rated)
BHD Man
Rank: Apprentice
Rating: 0%, 0 votes
The hour glass symbol means you have ended a video and the camera is saving it. If it does it on it's own, it might mean you have jammed the recording button. Try tapping it a little or pulling it out a little to get it back to normal. If that doesn't work, your camera may be malfuntioning. If you can't get it to get unjammed, get a friend or family member to help you. Take an easy on it or the camera will break and you can ever use the recording button again.
Was this helpful?
Yes
No
Popular Solutions for Sanyo Xacti VPC-HD1000 Flash
Questions and Unsolved Problems for Sanyo Xacti VPC-HD1000 Flash
Do you recommend Sanyo Xacti VPC-HD1000 Flash Media Camcorder?
Answer
Answer
sanyo xacti won't turn on. started just happening sometimes now it won't turn on at all.
Answer
I have the identical issue: I accidently used the wrong charge chord to plug in my camera dock. I... (More)
Answer
battery pack is low after 02 minutes.I have 02 battery packs with the same problem.I Just buyed a... (More)
Answer
I have 2 spare batteries with my sanyo hd1000. Now they are all empty whithin a very very... (More)
Answer
I have 4 spare batteries with my sanyo hd1010. Now they are all empty whithin a very very short... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sanyo Xacti VPC-HD1000 Flash...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 761
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
