Question about Apple iPod nano
Ipod nano 8gb 4th gen does not turn on
I have tried locking and unlocking the device. it worked for a couple days, I turned it off, and when I went to use it again it won't turn on, I have tried charging it.
  • 903 Answers
Look on this link for troubleshooting
http://www.apple.com/support/ipod/five_rs/nano4gen/
Posted on Dec 30, 2008
Why does my iPod keeps turning itself on when I lock it?
iPods have no traditional on/ff switch. They power up with the slightest touch, which makes turning the iPod on as simple as touching the menu. Turning the iPod off, however, can be more tricky. Waiting for automatic shut off wastes battery life, and surfing the menus yields no way to stop the device from running. Turning off the iPod Nano, though, is almost as simple as turning it on.
Locate the "hold" or "lock" switch at the top of your iPod Nano. It will be located on the top of your device on the left side. Make sure the device is unlocked. When the device is locked, an orange bar is visible. When it is unlocked, that bar is not visible. The iPod needs to be unlocked in order to power off. Locate the "play/pause" buttons. These are located at the bottom of the control wheel. Press at the "play/pause" section of the wheel and hold for a few seconds. Your iPod will power off. Do not touch the wheel again after powering off, as this will power the device back on. Locate the "hold" or "lock" switch again. Slide the bar to the locked position so that the orange bar is visible. This will prevent your iPod from powering on in your purse or pocket and wasting battery time.
Feb 08, 2013 | Apple MB735LL/A 8GB 4th Gen iPod nano -...
I forgot the passcode to unlock my IPOD NANO 8GB Purple
Good day,
I came across a few situations where someone has forgotten their iPod's passcode and now can't use it.
I will give some instructions on how to possibly repair this problem.
The first thing you can try is to connect your Ipod to it's HOME Computer. This will normally override the lock. Only thing is that you need the lock code to be able to assign a new code.
Another method I came across is to connect your Ipod to a computer. Make sure you are able to see all hidden folders. Browse to your Ipod on My Computer and double click on your Ipod folder/location. Open the folder named "iPod_Control" inside the folder open the folder "Device". Inside the device folder rename the file "_locked" to "_unlocked".
These two methods has worked for me in the past, so please feel free to let me know if this help you!
Regards
Jan 04, 2011 | Apple iPod Nano Video 8GB Purple (5th Gen)...
Ipod nano 4th gen. 8gb SCREEN LOCKED
restore iPod
  1. Verify that you have an active Internet connection, because you may need to download new versions of the iTunes and iPod Software.
  2. Download and install the latest version of iTunes if necessary.
  3. Open iTunes. Connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel. You will see information about your iPod appear in the Summary tab of the main iTunes window.
  6. Click Restore.
  7. If you are using a Mac, you will be asked to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen, indicating that stage one of the restore process has begun. When this stage is done, iTunes will present one of two messages with instructions specific to the iPod model you are restoring.
    • Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During stage two of the restore process, the iPod displays an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remain connected to the computer or iPod power adapter during this stage.
    Note: The progress bar may be difficult to see, because the backlight on the iPod display may be off.
  10. After stage two of the restore process is complete, the iTunes Setup Assistant window will appear. It will ask you to name your iPod and choose your syncing preferences, as it did when you connected your iPod for the first time.
but unfotunately all your previously synced congs will be lost,,, but its ok then, because you can use your ipod again.
Jun 05, 2010 | Apple iPod nano 4th Generation
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
Jan 29, 2010 | JVC KW-AVX810 Car DVD Player
New Ipod Nano 4th Gen 16GB has went blank and will not turn on
HI there,
worst case scenario is that a circuit has broken inside. But your ipod will be under warrenty for a year from purchase.
Otherwise, leave the ipod to charge for a long time. Just leave it connected directly to the computer USB port despite not having any change in appearance. Also, don't connect it via a usb hub or through your keyboard. You will need to plug it into your computer directly.
You can also try entering DFU mode. Here is a great step by step guide to do that. http://iphonefreakz.com/beginners-guide/howto-dfu-mode/
Then restore the ipod and update the firmware. Make sure you have the latest version of itunes installed. By checking through software update.
I hope this helps,
Nathan.
Apr 14, 2009 | Apple iPod nano 4th Generation
Hi. I plugged in my iPod nano 4th generation to charge it. It opened iTunes as it usually does and I could see my iPod in my device list. I left it to charge as normal. I came back a while later and my...
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Mar 22, 2009 | Apple iPod nano
Ipod nano went thru washer, now won't work
I did the exact same thing to my iPod nano 3rd gen. I discovered it by the noise it made in the dryer when it fell out of the pocket. Clack! Clack! It seemed dead, but it made a full recovery. What I did was put it on the dashboard of my car for a couple of sunny days to dry out, recharged it, and it was fine. If you have particularly hard water, maybe you'd want to try dipping it in some distilled water just to get rid of any mineral residue before drying it out. I'm impressed with how tough these dudes are. Good luck.
Feb 02, 2009 | Apple iPod nano
Ipod nano 4th generation 8gb purple wont turn off
Try holding the Play/Pause button down for a few seconds. Like maybe 5 or so, thats how my 3rd gen turns off.
Jan 28, 2009 | Apple iPod nano 4th Generation
Ipod nano plugged in but only showing up as USB storage device
Yes you have to Itunes srry :(. But there is a way that you can plug the ipod into different computers just put the ipod in manual mode and that should work.
Jan 08, 2009 | Apple iPod nano
Frozen ipod nano
Its ok, thanks... I was able to find a solution. I had to toggle the hold switch a few times, then press and hold the 'menu' and 'centre' buttons together. It eventually rebooted (well sorta).
Nov 27, 2008 | Audio Players & Recorders
Apple iPod nano Logo
123 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
