Question about Kenwood KNA-G510 GPS Receiver
How to install map update adta card
Puchased data card where is card slot?
  • 4 Answers
It's on the side of the unit. There's a cover that flips up to reveal the SD slot.
Posted on Jan 10, 2009
How do I update my Nextar x3-08 gps so the new roads will show up ?
visit Nextar.com to order your desired maps update and Check the overview description to see which SD card lists your GPS model number and serial number. Order the matching card.
Remove the existing SD card. This is usually found in a thin, rectangular slot on the side of the Nextar GPS.
Insert the SD card with the maps update into the empty SD card slot. Press until it clicks into place.
Reset the unit by pressing the "Reset" or pushing a pin into the "Reset" hole.
Click the "Navigation" button to have the maps automatically update on the GPS.
May 06, 2015 | Nextar X3-08 Car GPS Receiver
Avic s1
hello sir,
Portable Smart GPS Navigation comes with 3.5-inch Touch Panel Display, 2GB Flash Memory, Bluetooth Wireless Technology, and Scroll Wheel
  • 2GB Flash Memory contains the map data of entire US and Canada
  • Just unpack and use it � no PC connection is needed for startup
  • Future map data updates will be available by SD card � just load into the built-in SD card slot and the update will begin
  • Quickly set a destination by address, zip code, destination history, and more
  • Search for a gas station, restaurant or coffee shop using the POI Search � destinations are sorted into categories for short-cut searches, or use the touch screen to type in the name.
thanks for allowing us to help you
Dec 30, 2007 | Pioneer AVIC-S1 GPS Receiver
Garmin troubleshooting
When updating your map you may have chosen a version that does not have your state.... like canada and eastern USA... etc... try reloading your map and select via mapsource the map that carries your state. Or install a 4 gb sd card with the full map if your nuvi has the card slot on the side... good luck
Sep 04, 2014 | Garmin nuvi 200W GPS
Can not put an address in garmin nuvi
Try running an update with Garmin Express, let it sit for 30 Min after it says it is done, then check again
otherwise you may have jsut installed a smaller region ,... again Garmin express could help.
Aug 04, 2014 | Garmin nuvi GPS
No map data availble
Your Garmin GPS has an internal memory or an SD-card that contains an "operating system" and "map data".The operating system is like windows or Mac OSX. It contains the menu and everything the GPS displays. The "map data" is a digital roadmap the GPS uses to calculate your route. If the map data was on a SD-card that was inserted in your GPS, it could me that you lost the SD-card. That could be the reason your GPS can't find the map data. Sometimes it happens that when people connect their GPS to a computer to update the "operating system" of the GPS something goes wrong. For example, when you disconnect your GPS from the computer while the update software is still writing data to your device, the connection gets lost and you're left with corrupt files on the GPS. It could also be a defect in the internal memory of the GPS. I suggest you try to update the operating system with a program called "Garmin Express" (just google and easy find it). You need to connect the GPS to your computer with a USB cable. Then you can perform an update. I hope it helps to solve your problem. What you could also try is to soft reset your GPS. To do that, you need to remove the silver or blue frame around the screen of the GPS (it pops off). Behind this border there is a reset button.
If the map data is completely gone, and you don't have a backup there is only one solution: Buy the latest map for your GPS online and download it to your GPS. It's expensive. In that case it's better to buy a new device in a shop. Most new devices contain Lifetime online map updates (model name nuvi -then the number - LM or LMT) (LM= Lifetime Mapupdates T= Traffic information) Then you can update your map data every three months if you want.
Nov 08, 2013 | Garmin StreetPilot C330 GPS Receiver
I have nuvi 250 which needs the UK update. It has a memory card slot on the side. By using the card will I lose the European maps or does it just overide the UK maps
If it already has the European map then updating the European map will also update the UK map since the UK is part of the European map. You can get more details of how to update your map at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
Jun 11, 2011 | Garmin GPS
Cannot obtain any addresses on my GPS
I took the Garmin back to the retailer and they gave me a new memory card, seems like the other card did not have any maps stored on. Garmin is now working 100%.
Thank you very much for your response.
Regards
S Reddy
Sep 11, 2009 | Garmin GPS
Why cant I download my waypoint data to a 2 GB SD card. My Global map 5000c does not recognise the 2GB SD card. Do I need MMC/SD. Can I place the sd card in the slot beside the chart card ?. Thanks
You can place the SD card into the slot beside the chart card.
With the SD card in the GlobalMap unit by itself (take the chart card out), press MENU twice and choose BROWSE FILES. Does the unit indicate that an SD card is present? If yes, the card is working fine in that slot. Try the same thing in the other slot. If it only recognizes the SD card in one of the slots, the other slot is bad and probably won't work with any card. If the card is recognized in the BROWSE FILES menu, but the data that is on the card is not working, there could be compatibility issues with the data and the GlobalMap 5000.
Make sure the GlobalMap 5000 has the latest software update from http://www.lowrance.com/en/Products/Legacy-Products/GlobalMap-5000C/Downloads/GlobalMap-5000C-Software-Update-180/. You might need to get a different, smaller capacity card since your 2GB is not working.
If the 2GB SD card still isn't recognized in the BROWSE FILES menu after the update, the GlobalMap 5000 is not going to work with that 2GB card. You will want to get a different card. I suggest 1GB and smaller.
If this doesn't help, please let me know some more details. Is the 2GB SD card recognized in the BROWSE FILES menu. What are you seeing that makes you determine it does not recognize this card? What files are currently on this card? What kind of card is it (brand, model).
Jul 11, 2009 | Lowrance GPS
I need to install map update 2009 data card
If the map is on a SD card, just plug it into the SD slot on the side of your Nuvi with the power OFF. Then turn on your Nuvi and at the main menu, press the wrench symbol, then the map icon and then "map info". Uncheck your old 2008 map and check your 2009 map and you should be ready to go.
- Jim
SHARCNET-USA
Jan 18, 2009 | Garmin Nuvi 660 GPS Receiver
Kenwood KNA-G510 GPS Receiver Logo
574 people viewed this question
Top Kenwood GPS Experts
Michael Galve
Michael Galve
Mike
Are you a Kenwood GPS Expert? Answer questions, earn points and help others
