Question about Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens
I have a canon rebel xti with an 18 to 55 lens .. I recently bought an external flash to sit in the hot shoe .. now when I removed the flash from the hot shoe .. the cameras own flash will not pop up and work... I can manually pop the flash but it still will not work..  I thought that when I bought the flash at the camera store the sales person turned off something on the camera for the new flash to work.. is there something I need to change in the menus to get the cameras own flash to work.....
  • 25 Answers
I had the same problem.
Look closely at the hotshoe. Inside it, way over to the side, under one of the tabs on the side, is a tiny metal strip. When you attach an external flash, the strip is pushed down and holds down a tiny button that deactivated the pop-up flash. The strip can get bent so that it doesn't let the button come up even when the external flash is removed.
Very gently take a fingernail or a jeweler's screwdriver and run it underneath the metal strip. I had to do it a couple of times to get mine working again, but it's working great now!
Posted on Feb 18, 2009
    Novelist:
  • 155 Answers
The camera flash will only pop up automatically when in the automatic modes. When in Creative modes (M-DEP, M, AV, TV or P) the flash will stay down unless you press the flash button yourself.
Posted on Feb 05, 2009
I have problem, my 400D auto pop up does not work please help me
there is a sensor under the lip of the hot-shoe, you need a very small screw driver to lift up the piece that pushes down on the tiny button that tells the camera that there is already a flash mounted. this was caused by leaving the external flash on too long. try it, good luck. the sensor button is tiny., may need magnifying glass.
Dec 29, 2012 | Canon EOS 400D / Rebel XTi Digital Camera
Can I use Speedlight SB-50DX with Canon EOS Rebel Xti
It is not possible to use the Nikon SB-50DX directly on a Canon EOS Rebel camera. The Nikon flash gun hot shoe contacts do not match the Canon hot shoe contacts.
You can use the Nikon as a slave flash gun with a PC flash cord that matches the Nikon's flash contacts then connect the end of this flash cord to a flash trigger. The Canon's flash can then trigger the Nikon flash gun via the flash trigger.
Dec 27, 2011 | Nikon Speedlight SB-50DX TTL Flash
I just Bought a Canon Speedlite 540EZ it will not fire in the hot shoe of My Rebel XTI are they compatible
No. The rebel, or any digital canon camera requires the use of the EX or EX II series flashes.
Jan 19, 2010 | Canon Speedlite 540EZ TTL Flash
I recently bought a used canon EOS 400d which was
Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it popo up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.)
Oct 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Err 99
err 99 means there is moisture inside of the camera, probably inside the hot shoe
Aug 25, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
My camera is a Canon 400D. I put an external flash on it just few moments ago (canon speedlite 580EXII) and the flash wouldn't go off when i took pictures. So i took the flash off, but now the flash on the...
Hi Chrissy, I had observed the same problem - after an external flash had been removed from the camera, internal flash didn't pop up. Tried to look at the Google and finally found the solution. It helped me and could help you as well:
The usual reason is that the camera thinks that there's an external flash mounted on the hot shoe. Check the external flash detect switch. It's located under the right side of the shoe (there is a metalic piece which is kind of "elastic". Just try to push it and release several times, may be put the screwdriver softly under it and out... It helped me. Here is the picture of location of the detector.
Jan 11, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Switch from film to digital cameras.
I also own a Vivitar 285 that i used with my Canon F1 manual 35mm camera. Most older cameras before the advent of digital, had a hot shoe on top of the camera, or like in my case, the hot shoe went over the rewind knob. I also had to plug in a power cord from the 285 flash foot and the cameras PC connection in order for the flash to work on some other cameras. The Canon Rebel XTi has a TTL (through the lens) hot shoe usable with Canon's own EX flash units. You can buy a "hot shoe to PC connector" if the TTL camera hot shoe doesn't work, but be extremely careful, the only problem that exists with the older manual flash units was the trigger voltage is as high as 200+volts which would fry digital camera hot shoes. I tried my unit with a Wein flash trigger device on the PC cord of the flash and my Canon D60 with it's own flash. All shots were overexposed and washed out highlights.  Here's a copy of the hot-shoe review:h The EOS 400D's hot-shoe can be used with Canon and third party flashes (although sync only on most third party units). The hot-shoe is E-TTL II compatible. Compatible flashes include Speedlite 220EX, 380EX, 420EX, 430EX, 550EX, 580EX, Macro-Ring Lite, MR-14EX, Macro Twin Lite MT-24EX and Speedlite Transmitter ST-E2.  The Canon Rebel XTi doesn't have a PC socket to plug in a manual flash trigger cord which common sense tells me there is no provision to step up the voltage to trigger manual flashes - so my answer is this combination is not a good idea on a Canon Rebel XTi. Hope this helps.
Dec 12, 2008 | Vivitar 283 Flash
Images shoe up red
sounds like you might have an overheating CCD. Turn off the camera for couple of hours and when you try again if this happens again, return it to the store you got it from for warrenty repairs.
Jan 06, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Flash doesn't work
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Dec 02, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Not working with my Rebel XTI
ALL Canon digital EOS cameras will work with E-TTL only. Solution: you need EX flash for full auto.
Oct 20, 2006 | Canon Speedlite 540EZ TTL Flash
Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens Logo
197 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
