Question about Graco DuoGlider 7951 - G Collection Twin Seat Stroller
Spraying troubles When I spray my xr 7 the paint is coming out fine EXCEPT so does a lot of additional paint. When spraying the paint just runs out of the rim of the orange guard, never has done this before. Paint sprays out fine just more then going on walls in running on floor. The attachment is tight, checked and double checked. HELP!
    Problem Solver:
  • 9 Answers
Off hand I would say that you have the wrong spray tip for the paint that you are spraying or that the tip is worn. Another thing that it could be is the little piece of rubber behind the tip is worn or missing. My first suggestion is check the tip size with the recomendations of the paint that you are spraying (You will find this on any specification sheet from the paint manufacturer.. If the size is correct replace the tip. A new gasket comes with a new tip. Hope this helps.
Posted on Jan 20, 2009
Can I use spray paint in my back yard?
Sure, why not?. I've sprayed kitchen cabinets in my driveway, dining room chairs (metal, with auto paint) on my patio, wood paneling and more.
I would suggest using drop cloths or plastic to cover whatever you're not spraying, as spray will spread, especially if you use a water-based paint.
Dec 31, 2015 | Air Tools & Compressors
Over spray or fish eyes
Over spray is just that getting paint on a surface you are not painting (protect adjacent surfaces) "fish eyes" are almost always some type of oil wax or something that was not cleaned off and the paint film moves away from it- always clean all surfaces first before any painting.
May 27, 2012 | Air Tools & Compressors
Porter cable PSH 1 - clogs even with thinned paint compressor 4 gal 5.1 scfm
strain paint befor using. run water in gun or thinner to see if it will spray it before using and mix paint to the consistancy that spray gun or paint requires for spraying ( fine strainer)
Feb 04, 2011 | Porter Cable Gravity Feed Paint Sprayer
I dropped my kawazaki ninja bike in red but cant match the colour due to not knowing the code for the colour
This website will allow you to find the correct color match for your bike; ColorRite
Click on the Motorcycle link and enter your bike information.
If you find this information useful, please vote on this post. Thank you.
Jan 11, 2011 | kawasaki ZX-9R Motorcycles
When spraying latex paint I do not get smooth finish
Turbine powered hvlp systems are not the ideal system for spraying latex paint. If you plan to do lots of latex spraying an airless system is recommended.
You should be using a 2.00mm or 2.5mm tip. More thinning than recommended may be necessary to get a good spray. The addition of floetrol or similar latex retarder is a good idea. A retarder will slow the drying and allow more time for the paint to level and result in less orange peel finishes
Dec 24, 2010 | Campbell Hausfeld 3 Stage Hvlp Pro...
I can't remember how many seconds the paint should run through the funnel thingy
Assuming that you are using the standard 2.0mm tip - MAXIMUM 60 seconds.
The paint manufacturer publishes a data sheet with recommended viscosity for spraying and you should try that first. The data sheet will probably suggest a maximum percentage of thinning as well.
You will find that in order to obtain a nice fine spray 45 seconds through the viscosity cup is about right for most oil paints.
Nov 11, 2010 | Earlex HVLP Spray Station 3000
My graco nova 390 spray painting machine keepa squirting when I stop spraying what could be going wrong
Usually, the fluid valve has a lump of paint or debris caught where valve needle and seat meet. Be sure to strain the paint during fill-up each time. It should be cleanable by spraying some thinner (for the paint you are spraying) and jiggling the spray control. If not, you will have to dismantle the tip and inspect the parts. Hope this helps!
Oct 18, 2010 | Garden
Spray is very fine or not spraying
Any air leaks in the suction portion of the machine will cause it not to spray or spray weak. This is a airless paint spray correct? Your paint should be at least thin down using 1 gallon of water for a 5 gallons of paint. I find Baer paint is even thicker and had to slowly add more water.
To check if it is your paint. Fill a bucket of just water and see if it will spray your water. Of course after it gets a good prime. Let it recirculate until the water is coming out of the bypass as a solid stream. If it does not spray water then you have either a air leak or your pump packing needs replacement.
Let me know the results and the make and model of the machine.
Mar 20, 2009 | Binks Air Tools & Compressors
Graco DuoGlider 7951 - G Collection Twin Seat Stroller Logo
304 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
