Question about GE Spectra JBP78 Electric Kitchen Range
CAN I USE ENAMELED CAST IRON POT ON MY NEW GE GLASS TOP RANGE
What to know if enamel cast iron pots can be used on glass top range
  • 115 Answers
Yes they can just cant slide them around cause of scratching but as far as performance they are fine
Posted on Dec 30, 2008
Can I use a cast iron pan on glass cooktop range
Yes you can, magnetic induction stoves are working with anything metalic.
Mar 17, 2015 | Kitchen Ranges
If induction cooker does not heat the pot
Induction-compatible cookware contains contains iron or has a layer with magnetic properties. Cast iron, enamel cast iron and most types of stainless steel cookware are all induction compatible (But not all types; for instance, All-Clad's MC2 line, which is made of aluminum and stainless steel, is not induction compatible)
Nov 25, 2014 | Winco Professional Induction Cooker -...
Can I use Cast Iron Pots and Skillets on my new Frigidaire Gallery Stove Top?
Hello friend, thanks for your post!
It is not recommended to use any cast iron pots or skillets on a Frigidaire smooth top. In your manual it provides the best type of cookware material and cast iron is a poor heat conductor. Due to the weight of the cast iron it can cause scratches or damage the cooktop. I hope this information has been helpful. -Matt
Oct 09, 2014 | Kitchen Ranges
How to clean cast iron both pots and pans
Don't..... just rinse with hot water and dry them, the blackening is otherwise known as "seasoning" and protects it from rusting, left to soak or washing with soapy water will rust the cast iron...... if this happens you need to remove as much rust as possible by scrubbing with salt and a cut (half) potato, then wiping with vegetable oil and "seasoning" in a hot oven (do this a few times, the oil will evaporate and bake-on a protective film) think of the edges of your favourite roasting pan....... well used/cared for cast iron will almost certainly look totally black.
Jun 24, 2014 | Lodge Cast Iron Chef John Folses Cast Iron...
Le creuset enamel repair
If the chip is on the outside of the pot, it should still be okay to use. If its inside the pot-this is a useful posting
http://www.thekitchn.com/chipped-enamel-need-to-replace-86730
May 15, 2013 | Mario Batali 7-inch Chianti Enameled Cast...
Can one cook with iron skillet on glass top electric stove
Cast iron is NOT recommended to be used on a glass cook top due to its weight and potential for damaging the surface. Cast iron also heats rapidly and retains heat for a long time. Its great for gas stoves, but not a good idea for a glass surface.
The best cookware to use should be lighter in weight, have even heating properties with a SMOOTH flat cooking surface on the bottom for proper heat transfer. Some cookware that IS approved for use on a glass cook top is baked enamel, stainless and copper.
NOTE: Cooper and Stainless can leave marks on the cook top, but these marks do come off with most approved cook top surface cleaners.
If in doubt, always refer to your owner's manual. It explains in detail how to select the proper cookware for your range and the limitations and/or characteristics of each. If you have any questions, please let me know. I hope this helps you.
Dec 29, 2009 | Frigidaire FEF366 Electric Kitchen Range
I have a Kitchenaid electric range Architect Series II. Seems every time I use the large burner on the right side there is some sort of residue left that is very hard to get off. I have already made a...
What are you using to clean the stove? Only cleaners made for ceran type tops should be used according to directions. Do not use enamel coated pans or glass pans on your cooktop.If you have a boil over, turn off the burner and change to a different burner immediately. Clean up the spill completely before cooking on that burner again. Use a flat edge razor to clean tough residue. Your cooktop will look new for years to come, even with heavy use.
As far as the scratch, don't use abrasive cleaners on the top and only use pots and pans with flat bottoms. If you do use cast iron pans, never scoot them around on the top.
Nov 30, 2009 | KitchenAid KESC307 Electric Kitchen Range
CAN YOU USE CAST IRON SKILLETS ON RADIANT GLASS COOK TOPS?
you CAN use the skillet, but not with great results id assume, it holds too much heat, and problaby a bit too rough underneath and would probably scratch the glass top, in a family business for over 20 yrs. now and thats my recomendation, my brother also in the same feild swears his wife uses it with no issues!!!
Dec 30, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. So...you have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Feb 14, 2008 | Maytag MER5770 Electric Kitchen Range
Enameled Cast Iron Pans In Sharp Convection Microwave 820
It should be fine, but to be sure I'd contact Sharp.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277).
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 10, 2007 | Sharp R-820B Convection/Microwave Oven
GE Spectra JBP78 Electric Kitchen Range Logo
242 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
