Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opens by itself
We have a 19 year old home with a Stanley 1/2 hp garage door opener. The problem is 2 fold. When it gets cold out...below 30, the door will close and then open by itself. We also have it open by itself during the day when we are not home or will hear it go up in the middle of the night. I have followed all the adjustment guidelines but nothing seems to help. We have a second garage door, same opener, and have never had a problem with that one.
  • Anonymous Mar 16, 2014
I had the same porblem on mine , all I did was reset the dip switches to a different code and it works fine . I think the local airplanes were setting it off with the code that I had it on . Good luck !
Posted on Jun 09, 2009
  • 37 Answers
Sounds like the Logig board is going bad in your unit.
Posted on Dec 30, 2008
Don't know Mod. No. lost installation manual, approx. 5 yrs. old Need installation manual.
About 496,000 results (0.43 seconds) Search Results
    [PDF]GARAGE DOOR OPENER Model 3265 1/2 HP ... - LiftMaster
    www.liftmaster.com/.../en.../tucmanuals/114a3044.pdf Chamberlain GroupFasten the manual near the garage door after installation. .... This garage door openerhas been designed and tested to offer safe service provided it is installed, ...
    Manuals Download Craftsman Garage Door Opener Model ...
    www.craftsman.com/search=manuals%20download%20crafts...
    CraftsmanCraftsman has the best selection of Garage Door Openers in stock. Get the Garage Door Openers you want from the brands you love today at Craftsman.
    Craftsman 1/2 HP Chain Drive Garage Door Opener - Sears
    www.craftsman.com > ... > Garage Door Openers
    Craftsman1/2 hp Chain Drive Garage Door Opener Opens by Remote, Inside and from Car Enjoy a great end to every day by ... Owners manual - English (Warranty).
    Free Craftsman Garage Door Opener User Manuals ...
Feb 03, 2016 | Building Materials
I have a clicker model KLIK2U and forgot the code. How do I reprogram without the old code?
It's really easy to reprogram your unit:
Step 1. Hold down the (*) and the (#) keys until the keypad stops flashing.
Step 2. Determine your opener ID using the list below:
*1= linear garage door openers manufactured from 1997 to
present.
*2= Chamberlin, Sears, Craftsman, LiftMaster, Master
Mechanic and Do it garage door openers manufactured from
1997 to 2004 ( Orange learn Button)
*3= Same as *2 above, but manufactured from 2005 to present
with a (Purple learn Button)
*4= Same as *2 above, but manufactured from 1993 to 1996
with a (Green learn Button)
*5= Genie Intellicode and Overhead Door garage door openers
manufactured from 2005 to present (315 MHz).
*6= Same as *5 above but manufactured from 1995 to present
(390 MHz).
*7= Stanley garage door openers manufactured in 1998 to
present.
*9= Wayne Dalton garage door openers manufactured
in 1999 to present.
Openers with learn Buttons
Programming: Enter the PIN that you want to use, remember
(4) digits only. then press #
Enter ID # from list above, for example 2 then #
Press and release the Learn button on your
garage door opener.
Enter your (4) digit PIN and press (0),
for Genie and Overhead door units press
(0) twice. To test and use wait for light to go out
on keypad, Enter you PIN and press (0).
Note: If opener doesn't function repeat programming.
Instructions if required.
Sep 17, 2010 | Universal Garage Wireless Keyless Entry...
How to reset garage door opener pad without old acess number
A Stanley garage door keypad is wall-mounted, battery-operated device that allows you to open your home's garage door electronically without having to manually lift the door or use a pull chain. The keypad uses a four-digit access code that you program after the keypad is initially installed. You can change the code, disable the keypad manually by entering a invalid code and reset the keypad if the device is not working properly. After you reset your Stanley garage door keypad, the device is ready to accept a new access code.
May 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener won't work. Motor housing turns partial revolution but looks like transmission jammed. Motor broke from mounting screws. Stanley Premier, came with house, maybe 25 years old. Time for...
THE OLD STANLEY UNITS ARE NOT WORTH FIXING.
PARTS ARE NOT AVAILABLE AND THE UNIT DOES NOT MEET THE SAFETY STANDARDS
TIME TO BUY A NEW CHAMBERLAIN / LIFTMASTER / OR CRAFTSMAN OPENER
GOOD LUCK
May 23, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears garage door opener 1/2 hp about 6 years old. Will not respond to remotes to open and close. Light flashes on opener when remote is pressed but no door action.
Door sensors are not working. Check if lights are on both sides.
Might be misaligned or one is bad.
Door will close if you hold in the garge close button until it's all the way down.
And it will open on it's own.
You can get these off ebay.
Jan 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have two Sears 1/2 hp garage door openers. Cold weather problem
Very strange they both have the same exact problem. I would suspect something with the brackets is changing. When you are having this problem and the light on the receiver unit is not lit, tweak them a bit and see if it comes on. The odds of the logic board in both openers having the same thermal problem is just too high.
Dec 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programming my 98 blazers Garage door button on dash to a stanley
Here is some programming info for the Stanley.
http://www.aaaremotes.com/standualcodl.html
The programming information for your Blazer should be in the owners manual.
Aug 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
627 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
