Question about Kenmore 659 Electric Dryer
Going from 3 prong wall plug to 4 prong?
Wired it up and ran and made crazy noise then stoped. the light in side the dryes still works. how do i figure out if i wired it up right?
    Sergeant:
  • 359 Answers
Remove cover take a volt meter with one lead on center lug and one on the right lug should read 120 volts , then with one on center lug and one on left should read 120 volt , then with one on the left and one on the right should read 240 volts careful always when checking live voltage void electrical shock
Posted on Dec 30, 2008
Three prong to 4 prong outlet
Yes it can be. I suggest you get a licensed electrician to handle it.
Jan 27, 2013 | Bosch Nexxt 500 Dryer
Need to change out the wall plug to fit the dryer plug. The dryer is a 4 prong and to wall is a 3 prong.
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Mar 18, 2011 | Dryers
Change a 3 prong plug to 4 prong
Is it an electric dryer or gas dryer? If it's a 120 volt gas dryer, then no, you need to keep it on a 3 prong cord. If it's an electric dryer, then yes it is possible to install a four prong plug onto it. Although it isn't recommended.
The main thing you need to know is which wire is ground. From the machine, it should be the green wire. On the plug, there should be on prong that is slightly longer than the other 3. The ground has to be the first one in the wall receptacle and the last one out. So the slightly longer one is where the green ground wire needs to be wired in. The other two wires are both power so it doesn't really matter which prong you wire those wires at.
Once again I'll remind you that it isn't recommended to convert 3 to 4 prongs like that. Just be careful and make sure you aren't touching any live wires.
Mar 26, 2010 | Dryers
Our whirlpool Duet dryer has three prong plug and home has four prong outlet. Do we change the cord or the outlet?
You should change the plug at the wall. From your description, your dryer plug has two hot wires and a ground.
Your existing plug probably has 4 wires to it - two hots (120 volts each), a neutral (white), and a ground (green). The two hots are probably black or black and some other color.
You will need to match the plug on your dryer cord with the plug at the wall. The type of plug required should be described in your owner's manual. If you don't have that, then take a digital picture of the plug on the cord of your dryer and bring it to your local hardware or home improvement store. They should be able to match the companion wall plug for you.
Make sure the power is off (important). Remove the existing wall plug. When you wire it back up - this time with only three wires, connect the two hots (black and some other color) to the two hot prongs (terminals) and the green wire to the ground prong. Put a wire nut on the end of the white wire and tuck it back into the connection box. That's it. Turn the power back on and test for proper voltage and wiring configuration at the wall plug before you plug the dryer back in.
If you aren't familiar or comfortable with working on electrical apparatus, you should have a licensed electrician do this work for you. This solution also assumes you are in the USA.
Jan 01, 2010 | Whirlpool GEW9250 Electric Dryer
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
Jul 11, 2009 | Frigidaire Dryers
Can I install a 3 prong dryer power cord versus a 4 prong one and will it work?
yes,is your wall plug 3 prong?remove the small cover off the back of the dryer,you will see 3 screws,remove the 4 prong cord,all you have to remember on the 3 prong is the middle wire on the cord goes to the middle screw on the terminal block, mount the other 2 one on each side and your done,let me know how you do-mike
Apr 21, 2009 | Dryers
Wall plug is 3 prong, dryer is 4 prong...is there an adaptor available?
The following link explains the wiring scheme for 3 and 4 prong power cords. I know the instructions are for converting from a 3 to a 4 prong, but if you look under the "Additional Notes" section it explains how to convert back to a 3-prong if you are currently using a 4-prong.
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. If you have any questions, please let me know.
Aug 13, 2008 | Estate TEDX640JQ Electric Dryer
Kenmore 659 Electric Dryer Logo
42 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
