Question about Samsung SyncMaster 930BF 19" LCD Monitor
Monitor did not turn on when I reset up my computer system
I just cleaned my office and took down the three computers. When I reset up the computers, the two Samsung monitors did not come on. What simple thing am I missing. It's not likely that two monitors would go bad at the same time, is it?
    Master:
    Sergeant:
  • 461 Answers
Have you check the connections?
Posted on Aug 30, 2007
My computer monitor tokk so long to turn on
remove all unnecessary add on's, cookies and programs that are not necessary for the operation of the computer. Go into systems management and defrag the drives in the computer. This gets all the bits if information on the discs together. Add more RAM if you are doing a lot of work as small ram capacity slows down a computer . Failing all that take it to a computer geek and have him help you out.
Dec 17, 2013 | Acer Computers & Internet
I just purchased a new cpu and plugged in my Acer X203H monitor that i have only had for around 3 months and when I turn on the computer and monitor, the monitor power light flashes orange and blue and has...
Sounds like your PC is diplaying out of your monitors range. Try pressing f8 while booting up to get safe mode. then turn down the video resolution to display what your monitor can handle. Good Luck.
Nov 20, 2009 | Acer X203H bd Monitor
2-3-4- years old benq FP19G = returned to office after lunch - burned out electronic smell in air - whole section of office electrically dead' - did reset = computer fired up ok - but screen blank...
Benqs have had some quality control issues but from your description the inverter board went on you. It needs to be replaced or repaired. Expect to spend about $100 for the repair so you may want to consider just replacing the monitor.
They can be fixed. The monitor I am using right now was one of those dead ones. It took a few hours to find as the rest checked out and it turned out to be a bad ground. Unfortunately when you smell burnt electronics you are not going to get off that easy.
Jul 15, 2009 | BenQ 19" lcd black 1440 x 900 19 inch LCD...
No video output on Intel D915GEVL motherboard with Intel GMA900
hi there
if you would power down the computer and the monitor and unplug the cord going to the pc from the monitor and the power cord for the computer,,, now open up the case and find the powersupply cable going to the motherboard and unplug it now preess the computers on button than the reset button .. this will discharge any esd than wait 3 min and plug it back in than connect the monitor to the pc and plug in the power cord for the pc and monitor and turn on the monitor and you should get a messzage that the monitor is working now turn on the computer and see if it works let me know how this works ok
best regards mike
Feb 22, 2009 | Intel D915GEVL Motherboard
Computer will not shut down
right click your desktop go down to properties and click on it. then go to the screen saver tab and select power. then set the times there and hit APPLY then Hit ok.
Jan 27, 2009 | Computers & Internet
THE ACER MONITOR AL1711 BLINKING IN DIFFERENT COLOURS AFTER THE COMPUTER IS SHUTDOWN - TO STOP IT I HAVE TO REMOVE THE POWER TO THE MONITOR OR BEFORE SHUTTING DOWN I HAVE TO PUT THE POWER OFF FROM THE...
I just had this problem at work and what I did was I powered up the computer and went into the menu. I went to the 2nd to last button and selected the reset. It's working perfectly now. I do not know if it will last but it's easy and free.
Jan 23, 2009 | Acer AL1711 17" LCD Monitor
Faulty LCD Monitor ?
off hand it sounds like a power supply issue. sometimes fixable sometimes not.
Robert
Aug 26, 2008 | Scanport Computers & Internet
Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Aug 08, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Loud Fan, Three Beeps, Black Monitor and No Keyboard response
I have the same model after youlet it sit for a long enough period to cool down it will come back on and work normal, it is a cooling problem called gateway and they confirmed this theproblem I ran in to was what fan this computer has 3. temp fix I used was to remove the tower cover to allow better air flow try this till you can figure out what fan is messing up
Jun 02, 2008 | Gateway GT5404 PC Desktop
HCL Monitor type HCM580M display problem
Information about the Linux / UNIX less command. Thus, various display problems may result, such as long lines being split in the wrong place. -R --RAW-CONTROL-CHARS, Like -r
Device Manager information and help This section will also display what COM ports are detected; for example, ... CODE 13 - System Failure - Possible problem in Device Driver or Windows 95 Code.
Good Luck, Please dont for get to Vote, Thank You.
Dec 19, 2007 | Computers & Internet
Samsung SyncMaster 930BF 19" LCD Monitor Logo
227 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
