Question about Aardvark Direct Pro Q10 (bundle) External Sound System
Will my Aardvark Q10 work with a new machine with Vista?
I am considering purchasing a new Dell machine for my recording setup. I have two concerns, I have heard that newer machines have lower voltage PCI ports, and I don't know if the XP drivers will work in Vista.
Thanks
Mark
I have heard that the drivers will not work in Vista. But, you can get the XP downgrade (sometimes for free) and still be able to use your Aardvark on the new machine. As for the PCI slots being different, I wouldn't think there would be an issue. If newer machines had PCI slots with lower voltage or other differences, this might make them incompatible with a whole slew of older PCI cards. As far as I know, the only issue is with the drivers.
Posted on Feb 26, 2009
I have a conflict between my screen and a PCI standard PCI-to-PCI bridge. How can I resolve this please?
Unless your machine is legacy the Interrupts and memory ranges should be automatically set I guess yours is an older machine? or the automatic assignment of resources is not set in bios. ?
If that is the case set the resources in bios. setting them to auto should clear the issue hopefully.
If your machine is newer, say from within the past few yeaars I am baffled, I have not heard of anybody experiencing resource conflicts in the last ten years or so
Jun 28, 2015 | Computers & Internet
My son saved up and bought a Gateway SX2855-UB12P. We have upgraded to 8MB of RAM and now are looking to upgrade the video card which currently is a PCI Express x16 Graphics. Given his machine is a en
Hope you mean upgraded ram to 8 GB 8 mb is not much ram to run a computer.
To upgrade your computer's graphics card, unfortunately you can't just simply purchase a card and install it to your computer. Before purchasing a card, you must first confirm what is compatible with your motherboard. Graphics cards use either AGP or PCI Express technology. Many older computers use AGP. AGP cards can vary in version and bandwidth, whereas PCI Express cards can vary based on their lane . Moreover, the card itself is not your only consideration when looking to upgrade your computer's graphics. You must also consider the strength of your computer's power supply as well, since most newer cards use a lot of power. Download, install and run SiSoftware's Sandra (see link Below) to find out information on your motherboard. http://download.cnet.com/SiSoftware-Sandra/3000-2086_4-10556571.html Click the "Mainboard Information" icon, then write down the information next to "Manufacturer" and "Model." Navigate to the motherboard manufacturer's website. If you are not sure of the website's URL, enter the manufacturer's name into a search engine to find the company's website. Go to the support page and enter your motherboard's model. Download the motherboard's manual or review the specifications. Search the manual or specifications for "Expansion slot," "AGP" or "PCI Express." If the expansion slot uses AGP, note the version (AGP comes in 1.0, 2.0 and 3.0), as well as the bandwidth (1x, 2x, 4x or 8x). If the expansion slot uses PCI Express, note the amount of lanes (x1, x4, x8 or x16). Search the manual or specifications for "Power," "PSU" or "Power Supply." Write down the power supply's voltage (3.3V, 5V or 12V) and amp rating (designated by "A"). Not all manufacturers list the amp rating in their documentation, so you may need to contact the manufacturer for more assistance. Compare the graphics card you want to buy to the motherboard's expansion slot. AGP cards won't work in motherboards using PCI Express, and vice versa. Similarly, AGP 3.0 cards won't work in motherboards using AGP 1.0. A PCI Express x8 card will not fit in a PCI Express x1 slot. Check the voltage and amperage of the video card to the voltage and amperage on your motherboard. A video card that requires a higher amp rating requires a powerful PSU. Hope this helps.
b>
Dec 24, 2012 | Computers & Internet
Dimension 8250, No Ethernett, Sound card or PCI Input
Bear in mind that your antique machine dates back to 2003. If you are installing hardware that is newer than your OS, there is a strong chance that drivers do not exist for it.
Check whether the HDD is visible from the BIOS startup menu! If it is then you are looking at XP driver issues - or hardware configuration. I assume that the drive in question is a secondary drive? If so, the old ATA 66/100 IDE interface on these machines is fussy about the drives and each drive may have to be setup with a different ID 0/1 using jumpers on the drives. It is easy to overlook this part of the setup!
Here's an article describing how to do this: http://www.makeuseof.com/tag/install-ide-hard-drive/
Oct 23, 2012 | Dell Dimension 8250 PC Desktop
What is the video card slot type
From the information available on the Dell website I would say you could fit any PCI-E you can afford. The thing to consider is the power output of the power supply, which isn't great and it is not easy to upgrade on dell machines. So I would suggest you spend no more than about 75 (GBP)
Sep 14, 2012 | Dell Dimension 4700 PC Desktop
Also purchase the same washer. It's a piece of ****. Our previous front load washer was a Whirpool an we never had the smell issue for over six years. That's what we get for buying a 1st gen...
Seen this issue on a tv programme, newer washing machines are designed to run at lower temperatures. Unfortunately, they didn't consider all the gunk that could be left in the machine because the water temperature wasn't hot enough to dissolve everything.
Try a max temp. wash next time, see if there's any difference. Make sure you're not going to shrink any clothes.
Oct 23, 2011 | Samsung WF337AA Front Load Washer
Fuse bl;ows when turned on
Hi. Is it the line fuse or the output fuse that blows? Does it blow if it is not connected to the machine.
It is probably best in the long run if you purchase a new charger for your machine. Some older chargers are simple regulation circuits, and most of the newer ones operate on a high frequency switching power supply mode, and have complex circuitry.
If you can get your old charger fixed by an electronics serviceman, it would be a good idea to test it by recording a battery charge with a data logger, to make sure it is charging at the correct voltage levels.
Buying a new charger might mean that you will save destroying a set of batteries as well.
We have here testers for batteries and chargers where the data logger does a voltage test every 10 seconds. We can record a charger for 4 days, and download it to a PC. We have found a few chargers that overcharge. This will eventually destroy the batteries.
Good luck. Neil.
Jun 02, 2010 | RTO Mobil Line Mobility Scooter Chair...
Inserting GeFroce fx 5200 graphics card!
sorry to say this your dell system only has a X1 vga slot it is not compatible with the card you have.
If you want to use a card you have to go for a new system
Nov 30, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
I need the LX6 Direct Pro Driver for windows vista. All of the drivers i have tried say there do not support that OS. Do you have this driver or know where i can get it. Also do you know if the...
Aardvark had went out of buisness about 3 to 4 years ago. Unfortunately they didn't last long enough to write a driver for vista. Sorry to be the bearer of bad news. I love aardvark I had the LX6 and still have the 24/24 and Q10. Too bad they only work up to XP. Sorry. driverguide.com still has the XP driver.
Oct 01, 2009 | Aardvark Direct Pro LX6 Sound Card
Aardvark Direct Pro Q10 (bundle) External Sound System Logo
279 people viewed this question
Top Aardvark Computers & Internet Experts
David Payne
David Payne
Are you an Aardvark Computer and Internet Expert? Answer questions, earn points and help others
