Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Filter sucks against top creating low suction
When I turn the vacuum on, the filter sucks up against the top causing low suction and nothing will suck up.
    Problem Solver:
  • 3 Answers
Re: Filter sucks against top creating low suction
See my post with the same problem (described in painful detail) at:
I've no idea why this should happen all of a sudden. But it has. And so far nobody is suggesting anything.
Posted on Jan 03, 2008
0 characters
3 Points
Why won't it suck
Hey there! It's possible that you may still have a clog in your vacuum somewhere. The filters can also cause the vacuum to lose suction. Try these steps to restore suction to your cleaner.
1. Remove the dirt cup canister from the vacuum. Remove the dirt cup lid.
2. Remove the primary foam filter. Rinse the filter under running water until it runs clear. Allow 24 hours to air dry outside of the vacuum.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash) Filters should be replaced once a year.
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Remove the bottom plate and brushroll. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
6. Check that the brushes are still spinning. If not, replace the belt.
Hope this helps!
Jun 20, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
N2000 clean filter
The red guard goes on top of the foam after it is installed. The purpose of the red guard is to keep the bag from sucking down against the filter when you get a few inches of dirt in the bottom of the bag. If it sucks down against the filter the dirt in the bag will cause an airlfow restriction even though the bag is not full.
Jan 25, 2014 | Riccar Vacuums
No sucking
if you have no suction - then the problem could be a dirty filter or a blocked suction hose. clean the filter and check the hose from top to bottom for blockage. if all is clean and clear and you still dont have suction then the problem could be a bad vacume suction motor.
Feb 02, 2011 | Hoover U5175-900 Fold Away Bagless Upright...
It barely sucks, the suction is poor and the brushes don't spin at all.
If the brushes are not spining you might have something wraps around and stuck in it. like hair or sting. you might have to take the object where the brushes are apart to clean it out. Also check the belt, and if there is a filter make sure it is clean. Dirty filter can cause low suction.
Nov 30, 2009 | Electrolux Central Vacuum
My eureka 437 stopped sucking
I believe the filter on your vacuum is clogged. Bagless vacuums require the filter be brushed or washed and dried, If they are not, the filter will clog, resulting in the reduction of suction. Clean filter about every 3 months or sooner if the same problem happens again. Hope this helps.
Aug 20, 2009 | Eureka Vacuums
Vacuum gets hot loses suction and turns off
you have replaced all three filters?
if its turning and sucking with all new filters you have a glog somewhere
Apr 23, 2009 | Filter Queen Majestic Canister Vacuum
Vaccum has no suction
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Eureka Enviro Vac Model 4470 Not Sucking
First, check to see if there is suction without the hose on the base. If not, and there is no blockage, the problem is likely a damaged impeller, the small fan that makes the suction. That will have to be replaced.
May 21, 2007 | Eureka Smartvac 4870 Bagged Upright Vacuum
Low Suction
Empty the recovery tank; it may be full
and the automatic shut-off engaged.
Make sure filter and filter lid are properly
Make sure tanks are locked in place.
Check the filter and clean if dirty.
Make sure nozzle is replaced properly
and locked
Apr 30, 2007 | Hoover H3030 FloorMate SpinScrub 500...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
205 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
