Question about Numark ttUSB Turntable
Numark TTUSB seems to be rotating too slowly
Just bought and set up a new Numark TTUSB. At 0% pitch shift, the table isn't spinning quickly enough while transferring from record to . As far as I can tell, everything is set up right. I slipped the belt onto the motor pin, I'm not 100% sure the stylus is weighted perfectly, but messing around with that had no effect on playback. When I increase the pitch shift to +10%, I get the correct playback speed. Any suggestions?
  • Anonymous Mar 15, 2009
    Numark TTUSB runs slow. I can adjust and somewhere between 5 and 10 percent I can find the right pitch, but that's not really a solution. You should not have to adjust pitch every time you play an LP.
djproaudio
  • 515 Answers
SOURCE: NEED HELP WITH A TTUSB NUMARK TURNTABLE
You answered your own question: "He has Vista ..."
Vista still has a lot of bugs in it in regards to audio codecs. Most manufacturer's won't provide support on PC's with Vista.
- OPTiC
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Posted on Aug 08, 2008
SOURCE: Not hearing songs I transfered to my i tunes from my Numark TTUSB
Open Preferences, Sound, your input should be  USB Audio Codec (turntable).. make sure your output is NOT USB Audio Codec, rather, headphones (for external speakers plugged in there)... thats how i have mine set up...
Posted on Jan 25, 2009
  • 69 Answers
SOURCE: Where do I connect the ground wire from my amp to Numark TT USB?
i used to have stanton t80s,had the same problem no gnd on deck but diddnt need it there waqs no bad earth so if it sounds good leave it
Posted on Aug 07, 2009
  • 4234 Answers
SOURCE: Tonearm Weight, Good Replacement Stylus, Gain level
Most good turntables will track with weights between 1.25 and 1.5 grams. Any more than that and you are putting alot of pressure on the needle. Experiment a bit and make sure that the needle tracks well and that the sound is good. The less weight you use, the longer the needle will last and the less wear on the record.
Dan
Posted on Aug 11, 2009
57 varieties
  • 1653 Answers
SOURCE: where can I download gracenotes software for free
just do a Google or Bing search for gracenotes software download
Posted on Sep 10, 2009
High pitch noises.
It sounds like feedback hum. Most likely caused by the settings on your computer. Try adjusting all the sound settings. Especially record settings.
Sep 01, 2017 | Numark ttUSB Turntable
Platter vibrates; doesn't rotate smoothly
Do one thing Remove the palter and put one drop of lubricating oil in the center shaft. Also put one drop in the motor shaft. Be carefull do not drope the oil in motor pulley. If so clean the pulley with a cloth. Because it will cause slipping the belton the pulley.Then put the plater back. Rotate the plater with arms for some time. Then check.
Ajin
May 07, 2012 | Numark ttUSB Turntable
My turntable judders when playing a vinyl.I have tried a different drive belt and a different platter,but that has not helped.I am transferring my vinyl to mp3 so I need a solution.The turntable is about 4...
Check the belt path for any foreign material that may be on the pulleys. Without the belt attached, feel for a rough spot(s) while slowly rotating the platter. Same for drive motor. This will often identify the offending part. With a seldom used table, the grease on the table spindle dries out and may need cleaning with a solvent (alcohol) and q-tips. The same for the motor. Then re-lube with a synthetic oil. Be careful that you don't lose any bearings or spacers. This technique has repaired many tt's. Good luck, work slowly and carefully.
Jan 13, 2011 | Numark ttUSB Turntable
My turntable is running slow!..and i just bought this turntable brand new a couple weeks ago...please help me.
Check the +10 / -10 slider too make sure it's not set to -10; adjust it towards +10 to the pitch / tone desired. Check the belt to make sure it is not loose. A loose belt will slip and turn the record slower than the recommended 33 or 45 RPM. Have a look at the YouTube video for correct set up if you're still having problems.
http://www.youtube.com/watch?v=zFonG5dijKU
Please rate this reply if you found it helpful. Good luck!
Jul 01, 2010 | Numark ttUSB Turntable
Jul 18, 2009 | Numark ttUSB Turntable
I Bought a TTUSb from an auction. I do not have software EZ Conv
My guess is that you have not bought a Numark turntable at all, but a fake. You should contact the auction site/place and inform them you have been sold a fake. Many sites have ways of dealing with fakes. You might even get your money back. If you are lucky!
Jun 15, 2009 | Numark ttUSB Turntable
Belt came off
the belt is at the button of the turn table.
lock down the turn table and turn the turn able upside down, unscrew the 4 screws and open the button plate. you may need to get a new belt. make sure it is the right size.(that may be a difficult, now a days).
Sep 08, 2008 | Numark ttUSB Turntable
- OPTiC
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
May 16, 2008 | Numark ttUSB Turntable
Platter spins very slowly
Well hope fully its something small. check your pitch control first make sure its not set at a slow speed. then check your start stop knobs at the bottom of the table. roll them one way then start it see if that works, then the other way... if its not that then its possibly its a malfunction ,, Numark with there new awesome products but sometimes faulty that turntable wigs out goin slow then normal then slow ect... If its less then a year send it in it is coverd by warrantee
Oct 07, 2007 | Numark CDX Turntable
Numark ttUSB Turntable Logo
55 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
