Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Where can we get the best IC Replacement
We have the Panasonic PT-56TW53 and it's IC's went. I have been reading mix reports about which IC's to get.
I went to the Parts Store, but they seem to be made by Panasonic or at least that is what it states when we look up our model. They do offer Toshiba brand.
Do we go with the Panasonic Brand or do we opt for another brand? We don't want the same thing to happen again so soon, so we are reluctant to get the Panasonic Brand.
If someone has done this replacement and can offer any advice as to where and what brand to purchase, I would be thankful. Any help or advice will be greatly appreciated.
  • 4,234 Answers
This unit used STK392-110 ICs. THese can be purchased from any reputable supplier. I have used Toshiba, Sanken and others without problems for years. When you install them, make sure that you also use plenty of heat sink compound (white stuff) on the back between the IC and the heat sink. This will insure good heat transfer and make the ICs last longer. Also check the area for any low valued resistors that may have changed values or opened up.
Dan
Posted on Dec 31, 2008
  • 905 Answers
Always stick with the manufacturers brand ! but you will need to check the resistors on the IC lines to make sure thier values are not off , because that will cause the IC to go again no matter what brand IC you use. other components in line of the IC should also be checked for bad values as they can also cause malfunction and breakdown of an IC and its circuit components
Posted on Dec 30, 2008
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Jan 28, 2013 | Panasonic PT-56TW53 56" Rear Projection...
Pt 56tw53 picture trouble
Based upon your description, the problem area is the convergence circuit. These sets usually have a couple of large black ICs that control the convergence. These Ics either have bad connections on the pins or are failing. You can try resoldering the pins of these ICs if you can solder, or replace them. These ICs are usually marked STKxxx and are attached to a heatsink.
If you get this repaired, expect to pay about $30-$40 for each IC (there can be 2) along with the local labor rate for projection sets.
Dan
Mar 26, 2008 | Panasonic PT-56TW53 56" Rear Projection...
Screen went black with a vertical rainbow line down the middle
Failue of the vertical section, could be the drive, the power to the section or even some discrete componets. Unless you are familiar with electronics , get some help to ceck out on these circuits, could not be major but to get themain culprit will require good probing.
Jun 29, 2010 | Panasonic PT-56TW53 56" Rear Projection...
I have a panasonic projector tv model pt-56tw53g, when i turn on it wont come on but the red light blink 5 time. is there a problem with my lamp or the power supply.
the blinks are signaling how many circuits or transistors it is going through that are good letting you the 6th is the issues you will need to contact a tv repair man in order to have someone open it up and find what can be done about it
Apr 25, 2010 | Panasonic PT-56TW53 56" Rear Projection...
When I turn my TV on it shuts back off and power light flashes
Power supply board is dead.Replaced the power supply board well get ur power back and solved this.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Feb 10, 2010 | Panasonic PT-56TW53 56" Rear Projection...
My panasonic pt-56tw53 picture was not looking righ all on adjusted - went to the converge set up and now lost whole picture just shows all colors in middle on tv zig zaging
If you go into the customer menu and select convergence and it is skewed you need to remove the light box and replace both of the STK-392-110 CONVERGENCE IC chips this set uses.
I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET--I can post them here if you think you or someone you know can do the repair.
Most shops get 300 or more for this repair--if you buy the chips on Ebay (I can tell you the seller to look for there) they and any other parts should total under 30 dollars. The fact that the set is still coming on means most likely just the two chips need to be replaced and the set adjusted with the Panasonic remote for this set.
If you have questions or want the instructions rate this solution and let me know and I will post them here---I do this here for FREE.
SD TECH
Nov 27, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Panasonic PT-56TW53
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 02, 2007 | Panasonic PT-47WX49 47" Rear Projection...
I had the same problem with my TV, It seems the high voltage trasnformer blew which in turn casued the pin cushion?? to blow. It then shuts the tv off to prevent more damage to it. $500 with service charges to get it fixed!
Nov 05, 2005 | Panasonic PT-56TW53 56" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
75 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
