Question about Linksys Wireless-G WRT54G Router
Security can't seem to get security set up right and people are using my wireless causing it to run slow.
  • 59 Answers
Here's a video that teaches you how to do it
http://www.youtube.com/watch?v=ZH6bLu3ri1c
http://www.youtube.com/watch?v=KQH5egRPnoo
look up wireless or wifi security in youtube lots of tutuorials
Posted on Dec 30, 2008
How can i block intruder?
If the Wireless device isn't secured, Secure it. Set up a SSID and Security Key(password). If it is secured, change the Security Key(password), Use the Linksys Setup Manual found here: http://support.linksys.com/en-us/support/routers/WRT120N Always Secure your Wireless. If unsecure your signal, at best, COULD be use by anyone to connect to the web using your resources and slowing down your activity. At worst, use your signal for nefarious purposes causing you a great deal of Pain and Heartache, and MAYBE the FBI knocking at your door.
Mar 20, 2013 | Linksys WRT120N Router
Tip
Solution on a slow Internet connections Problem  The major  causes for a slow...
The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.
 1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.
 2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.
 3. Internet Worms
An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.
 4. Running Background Applications
Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.
 5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.
 6. Service Provider Issues
Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.
 www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Tip
Steps to improve the shutdown times.
Start Registry Editor and navigate to the following key:
[HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management] Set ClearPageFileAtShutdown value to 0
Or, using Group Policy Editor [for Windows XP Professional]
Click Start, Run and type Secpol.msc
Click Local Policies | Security Options
In the right-pane, set Shutdown: Clear virtual memory pagefile to Disabled
However, this setting is not the only cause for slow shutdowns. Non-responsive programs and Services also contribute to slow shutdowns. If the problem is seen recently after installing a third-party driver or software, try a System Restore rollback to see if that resolves the slow shutdown problem.
on Mar 09, 2010 | Computers & Internet
My computer seems to disconnect the internet
Wireless or Hard Wired internet connection ?
When you set up a dial-up Internet service connection on your Windows computer, it comes automatically configured to disconnect itself after a predetermined period of inactivity.
This means that if you walk away from your computer and forget that you're online, your internet connection will automatically shut itself down.
If this feature isn't as helpful as you assumed it would be, you can turn it off using the Network and Sharing Center.
Click "Start."
Click "Control Panel."
Click "Network and Sharing Center."
Click "Change Adapter Settings."
Right-click on your dial-up Internet service icon.
Click "Properties."
Clear the check box next to the "Auto Disconnect" listing on screen.
Click "Apply."
The auto disconnect on your computer Internet service connection is now turned off.
also if its running slow
Slow computers that persistently disconnect from Internet access may have issues with the wireless setup or if on a wired connection, there may be a problem with the Ethernet cable or port.
Troubleshooting connection and speed issues can save money rather than taking the computer to a technician or repair shop.
Additionally, some firewalls and security features can make it difficult to access certain types of websites.
Before spending money to have the computer diagnosed, try running through the most common, basic causes of connection issues.
Consider the type of site you are trying to access.
High-traffic sites such as gaming sites can sometimes be affected by high volumes of users accessing or attempting to access the site at once.
Test this by attempting to access the site at different times during the day and evening; peak hours for games that typically appeal to children may be during the afternoons on weekdays while games for older or more mature audiences will see high traffic at night.
Check your Internet connectivity and determine whether you are using a wired or wireless connection.
In the lower right side of the computer screen there should be an icon displaying the Internet or network connection.
Wireless connections are displayed with connection bars similar to those seen on cell phones while wired connections may show the end of a plug next to a monitor icon.
Reset the router if using a wireless connection.
For most home routers you simply unplug the power cord from the router box, wait a moment and plug it back in.
You may have to restart your computer to reestablish a secure connection.
Access the router through the computer and check for updates. Some routers offer firmware updates that fix some connectivity issues.
While updating the router, check for Internet browser updates as well as any critical updates for your computer's operating system.
Verify the computer uses the most up-to-date version of the Web browser available.
Try a different browser. Internet Explorer is the most commonly used Web browser, but not always the best for every site.
Try downloading another Web browser such as Firefox, Opera, or Google Chrome and test the sites there.
If the connections are still disconnected and the Internet speed seems slow, it may be an Internet issue.
Wired Connections
Trace the Ethernet cable from the Internet modem to the computer if using a wired connection.
Unplug the end of the Ethernet cable and check that the plastic head is secure and that there is a click when you return the plug to the modem; do the same on the computer end.
Inspect the Ethernet cable carefully as it runs from the modem to the computer.
If the cable was tacked down with a staple gun or other attachment, check the cable to verify it wasn't accidentally pierced.
Additionally, check for bends, twists or worn areas along the cable.
Measure the length of the Ethernet cable.
In general, cables longer than 100 feet tend to receive poorer signal transmission.
If the cable is longer than 100 feet, replacing with a higher quality cable or moving the computer or Internet modem may resolve connection issues.
Hope this helps.
Nov 28, 2012 | Computers & Internet
Slow or no wireless speed, connection says excellent
Your router may be toast but here are a couple of things to try:
Please remember, I'm guessing here...
Before restoring to factory defaults, make sure you can get to the config pages using the rj45 (wired) ports. Do a speed test with a wired connection at http://www.speakeasy.net/speedtest/
1. try removing all security. No WEP or WPK. Also, use no mac address filtering. See if it speeds up. Go back to http://www.speakeasy.net/speedtest/ and try speed testing the wireless portion of your router..
2. If it has automatic channel selection, this may be acting up. So manually select channels. Then do speed tests at the web site (or any speed test web site of your chosing). You may find a screaming fast channel.
3. If this fails to help, use the reset to factory default button. Try setting up the router with NO security first and do speed tests. Use automatic channel selection first, do speed tests, and if all else fails, you can try manually selecting channels again. If the router works well, you might want to set up security again and retest.
4. If all this fails, buy yourself a new wireless 802.11N - (N1) router. They are screamin' fast and have better range.
Apr 07, 2009 | Linksys Wireless-G WRT54G Router
Belkin 54g Wireless connection problem.
This is more of an explanation then a solution, but to best explain what to do I have to first explain why this is happening. When you add security to a wireless router or ap you add extra envelopes to the packets of info being transferred, adding encryption to that makes it much slower because the ap has to encode all packets coming to you and un-encode all packets being sent to the Internet. In our time this happens very quickly, but in computer time I just described a lifetime. In addition if your signal is not 100% you might have packet loss "more slow down". Now the answer, in your ap setup pages you can setup wireless security, set this to Mac address authenication and add the mac addresses of all the network cards that have access to this ap. This is by far the fastest methiod of secure data transfer.
Hope this was some help...
Tim
Mar 22, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Wireless connection of netgear wireless router for compaq laptop
Sometimes firewalls on your computers can cause connection issues. I had the same problem with my home network. I had norton internet security 2008 on both systems, but the firewall settings on both computers had to be adjusted to allow the computers to talk. If you have different brand firewalls on each computer, you should consider to switching one of the computers so that it matches the other.
Another thing you want to do is log into the router's web utility and check to see if the wireless settings are blocking wireless connections in some way. You also want to make sure the ssid broadcast is enabled.
Finally, you really should consider using security on your router, so wireless connections would be password protected. I suggest wpa personal.
May 03, 2008 | NetGear WGR614 Wireless Router
Slow Wireless Connection or even not Detected
problem a: could just be your isp is slow therefore when you share the connection it is slow when both pc are connected. Also it could be that your firmware on the router is outdated and creates problems for you. Try updating to the latest firmware go to www.dlink.com and select your router. In addition, i find with dlink if you use their software to control your wireless adapter you get better performance than if you use windows default software.
problem b. Youa re right wep security creates overhead due to encryption will always be slower than no encryption. If you are just worried about people stealing your internet access then i suggest you use unsecure connections but restrict access to the router by mac address. WEP can be hacked easily anyway.
problem c: use port forwarding for your torrent to increase speed. chances are your firewall and antivirus scans everything thus slowing down your connections.
good luck
smeags.
Jan 08, 2008 | D-Link AirPlus DI-524 Wireless Router
Linksys Wireless-G WRT54G Router Logo
110 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
