Question about Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum
Low Suction When I turn my vacuum on the filter sucks up against the top causing low suction and the water won't suck up. It has never done this before. Any suggestions?
  • 1,673 Answers
Re: Low Suction
Empty the recovery tank; it may be full
and the automatic shut-off engaged.
Make sure filter and filter lid are properly
Make sure tanks are locked in place.
Check the filter and clean if dirty.
Make sure nozzle is replaced properly
and locked
Posted on Jan 14, 2008
0 characters
3 Points
How do I reset the suction on a DC65 Dyson upright when it stops sucking?
Hi Gari, it's Jack at Dyson.
If you've noticed a change in the performance of your DC65, this is likely to be due to a blockage, and the filters may also need a wash. I'm confident that by following the steps shown into the videos below, you can remove any obstructions and restore full performance to your vacuum:
You may also want to give both filters a wash with cold water without detergent, if this hasn't been done recently. In normal use this should be done at least once every three months. Make sure both filters are completely dry before replacing them - this could take at least 24 hours:
If you'd like further help or advice after giving these steps a try, please call our experts directly on 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Nov 29, 2014 | Dyson DC65 Animal Bagless Upright Vacuum
Why won't it suck
Hey there! It's possible that you may still have a clog in your vacuum somewhere. The filters can also cause the vacuum to lose suction. Try these steps to restore suction to your cleaner.
1. Remove the dirt cup canister from the vacuum. Remove the dirt cup lid.
2. Remove the primary foam filter. Rinse the filter under running water until it runs clear. Allow 24 hours to air dry outside of the vacuum.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash) Filters should be replaced once a year.
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Remove the bottom plate and brushroll. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
6. Check that the brushes are still spinning. If not, replace the belt.
Hope this helps!
Jun 20, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
My dyson hose sucks good but, when i put handle down, it won't **** but brush does turn
I just had the same problem....suction from wand, but no suction from soleplate, the brush bar spins. Did all the troubleshooting steps on but they didn't says need to take to repairman, being a diyer I went to search engine. I didn't find a fix, however I found one appears the vac can get stuck in floor mode or in between modes....the dial on top on dc07 ....selector of floor or carpet..try pushing it back and forth to see if that puts it in carpet mode...check for suction or try vacuuming...if that doesn't work, looking at vac from behind vac on the right hand side is the selector dial..on top of bottom portion of vac.....with vac in upright position, recline it as if about to vacuumn floor...look down at selector area should be able to see a rectangular type button exposed ..push this to reset may have to push it a few times...then try vacuumniing.....I finally had suction from soleplate!! Another tipoff to this problem is my selector dial would not stay in place would pop I to carpet by itself, but only halfway....fro a long time my vac would work but not very well...had to go over same area.4-5 times..What a workout! The first time I contacted dyson via tele the rep had me remove some stuff and I was able to look at area below selector...what I saw was two holes, one hole was only over the other hole half way...hence at that time I had only part suction since holes were not aligning properly....I read somewhere as a further tip to get suction to engage, while vac is reclined step on front edge of vac head it said you'll get more suction that way, I haven't tried that, but thought it may help someone
Feb 16, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
No sucking
if you have no suction - then the problem could be a dirty filter or a blocked suction hose. clean the filter and check the hose from top to bottom for blockage. if all is clean and clear and you still dont have suction then the problem could be a bad vacume suction motor.
Feb 02, 2011 | Hoover U5175-900 Fold Away Bagless Upright...
It barely sucks, the suction is poor and the brushes don't spin at all.
If the brushes are not spining you might have something wraps around and stuck in it. like hair or sting. you might have to take the object where the brushes are apart to clean it out. Also check the belt, and if there is a filter make sure it is clean. Dirty filter can cause low suction.
Nov 30, 2009 | Electrolux Central Vacuum
Not sucking makeing a clogged noise
Bagless vacuums don't usually get clogged as easily as standard bag styles do. However, if you can disconnect the top half from the brush head section you should see a "neck" where the two meet, check there for a clog. Also check your filters, this is where loss of suction happens most. Dirty filters = Low Suction. I hope this helps
Jan 19, 2009 | Fantom Vacums Fantom Wildcat 2100 Upright...
Vaccum has no suction
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
It sounds fine but it is sucking very little
If the suction at the port that the hose hooks into has low suction, then most likely you have a problem with the motor. Some of these Rainbow motors sound ok running, but are running at a slower speed, thus reducing the suction and replacing the motor is the solution.
Dec 24, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Filter sucks against top creating low suction
See my post with the same problem (described in painful detail) at:
I've no idea why this should happen all of a sudden. But it has. And so far nobody is suggesting anything.
Apr 30, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum Logo
186 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
