My ipaq h1940 have a virus and it make my ipaq to record continually. please hepl me
SOURCE: Hard Reset HP 6515
Hold down the POWER button and press the reset hole for approx 5 seconds, then remove stylus from reset hole first, follow by release of POWER button.
SOURCE: Hard Reset
On the front pannel you have the 4 buttons and the central navigation key. Press simultaneous the first and the last of this buttons (1 and 4) and then with your stylus (while keeping these buttons pushed) press the soft reset button (bottom of the device, a small hole). Keep these pressed alltogether for 4-5 sec then release them and do a soft reset. Your PDA should now be in factory settings. If not, try again. It will work.
SOURCE: HP iPAQ HX 2495b cuts off and on
1) Presione y sostenga el botón de la Agenda, el botón de arranque, y el botón de mensajería.
2) Mientras mantiene estos botones, utilizar el lápiz óptico para presionar ligeramente el botón de reinicio en la parte inferior de la HP iPAQ.
3) Cuando la pantalla de Pocket PC empiece a desaparecer, la liberación de todos los botones, y luego quitar el lápiz desde el botón de reinicio.
El HP iPAQ se reinicia y facultades sobre
SOURCE: HP iPAQ hard reset
Scroll down on this page to find the ipaq 5000 series:
http://www.pocketpcaddict.com/forums/pocket-pc-tips/14964-how-hard-reset-your-pocket-pc.html
(H5450 and H5455 are the same ipaq)
SOURCE: How do i do a hard reset on HP ipaq X11-21204?
u have given a wrong Model number this is not a model number infact a part number pls try to find the correct model number from HP site thru photo identification if u dont find ur model other wise i am providing u detail below to try the hard reset on various series of HP IPAQS kindly be sure that ur ALL DATA WILL BE ERASED pls rate me FIXYA if i fixed ur problem
How to Perform a Hard Reset on an HP iPAQ
Performing a hard reset on an HP iPAQ is relatively easy, but is a dramatic step in the management of your handheld organizer. A hard reset will completely clear the memory of your device and restore it to the state you received it in from the factory. A soft reset, on the other hand, simply closes running programs and restarts your pocket PC.
Instructions
Difficulty: Moderately Easy
Step1
Read the owner’s manual. If you don’t have to do a hard reset, you shouldn’t, and you definitely don’t want to do one by accident. So familiarize yourself with the hard reset protocol offered in the manual.
Step2
Make sure you want to clear all personal settings, saved data and personal files from your PDA. If there are files you wish to retain, save them to a removable disk, or send them to your computer’s hard drive to be retrieved at a later date before performing a hard reset.
Step3
For the HP iPAQ h1900 series, hold down the power button while you use your stylus to hold down the reset button (on the left side of the iPAQ). Hold these buttons for a few seconds until the screen fades to black.
Step4
For the HP iPAQ h2000 Series, press down on the far left and right buttons (calendar and iTask, respectively). While you do this, press and hold the reset button on the back of the iPAQ until the screen fades.
Step5
For the HP iPAQ h5000 Series and H3800 Series, the procedure is the same as the h2000 Series with the only difference being on some models the Today button is used instead of the iTask button.
Step6
For the hw6500 Mobile Messenger Series and hx2000 Series the procedure for the hard reset is precisely the same as for the devices in step 4.
Step7
For the rx3115 and rx3715 models, hold down the Mobile Media button (on the far left) and the iTask button. Then press down the reset button with the styles for a few seconds until the screen goes dark.
Step8
For the rz1710 and rz1715, follow the same procedure as the devices in step 7, with the difference of pressing the Today button (on the far right) instead of the iTask button.
Step9
To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Tips & Warnings
* If you’re iPAQ is simply slowing down or having problems, try a soft reset (reboot) before resorting to a hard reset.
* Read your iPAQ’s instruction manual to familiarize yourself with how to do a hard reset, and the effects of performing one.
* Do not perform a hard reset unless you are okay with or intend to erase all non-factory installed data and settings from your HP iPAQ.
Select the "Bluetooth" icon from the Today screen of your iPAQ h1940. Click on "Bluetooth Settings." Touch the "Turn on" button.
Select the "Accessibility" tab from the Bluetooth menu and select "Allow other devices to connect" and "All devices." Click "OK."
Click on the Bluetooth icon in the upper right-hand corner of your Mac. Click "Turn Bluetooth On."
Select "Set up Bluetooth Device" from the Bluetooth menu and click "Continue." Select "Any Device" and click "Continue."
Select your iPAQ h1940 from the list of devices and click "Continue." Input the passkey number from your Mac into your iPAQ.
Select the type of syncs you want with your iPAQ and Mac and click "Continue."
Select "Browse Device" from the Bluetooth menu on your Mac and select the iPAQ from the list. Click "Browse."
Add or remove files from your iPAQ h1940 by clicking on them and dragging them into a file on your iPAQ or on your Mac. Close the window when you are finished and select "Turn Bluetooth off" from the Bluetooth menu.
Click "Turn off" on the Bluetooth icon on your iPAQ h1940.
