Question about JVC BR-S822DXU VHS/S-VHS playback VCR
Any idea how to setup and allign the internal switches of tbc boards in br-s822
I have the br-s822e with all tbc and dnr boards installed any idea about the internal switches inside the tbc boards and the video lum. board and the other boards how to setup them all and make the allignment for the video because i don't have the manual please try to help
    Champion:
  • 221 Answers
JVC still hass the manual for this machine; call them and ask to buy one.
Posted on Jun 27, 2007
  • Barry8Track Nov 04, 2010
    The VCR manual won't tell you anything about the TBC, and I haven't been able to find anything either. What you want is the manual for JVC model # SA-T22E, the TBC option. Good luck. I have all the BR-S822 instruction and service manuals, but they are no help on the TBC since that was a separate option. I would tell you how mine are set, but it won't help because most stuff on this machine is software-controlled, where you set one control and the processor remembers it, then you may set the same control later for another parameter.
I installed a new main board in my lg 65eg9600,after install the power button and button on TV don't work...do I need a service remote for first time setup?
Update for your tv SHOULD be available here:
http://www.lg.com/us/support-product/lg-65EG9600
After being sure your cables are all attached SECURELY and correctly buttons should work.. IF not sounds like you received a defective Main Board
I’m happy to help further over the phone at https://www.6ya.com/expert/mike_316638c836088218
Mar 30, 2018 | LG Televison & Video
Tip
How to Install any Driver/Software which isn't Supported by Windows Vista/7
Hello!!
There are lots of old Soft-wares and Drivers available which are not compatible with Higher Version of Windwos.
So some Windows XP exclusive setups can be installed under Windows Vista/7 As Under.
1. Try to install the drivers in compatibility mode.
2. For that right click on setup.
3. Go to properties.
4. Go to compatibility Tab.
5. Set it to win xp sp2.
6. Hit ok
7. Run setup as administrator
8. Ignore any error and hit continue anyway during installation
9. Restart pc
If the above trick doesn't work, then use the device in VIRTUAL XP MACHINE
You can use XP MODE or VMWARE or any other Virtal Machine Application.
Hope it Helps..!!
on Jul 13, 2011 | Computers & Internet
Sony bravia kdl-40w600b..turns off after switching on..and the red light indicates 8 time..whats the issue..and need to resolve
8 red flashes- main board sp prot, try power reset, update with usb, or replace main logic board
How to service fix phones tablets PCs TVs and tech reviews blog by Tampatec
Factory reset:
https://us.en.kb.sony.com/app/answers/detail/a_id/43126/c/65,66/kw/factory%20reset/session/L3RpbWUvM...
First I unplugged my HDMI cable and powered OFF my router (using wireless).
As soon as HDMI 1 showed on screen, pressed the arrow up button on remote, touched the power button on left rear side (uppermost) button on my TV) and let go of arrow up. TV said RESET and after a min, TV went back to setup screen. Followed Setup onscreen instructions and working OK.
May 11, 2016 | Sony Televison & Video
What is the default ip address for hp 2510-24 j9019B switch ?
Switches don't have an address, think of them more like a traffic intersection with 24 roads.
When you plug a device into the switch, that device gets assigned an ip address.
For example:
  1. Phone line comes in to your house and stops at your modem, your modem is plugged into the switch. The modem picks up the private network address 192.168.0.0
  2. Your computer is plugged into the switch. It picks up ip 192.168.0.1
  3. Your friends computer is plugged into the switch. It picks up ip 192.168.0.2
This carries on until you have filled all the sockets on the switch.
The ip's here are only on your personal network, to find what your external ip (your modem -> internet) is just type 'whats my ip' in the google search and it will show you your public ip address.
Nov 24, 2015 | HEWLETT-PACKARD Hewlett Packard HP...
Truck displaying "TBC FAULT" while driving. What
It may possibly store DTCs. If not.. PINPOINT TEST H: THE INSTRUMENT CLUSTER DISPLAYS "TBC FAULT"
Test Step Result / Action to Take
H1 CHECK FOR THE PRESENCE OF A TRAILER BRAKE CONTROL (TBC) MODULE AND BRAKE PRESSURE TRANSDUCER
Verify that the vehicle is equipped with a TBC module in the instrument panel and a brake pressure transducer on the master cylinder.
Is the vehicle equipped with a TBC module and a brake pressure transducer?
Yes
GO to H2.
No
If the vehicle has a brake pressure transducer but not a TBC module, INSTALL a TBC module. CLEAR the DTCs. REPEAT the self-test.
- If the vehicle has a TBC module but does not have a brake pressure transducer, GO to H4 .
- If the vehicle has neither a TBC module nor a brake pressure transducer, GO to H3 .
H2 CHECK TBC MODULE COMMUNICATIONS
Using the scan tool, access the TBC module. Does the scan tool communicate with the TBC module?
Yes
VERIFY that the instrument cluster is configured correctly, RECONFIGURE as necessary. REFER to Programmable Parameters in this section.
No
Go To Pinpoint Test a.
H3 CHECK THE VEHICLE BUILD INFORMATION
Verify that the vehicle is supposed to be equipped with a TBC module.
Is the vehicle supposed to be equipped with a TBC module?
Yes
INSTALL a trailer brake retrofit kit. CLEAR the DTCs. REPEAT the self-test.
No
H4 CHECK THE VEHICLE BUILD INFORMATION
Yes
INSTALL a brake pressure transducer. Make sure to LUBRICATE the O-ring seal with clean, specified brake fluid before installation. RECONFIGURE the instrument cluster for trailer brakes, REFER to Programmable Parameters in this section. CLEAR the DTCs. REPEAT the self-test.
No
REMOVE the TBC module and install the storage bin.
Hope this helps; keep us updated.
Jan 17, 2011 | 2007 Ford Super Duty King Ranch
HDMI input stopped working
The problem is the main board in your TV. If your TV is a LG or SONY brand, please try this:
Re-Flow Soldering Procedure for LG Main Board
1.Pre-heat your kitchen oven to 385 degree (No more than 400 degree);
2.Put the main board on a card board (like a pizza box board) in the oven;
3.Heat it for 10 minutes (No more than 10 minutes);
4.Turn the oven off & leave the door open, at this moment, do not touch or move the board until it colds down to the room temperature.
5.Install the board in the TV & try it out.
Aug 22, 2017 | Sony KDF-E55A20 55 in. LCD Television
Seems like TBC won't lock, blue cast, picture unstable, weird colors, no contrast
change in stability after warm-up is a sign of defective capacitors. the DS550 and DS850 both are notorious for capacitor failures. don't touch the trim pots unless you have a service manual and a wfm/vectorscope.
Nov 07, 2008 | Panasonic AG-DS555 S-VHS VCR
No colour at playback when tbe switch is on
The DNR boards for these machines can go bad and produce a black and white picture. Try swapping the DNR board.
Apr 30, 2007 | JVC BR-S822DXU VHS/S-VHS playback VCR
Mother board liquid spill
Here is the link to one Toshiba parts supply house that actually carries your system board: http://www.sparepartswarehouse.com/Toshiba,Laptop,Parts.aspx Good luck and please don't forget to rate the posting.
Jan 03, 2007 | Toshiba Satellite R15-S822 Tablet PC
JVC BR-S822DXU VHS/S-VHS playback VCR Logo
332 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
