Question about Kalinka MB-3 Kronos Night Vision Waterproof Monocular Spotting Scope
1993, 940 volvo will not start.
Owner said he just parked and when he returned his 1993, 940 volvo will not start. checks made timing belt, fuel injector and internal and external pumps, distributor, rotor, air sensor. can malfunctionig computer cause this?
My 94/ 940 had the same problem turned out to be worn out crank-shaft sensor.. generic cost$115 for part .Canadian tire charged me $400 for job.would have been much cheaper had i checked forums first good luck
Posted on Apr 04, 2009
2008 Chevy cobalt 2.2 l 133,324 miles. It just started to hesitate to start and smells like raw gas. What could it be?
Hi Jesse, IM AL the owner of Big As Auto Repair.
Jesse, if you are smelling "Raw Gas" then this is a sign of a gas leak or an injector stuck open flooding the system.
Start the engine and check for fuel leaking from the injectors sometimes and injector will leak externally. Also check for fuel leaks around the fuel line and fuel rail, also check under the vehicle, the fuel lie, tank, filler tube. The Internal Injector leak can only be checked after removal of the fuel rail (engine off). With the fuel rail in your hand have someone turn the key on (engine off) it should be a spray like pattern from each injector and no drips after the spray. NOTE: This should be checked only after there were no other issues found with the first issues I talked about. Hope this helps and please visit my auto-repair-website http://www.bigasautorepair.com/
Feb 06, 2017 | Cars & Trucks
No spark 1999 volvo s 80 but has fire to inj..but wont spray
what have you actually got
no spark is from cam/crank position sensors faulty, faulty ignition control module
but you say fire to injectors -- do you mean power to injectors
if you have power but the injectors are not squirting---low /no fuel pressure = faulty fuel pump / no power to pump , faulty pressure regulator , pump relay problem
At this point check for a broken timing belt/ chain
Aug 13, 2016 | Volvo Cars & Trucks
Volvo 960
There are three things needed for an engine to run:
  • Fuel
  • Spark
  • Air (Compression)
If the car shut down suddenly without prior warning, and if the engine cranks over very fast (seemingly faster than normal), then my first guess would be a broken timing belt. This is bad because not only did you lose compression because the timing belt keeps the valves in sync with the pistons, that very fact means that the breaking of the belt most likely did internal damage to the engine in the form of bent valves. The very first thing you should do is to pull the plugs and do a compression check of the engine. If the cylinders are not all at the same level of pressure (within reason), or there is little or no compression in one or more cylinders, then the timing belt is gone. If compression is good, then the issue is either spark or fuel. Ensure spark is available by using a pair of insulated pliers to pull off one of the plug wires and hold it near the engine block. Crank the engine and watch for spark from the wire to the block. If there, you have spark. If not you must troubleshoot the cause. Fuel can be easiest or hardest to determine. Most vehicles have electric fuel pumps. Most have a "prime" function that occurs when first turning the key to the ON position. This allows the pump to bring the fuel rail to pressure for the injectors. Without starting the engine, turn the key to "ON" listen for a 3-5 second humming noise. This would be the fuel pump priming the fuel system. If you hear this you should have fuel to the rail. If you don't check the rail for fuel availability,.
Aug 23, 2014 | 1996 Volvo 960
Hilux fuel return
I think the in-tank fuel screen(the "sock") has come off.This screen allows the pump to **** up the last bit of fuel in the tank.To verify,see if it does it with a full tank.You can either carry a 5 gallon gas can,or just fill it up all the way and try parking in a known uphill spot that causes the condition.If this isn't it,then youv'e got me as to what it is.
Sep 01, 2012 | Cars & Trucks
My 1995 Volvo 850 will not start. I think it is the fuel pump. I tryed a procedure where I removed the fuel pump relay and jumpered the sockets for blades 85 and 15. there was no help in starting the car...
another way to test it
unplug any fuel line you can locate tell a friend to start key one turn only if the line squirts fuel then pump is working and it might need regulator
if not then pump is gone
Jun 08, 2011 | 1995 Volvo 850
1984 Volvo will not start - I have spark and fuel to the cylinders. It just cranks and cranks and floods the cylinders. I am a bit of a "back yard mechanic" and have tried everything I can think...
you probably have weak spark or it is flooding due to too high fuel pressure. is the timing good the firing order correct has the cam belt timing slipped, missing teeth. is the cold start injector open all the time.
Dec 19, 2010 | 1984 Volvo 240 Series
Volvo 850 2.0 1995 non starting already fitted new plugs leads cap roter arm cam and crank sencors good spark good fuel presure and no imobliser light on plugs all dry when turning over engine
try spraying some easy start into the air intake while someone operates the starter if it trys to start you have a fuel system fault have you checked fuel pressure at injector rail you need to do this using gauge and check against volvo spec if low it will never run if ok check feeds to injectors using multimeter if no feed check relevent fuses if ok using multimeter check continuety of injector wireing back to ecu if it did not try to start using easy start check timing belt is ok and engine has compression
Jan 02, 2010 | 1995 Volvo 850
Volvo 240 GL Wagon, 1986
Seek good repair shop, too many possibly problem, Sometimes that's the best money spent.ask for a one hour diagnostic check.
Sep 25, 2009 | 1992 Volvo 240
1995 buick park ave bucks/shakes
have you checked the coil packs
Apr 29, 2009 | 1995 Buick Park Avenue
Volvo 240 2.3L FI the engine has spark, no injector pluse.
is there air in the fuel rail? bleed air bubble out
Mar 15, 2009 | 1989 Volvo 760
Optics Logo
155 people viewed this question
Top Kalinka Optics Experts
james laughton
james laughton
ray gallant
Are you a Kalinka Optic Expert? Answer questions, earn points and help others
