Question about JVC BR-S822DXU VHS/S-VHS playback VCR
No colour at playback when tbe switch is on
I have jvc br-s822e pal with tbc and dnr boards installed , when i playback and switch the tbc to on it becomes black and white playback while that if you press any of the inserts (audio or video or assemble) it becomes clolourfull but as if the tbc is off because i notice that the dnr filter is off because the picture returnes normal without noise reduction ,as aconclusion the tbc switch when is on the dnr works but the picture becomes b&w any idea about the fault
Check your SYNC in or remove all input Cables while in Playback mode.Try to switch the sync mode on Internal sysnc.There couldent be an error in the DNR board, this never fails !
Posted on Apr 14, 2008
Theres a fault in your wireing or Sync. System. Remove all inputs from the Deck and try it oncemore! The TBC had to be syncronised with your Video Source.(in sync)
If the deck is in Record mode (assembe,insert) switch of the TBC !
Daniel from germany
Posted on Apr 09, 2008
    Champion:
  • 221 Answers
The DNR boards for these machines can go bad and produce a black and white picture. Try swapping the DNR board.
Posted on Jun 27, 2007
  • Don Roth Jan 06, 2009
    defective TBC1 board will cause loss of color in playback - just repaired one this morning.
SOURCE:
My Disney lightning McQueen tv wont play dvds in color. The cable plays in color just fine. I think my son changed the settings some how, I've went through the book front to back and the setting...
go to settings for playback/ video and check to see if it is NTSC or pal.whatever it is switch it to the othe and the colour display should then be correct.europe is pal. America is NTSC.
Oct 27, 2014 | Disney CARS 14 TV/DVD Combo
I own a Panasonic 3ccd nvgs mini dv i was shooting some footage...tape got horizontal lines on it... i really really need that tape... can it be fixed?...thx a milion
Sounds like dirty heads .
If the lines are recorded onto the tape, probaly not.
Try a head cleaning tape in the camera or use another playback device.
If the lines are recorded onto the tape then track down someone with a TBC (timebase corrector) and pipe the signal through that and record to another tape.
Apr 13, 2011 | Panasonic NVGS-200 DV Camcorder 3 CCD 2.32...
Navigation starts in black/white, where are the colours??
try switching your tv to pal instead of nstc you can do this in the remote menu .
Dec 07, 2010 | JVC DRMH20 DVD Recorder
No Colour
PAL chroma operates at 4.43 mhz and NTSC operates at 3.58 mhz. Here is a link to PAL to NTSC convertors.
http://www.world-import.com/samar.htm
Dec 31, 2007 | JVC HD-52Z575 52" Rear Projection...
JVC HD-52Z575 52 inch Cannot get a colour pic only black & white
Your HD-52Z575 will only be able to display an NTSC signal, PAL is not compatable. There is nothing that can be done to make it play a PAL signal.
Dec 18, 2007 | JVC HD-52Z575 52" Rear Projection...
E03
my jvc gr-DVX MINIDV PAL KEEPS GETTING ERROR CODE EO3 PLEASE HELP
Dec 04, 2007 | JVC GR-DVL20EG Mini DV Digital Camcorder
Any idea how to setup and allign the internal switches of tbc boards in br-s822
JVC still hass the manual for this machine; call them and ask to buy one.
Apr 30, 2007 | JVC BR-S822DXU VHS/S-VHS playback VCR
No chroma on playback
Bad heads may produce a loss of color in playback. If you have a spare head, swap it out and confirm this.
Nov 15, 2006 | JVC BR-S822DXU VHS/S-VHS playback VCR
Noise block doring playback of D-VHS tapes
* Do not record program in DVHS mode on an S-VHS cassette. Use of S-VHS cassettes will not allow for maximum performance and may result in head clogging. Use only D-VHS cassettes as recommended in the instruction manual on page 27. * Make sure that the DIGITAL 3-DNR lamp is ON when playing back a cassette recorded in D-VHS mode. If not press DIGITAL 3-DNR so that the DIGITAL 3-DNR indicator illuminates. * When block noise appears on the TV screen, clean the video heads with the DFC-2 D-VHS Head Cleaning Cassette (continue up to 3 minutes total). Please refrain from using any other head cleaning cassettes as drum damage may result.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
JVC BR-S822DXU VHS/S-VHS playback VCR Logo
312 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
