Question about Samsung HCM4215W 42" Rear Projection Television
Distored red picture
The red picture is distored like a pincushion on up left conner. The green and blue look ok so far. Auto adjust do not work. Tried to adjust convergence manually (I bought a service manual). Is it the ICs on convergence amp and how do I know? They are two stk392-010. where do I get them and what is the proper process to replace them?
  • 71 Answers
Sometimes a nearby speaker or cassette recorder or an old telephone may affect it, because of its magnetism power ,take away any nearby stuff and try manual reconvergence after a short power off for a reset ,
Posted on Apr 30, 2007
  • Mohamad Abdan
    Mohamad Abdan May 07, 2007
    hi ,
    you rated my help as a poor also i was here to help ,
    it is quiet clear that you have a bad convergenz due to magnetic field effect ,
    the stk's are not the fault don't even try to resolder , that kind of ic loose its function for extra heat
    please try to change your rate it is my only poor rate got byyou!!
    regards
    regards
  • Mohamad Abdan
    Mohamad Abdan May 09, 2007
    thanx sir for reactiong about the bad solution strick
    regards
I have a Sony KDP-57WS550 TV that has a convergence problem. Based on the symptoms, I'm not sure whether to indict the convergence ICs. In the convergence mode, I can move the red (and blue) crosses,...
With your TV in setup Use a small magnet to "move" the non converged Red, Blue, or, Green color lines "crosses" (each CRT will need to be adjusted in turn) by moving the magnet close to the offending Red, Blue or,Green color CRT yoke or, tube while observing the movement of the CRT color line "cross" in a mirror ( try several places near the tube and, several strengths of magnets:) a refrigerator sheet magnet works well (you can cut these with a scissors to make a better fit or, apply less magnetic "pull." by making them smaller (you may need more than one magnet per tube to fix each CRT's convergence) When you have each CRT tube's convergence right, apply some clear silicone adhesive to the magnet and, permanently affix the magnet to the now "fixed" CRT tube exactly where you placed the magnet to obtain the best convergence on the CRT.
(Do not adjust the "Green" CRT unless you must, as it is used as the color line to adjust other lines to)
Jun 30, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
My picture has far too much red in it. Where do I
there should be 5 or 6 preset on the crt(tube) base 3 of them should adjust red /green blue in the white aera and the other 3 adjust re/ green /blue in the dark aera make these adjustment with the colour turned off.
Sad to say that this is most likley a low crt the blue gun as gone low.
Mar 06, 2010 | Orion1934 19" TV
I have the opposite of a convergence problem. green pincushion cannot adjust so green is higher on left and right than center (bow tie). BUT red & blue will adjust and proprerly converge over the...
makenamicro, there is still a convergence yoke the green crt which means there is still a drive control circuit that controls your dynamic and static convergence. If you are working with out a service manual it is still possible that one of the convergence power amps is out, since you mentioned that you can adjust the red and blue to conform to the green pattern then try to adjust the green with out the R/B present if you ca not still adjust you green pincushion problem then suspect one of the power conv amps or a defective green conv yoke.(don't forget to check the small value resistors usually around 2 ohm and the pico fuses if the tv uses them. good luck and i hope i answered your questions, please let this web site know if yes by leaving some pos feedback. thanks!
Aug 22, 2009 | Sony Televison & Video
Hitachi 50gx30B Pincushion problem
Please let me know in which direction the picture is distorted. Does it bow in from the top and bottom or left and right?
Thanks,
Dan
Mar 06, 2009 | Hitachi 50GX30B 50". Rear Projection...
Mitsubishi 1080, Model #WS-B55
I need one for all universal codes for mitsubishi.
Jan 09, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergence problem
You need to replace both convergence ICs number STK392-110 youcan get replacements at the following link and they provide free installation instructions with pictures so you can do the job yourself . heres the link.
http://servicemanuals.vstore.ca/
May 04, 2008 | Toshiba TZ50V51 50" Rear Projection...
Colors are off after auto adjust
I seem to have found the solution (and the cause, perhaps?) for this problem!
I was having the EXACT same problem with a monitor I'm repairing for a friend. The capacitors on the power supply board were blown (CapXon capacitors, who'd've guessed), which was keeping it from powering up. After replacing the capacitors, the screen worked beautifully. But it had this weird yellow tint!
The strange part was that pure colors - red, green, blue - all appeared perfectly OK on screen. Curiously, the menus would show in the proper colors, except for one: the manual color adjustment menu, which illustrated "Blue" as a sort of off-green in the icon. Auto-Adjust would always fix the colors for a split second, then go back to yellow. Reset didn't fix it. Color reset didn't either. So, exactly the same problem as above.
The solution I found was hidden within the main menu itself, a sort of "easter egg". <b>Hold the Menu button down while pressing Power, and hold it down until the screen, and menu, appear</b>. There will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. Voila! PERFECT COLOR! Perhaps this menu was accessed by accident, and calibrated to an incorrect color key. But now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Hope this helps some people, it sure saved my ****! ;)
Dec 05, 2007 | AOpen 19" LCD
Red picture distorted
The complete convergence board AA95-02002A is avaiable through PTS electronics. You can call them at 1-800-844-7871. By the time you buy the right ICs for this unit, replace, them, it will cost you almost as much as another board. Samsung does not ave this board available any more. you can buy cheap replacement ICsl for about 20 bucks, but that would be a big mistake. Good Luck
Jun 09, 2007 | Samsung HCM4215W 42" Rear Projection...
Pincushion Picture on a big TV screen!!!
The set has 3 IC's(one for each color)strictly dedicated for the aligment of each color,if one them does not align is because is going bad or is already bad becuase picture can not be adjusted,the IC's can be identify because they are mounted on a heat sink and have the markings STK--- ---,they are all the same and need to be replaced with an exact replacement.If you are familiar with tv service you can replace them,sometimes the new ones need to be aligned from the service menu,you will need the service manual,soldering and unsoldering will be involved,If you are not too familiar be safe and seek the assistance of a servicer.
Nov 03, 2006 | Sony KP-46WT500 46" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
41 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
