Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
Analog mode unfunctional
Analog output from my SB Live!5.1 doesn't work. Digital output does work but only the right hand speaker. In 5.1 mode test, both speakers do work, but the left speaker takes the place of middle speaker.
These tests prove that the speakers are OK, but sound card is faulty. Could I have burned the sounds card in removing and and putting back the speaker connector to the sound card output, while power was on in the speakers? The problem started after I had done that - the sound was fine before that. If that is th eproblem, what should I do to fix it?
  • 1,472 Answers
Dear kaarlo125
In regards to your card not working in analog mode the card can only do analog or digital not both. So for analog to work you will need to turn off the digital mode. You should be able to do this in the Audio HQ. There should be a check box that you will need to uncheck. However it is been awhile since I had my Live card working so I am not directly sure where it is at but if you have trouble finding it let me know and i can set the card up on my test system.
As for the speaker test there is not a real test for digital speakers because the audio is a compressed signal. Now there has been AC3 files rigged to work like a speaker test but this was not avalible with the Live card.
Let me know if you still have trouble. If you do I will need some more info:
Make and Model of your speakers.
Model of the Live Card (Also did the card come with your computer.) The link below will show you how to find the model number on the Live card.
http://support.creative.com/kb/showarticle.aspx?sid=46261
Issken
Posted on Jan 04, 2009
Can I hook up this receiver to a Panasonic Viera tv tc-L32C3
U need to get a digital to analog converter for the tv digital outputs on "tv mode." Connect the analog outputs to the audio input of receiver. I had same hassle with my Viera till I got another receiver that would take direct digital input - no more need for converter.
May 14, 2014 | Pioneer VSX-D458 Receiver
Yamaha rx-v2500 receiver how to hook up speakers
HI,
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. blank.gif
Oct 06, 2008 | Yamaha RX-V659 Receiver
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
I want to have digital stereo playback from my sony cd player. I receive analog only and want full stereo sound. The receiver is a harman kardon 3390z and the cd player is a sony 5 disc with analog red and...
This receiver has NO digital capabilities.
If your unknown model CD player only has analog red and white outputs then IT has no digital output capabilities but it DOES have full stereo sound.
Feb 08, 2011 | Sony Audio Players & Recorders
Trying to connect BA735 speakers to a MacBook? No sound? Are they compatible?
Those speakers were originally supplied with Gateway computer system that had sound cards with digital outputs. While some versions had analog and digital sound inputs, most often the speakers had digital input only. The on-board sound in the eMachines is analog output only, so the speakers are most likely not compatible with your computer. If you want to use those speakers, you will need to locate a PCI sound card with digital output.
It's a matter of the output from the computer's sound card (built-in) being incompatible with the speaker input. The card is sending out analog sound wile the speakers are expecting digital input. Downloading a driver won't help because that doesn't fix the root problem. You need to get speakers designed for analog input, or a sound card with digital output. As it stands now, your computer just can't use those speakers.
Since your using a MacBook there is no option for this Pci Digital Sound Card.
Feb 03, 2011 | Boston Acoustics BA735 Computer Speakers
Denon avr 3805 2 zone configuration, I added optical sound from TIVO and now zone 2 is not working. I did the test of the speakers and they all work. I have configured the main for 5 channel stereo.
Zone 2 needs an analog input to work, if you pulled the analog from tivo, put it back on. Digital will not pass on zone 2. If your analog is still connected as well, go into your receivers settings for audio and select "auto" not "digital" Check the settings on tivo as well. make sure it's audio output is set to "auto" if available. If it's not, it's default is "auto" and will output simeltaneously on all outputs. Hope this helps. If you need more help, post a comment and I will help some more.
Jul 05, 2009 | Denon AVR 3808Ci Receiver
BA735 no sound but sound card works in analog mode.
this should be pretty easy to diagnose. both speakers have mini jacks right? if so, and you plug one pair of speakers in on say, port "A" and you get sound then if you plug your other speakers in on port "A" and you don't get any sound, the problem is with your speakers.
Oct 19, 2008 | Boston Acoustics BA735 Computer Speakers
No sound. Sound card or speaker failure??
These speakers only accept digital input in form of 3.5mm mini-din digital out from your source.
Nov 09, 2017 | Boston Acoustics BA735 Computer Speakers
Daylight Saving Time will not set correctly
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 08, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Jan 22, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
89 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
