Question about GE DBXR463EBWW Electric Dryer
GE Dryer model DBXR463EDIWW
Clothes take a long time to dry. Outside of Dryer gets very hot but it takes forever for clothes to dry. I cleared all the lint from the dryer in the front and took dryer out and cleaned back of dryer as well as vent. Still it takes so long for clothes to dry. Any ideas?
  • 3 more comments
  • dragon2900 Dec 31, 2008
  • Anonymous Feb 21, 2009
    We are having the same problem cleaned vent line all the way through to the exterior??? Priced a heating unit at $158.00
    don't know if that is the problem? This dryer is only a couple of years old, but don't wnat to put a lot of money in it
  • Anonymous Mar 01, 2009
    Dryer gets hot on the outside to touch but clothes take 4ever
    to dry
  • Anonymous Mar 17, 2009
    I have the same problem. The dryer is a couple months old and the outside gets really hot but it take three cycles to dry the clothes.
  • Anonymous Apr 25, 2009
    cloths take at least 2 cycles to dry them
    Problem Solver:
  • 13 Answers
If there is no lint blocking the air outlet path, I would next check two things: First, is the dryer in a small, closed room? If there is not enough space for air to get in to the dryer, it won't have good airflow through the clothes. Second, for older dryers, the blower fan may be loose on its shaft or, if the blower has its own separate motor, the blower motor might be dead. In order to find the blower fan, you'll have to be able to open up the dryer. Once you find the fan, see if it turns easily without moving the motor shaft -- if so, you need to replace the fan. Also, be sure there isn't anything blocking the blades of the fan.
Posted on Jun 14, 2009
Takes to long to dry clothes
after checking and replacing the vent going outside still the air was not venting and inside my drier everything was wet although the air was hot. After removing the rear panel i saw the blower belt disconnected. it took me some time to get the belt on but everything is ok and the air is venting and clothes getting dried. Also note that the little pulley came off its positio too.
Feb 14, 2013 | Whirlpool Dryers
My dryer heats up but does not dry clothes. I check ventilation and lint trap, there is no buildup. what could cause it to take forever to dry clothes?
If the drum gets hot to a real degree it has to be a blockage between the drum to where the air exits the home.
They do make a brush designed to go into the area where the lint trap is and be long enough to come out the rear of the unit---A lot of places will come out and professionally clean from trap to vent outlet
A blockage can be dangerous as hundreds of fires happen each year from the lint catching fire in the dryer.
The tube to the outside may seem clear but if blockage anywhere from lint trap to it, that will cause this problem and present a possible fire hazard.
Its not unlike having your vac not pick things up very well...except there is rarely a fire with that.
Dec 16, 2012 | Kenmore Dryers
Dryer putting out hot air but clothes not drying
You have some blockage between lint trap and where the unit vents outside.
Dec 16, 2012 | Kenmore Dryer Sears Elite
Heating elements are lit up working normal, drum hot but not inside of drum. it takes forever to dry clothes. vent wide open no clogging inside. need help ?
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 04, 2011 | Whirlpool LER5636P Electric Dryer
The clothes take forever to dry. Even with the more Dry cycle the clothes are wet after 40+ minutes The timing changes from 40 minutes then to one hour+.....
Nov 23, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer gets hot but takes along time to dry
Make sure the lint filter is clean. If it is make sure the hoses leading from the dryer to the outside are not clogged. It sounds like it is not getting prober airflow through the tub.
Jun 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer gets clothes hot, but forever to dry them.
I have exactly the same problem. My unit is 2 years old and has suffered this same problem since the day I bought it.
May 14, 2010 | GE Spacemaker Washer and Dryer Electric...
Dryer is taking forever to dry clothes.
you better not use the dryer again until you can clean the entire vent system-----not just the lint filter , but the back of the dryer and the complete exhaust duct all the way to the outside. It is probably plugged. Also check to make sure nothing is blocking the air intake. I know a co worker who had a house fire due to a blocked vent. After the vent is clear, make sure you can feel a good stream of air coming out at the outsde of the vent.
Jun 25, 2009 | GE DBSR453EBWW Electric Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
My dyer will not dry the clothes
First unplug your dryer from the electrical outlet. Next pull your dryer out from the wall. DIsconnect your flex outlet hose from the dryer and make sure it is not stopped up with lint etc. Next check the wall adapter to make sure it is clear of lint etc going to the outside of the house. If both of these are clear look inside the dryer outlet by looking in the tube where the flex hose was connected. You will need a flashligt to do this. If there is anything stopping it up remove it. If your dryer is getting hot but not drying there is probably something keeping the air from going out of the dryer to the outdoors.
Apr 01, 2009 | Whirlpool LER5636P Electric Dryer
GE DBXR463EBWW Electric Dryer Logo
300 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
