posted by Amna91 on Apr 30, 2007
Hi.
When I start my laptop it goes up to the Windows thing n then after it says it dumping the memory or sumthing.. Then it starts over and keeps on doing that..
It wont get to the part about logging in.. It just starts over n wont stop. I dont know what to do. It says sumthing about hibernating.. I even put the battery and its working but it wont start properly.
Comment by Amna91, posted on May 01, 2007
How do I change the memory?
Best Solution
posted on Apr 30, 2007
It sounds like you may have a faulty memory on the laptop...try changing the laptop memory...blue screen normally occurs because of a faulty hardware device..
Comment by bapplay, posted on May 01, 2007
take a look at the bottom of the laptop there should be some small doors like area with a single screw...you will need to get a screw driver (philips) and open that area...
in there should be a flat green chip that can be romoved..thats your memory...u will then need to get the exact replacement like that ..
http://www.daileyint.com/hmdpc/upgrade.h...
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for NEC Versa LXi PC Notebook
Email this problem
Email this problem
Can you Help with these PC Laptops problems?
Repair Service
Find PC Laptop Repairman Near You:
