Have windows 7 on new computer, installed Adobe Pagemaker which is fine but want to turn files into PDF format, message say's no printer driver installed. Have tried to install but windows will not let...
the printer will need to be installed in compatibility mode....un-install the printer from control panel.
pain in the **** i know, but least you'll know from now on, how to install older programs & drivers in to windows 7....
if your installing from a disk, then put the disk in, then when the auto run box comes up, close it...
open computer instead from the start menu.
right click on the cd drive with the disk in, & select open.
drag & drop the contents of the disk on to your desktop....make a new folder to put it all in, if you need to.
then once it's copied across, right click on the install/application icon.
from the top of the menu click "check compatibility" if you dont see it,click off it & then try right clicking on it again untill you see it.
windows will scan & set itself to the right settings for that program.
then click try recommended settings.....followed by START PROGRAM.
if it all installs ok click next then click YES KEEP THESE SETTING FOR THIS PROGRAM NEXT TIME.
then go to the printers web site & update it with the latest software,thats if windows doesn't do it for you.....TIP:(white flag @ bottom right of screen)
do this with all older software.....windows 7 is **** hot when it comes to running older programs, im using a windows 98 program call photo express on mine...no problem.
GOOD LOOK MATE.
