Good day. Go to phone menu, and select phone book. Browse and select log, all the information from your recent calls and text, even call duration you can find it there. There is a manual delete procedure that you can choose. Thanks
Your cell phone keeps track of every call you make and receive through it, including a caller's phone number and the date and time a call took place. If you answered the call, it records how long you talked. If you do not want this type of information about your habits to remain on your phone, you can delete records of individual cell phone calls received, dialed or missed, or delete the entire call log at once.
Delete Call Log
1.From the home screen, click the "Menu" button on your phone to navigate to the main menu of your cell phone. This is where your call log application is located, among other features such as your address book and text messaging.
2.Click on the "Call Log" or "Recent Calls" icon. The name may vary slightly depending on your cell phone provider.
3.Select " All Calls" from the call log screen.
4.Scroll down and select "Delete All." This will delete all calls from your call log.
As far as I know, there's no code that will enable the numbers to be recalled or seen. Call your provider, or take the phone into to them, to verify this. They should be able to verify this.
Good luck, and hope this helps.
Power cycling is not supposed to clear the incoming call log.
I will give you the book description of how to use the Navigator key on a 76xx phone. It may or may not work.
You can program a call log button, or use the Navigator to display, call, or erase the incoming call log. To display, press the call log button or left arrow on the navigator button twice.
It will show the last call. While that display is viewable, press the TRANSFER button to delete it, or lift the handset or press SP-PHONE to call it..
Your up and down arrow keys will step between the calls if you have more than one.
To program a button for call log, press the PROG softkey, a button, dial 54, and STORE.
These are the instructions for your personal call log. There are also instructions for Incoming Call Group (ICD) call logs.
These and other instructions are outlined in the TDA Operating manual.
Your dealer/installer should be able to get you a copy if you don't have one.
