Question about Garmin StreetPilot c340 GPS Receiver
Not charging had the garmin plugged in my car and said that battery was running low and I took it to radio shack thnking it was the car charger that wasn't working. I've pressed the side red button but won't start and I've only had it for about 2 months+/-.
If it won't turn on even when plugged into your car then it probably is the car adapter. Check the fuse. It is located in the tip of car adapter which can unscrew.
Posted on Jan 01, 2009
Just got a used Garmin 205W in the mail with no User's Guide. It says low battery. Can I charge it with a regular plug in device like I use for my cell phone, or do I have to use the cigarette lighter...
You can charge the garmin satnav with either the car charger when the car is running, an optional mains charger or you can charge it through the USB port of a computer. It takes around 8 hours to charge through a computer or 4 from a car or mains charger.
You can get the user manual from
Aug 03, 2011 | Garmin nuvi 205W GPS Receiver
I purchase a stanley 450 amp battery jumper.and i woul like to know how can i plug a radio in my ice shack with this product and if so where can i purchase whom this may concern thank you.
the most simple way to run the radio from a charcher is to hook radio and charger to a battery
the charger will charge battery and battery will supply constant volts to run radio
Jan 04, 2011 | Stanley Garden
Nuvi 255w-Where can I get a replacement fuse for the car powercharger? What is the fuse number?
On the plug charger unscrew the silver or black bottom tip of plug.. you can probably get a fuse from radio Shack or any Electrical supply store.
Oct 22, 2010 | Garmin Nuvi 660 GPS Receiver
My charger will not charge the computer, and when it is plugged in it is getting really it my charger or battery??
Toshiba laptops run really hot, normally. It is one thing that I dislike about them. I never investigated, but presumed it was processor, as the heat was being removed by the fan.
Sep 30, 2010 | Toshiba Computers & Internet
Garmin C340 Street Pilot
I had the same problem. Found out that the fuse had blown in the power cord. I bought a new fuse from radio shack and have not had the low battery since.
Mar 25, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin Nuvi 660 shutting off
It sounds like your battery is defective. They can be replaced. The Motorola phone cable is not wired exactly like the Garmin, and your Nuvi thinks it's connected to a PC. Radio Shack carries a charger for the Nuvi. I have one myself.
Let me know if you need additional help with your battery problem.
- Jim
Nov 15, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Oct 28, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin car charger
There are thee ways to charge the Garmin 750, 1: thru a car cord that plugs into the base that your unit mounts on. 2. Thru an AC charger. 3: thru the USB port on the Garmin unit itself. In your case the car cord plugs into the base that mounts your unit to the window. If that is not working, check that you are getting power from your car receptical. Check by plugging your Phone in or buying an adapter at Radio Shack that checks it. Also check the plug that goes into your car recepticle. Your manual tells how to check the fuse that is located in the end of the plug. If neither of these work your mount connection is bad. Hope this helps
Aug 02, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Low battery display
My first guess would be to take a volt meter, and check the power pack to see if it's putting out the correct DC voltage(or any voltage). Those things are super cheap!
Then check the plug in on the scanner to make sure your getting a good connection(might have a broken connection to the circuit board). If those are 2 year old rechargeable batteries, they might be getting close to laying down and dying. Hope this helps,, Mechanic
Oct 22, 2007 | Radio Shack Pro-94 Scanner
IQue 3600
You can get a charger that fits in the tiny little charging port, on the lower right side next to the "cradle teeth". But of course you will STILL not be able to sync.
Radio Shack has a set of port adapters, the little yellow one fits. Be SURE to plug it in the correct way around. (Bring iQue to Radio Shack when you buy adapter.)
Oct 08, 2007 | Garmin iQue 3600 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
