Question about Dell E197FP LCD Monitor
Dell E197FP LCD Monitor won't turn off
Monitor buttons will not work at all. Montior will not turn off. Other buttons will not work. If the computer is in a power saver mode with the monitor it will power down. However, when you move the mouse or touch keyboard to waken the computer and the monitor the computer will wake and start working, but the monitor button turns green then shuts down immediately. By unplugging the power cord for a few seconds the monitor will power up. Buttons still do not work.
5 Suggested Answers
SOURCE: Dell E197FP LCD Monitor won't turn on completely dead
From Matosml
Thank you all for the suggestions it turned out my PC was still under warranty so they send us a new monitor:-)
Posted on Jul 09, 2008
  • 4 Answers
SOURCE: blinking monitor power button and flashing image
I buy and sell these monitors (Dell E17FP) the problem is with the transisters (Q739, Q740, Q759, Q760) they short out and the monitor will just blink on and off. You have to desolder them and test them with a simple battery and light circuit. The reason they blow is because of the dirty solder joints by the transformers. If only on pair of backlights work the problem maybe transisters Q751, Q743. I home this answers your questions.
Posted on Sep 12, 2008
  • 922 Answers
SOURCE: Dell E173FP Monitor requires unplugging/plugging back in to wake
Perhaps your computer is hibernating instead of going into standby which takes a little longer to wake up from. While you are playing plugs and cables it give it enough time to come out of hibernation.
When the computer is in this mode the USB ports turn off which disables keyboard and mouse so the only way to wake up the computer is to press the power button on the computer itself.
One tell tale sign a computer is in hibernation is that the power light on the computer will slowly blink.
I hope this helps.
Posted on Aug 08, 2009
  • 822 Answers
SOURCE: Dell 1704 FPt lcd monitor power button blinking green, no screen.
the only thing you can do, is to get a qualified service technician if you are not an electronic expert. because the problem is in your power supply and inverter board. due to heat pressure inside can damage components specially capacitors.
Posted on Aug 15, 2009
The monitor wont come on.i noticed the power button has been pushed inside the monitor and i need to know if i can disassemble it to get i tout without hurting the monitor
The E177fp and E197fp are identical units other than the size of the display panel. Here is a link to a repair guide for the E177fp that has videos showing how to open the unit. It should help you get your open.
Nov 07, 2012 | Dell E197FP 19 inch Flat Panel LCD Monitor
Does a Dell E197fp monitor have built in speakers
Not in the monitor, there is a sound bar that attaches to the bottom of the screen that is optional that added speakers to that model.
Sep 24, 2012 | Dell E197FP LCD Monitor
Hi.i have a dell e521 with a e197 fp monitor. when i turn the system on the monitor stays in stand-by mode. so i have a black screen,is it broken?
not really.. theres a possibility that the monitor is just on standby mode. try to disconnect the power cable of the monitor, then hold the power button of the monitor to drain its flea power. put the power cable back then try it again.
if its going to do the same thing, check the connection of the monitor at the back of the computer. see if its seated properly.
try restarting the computer..
try draining the flea power on the computer as well, possible that the computer is in standby or hibernate mode..
Jun 23, 2010 | Dell E197FP LCD Monitor
My LCD Dell Flat Screen Monitor has a blue
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
Good Luck!
May 12, 2010 | Dell E197FP LCD Monitor
The monitor screen has a yellow tone to it.
try the new monitor with a different pc, if it works fine, your PC has a videocard problem..
May 08, 2010 | Dell E197FP LCD Monitor
Monitor lights but no picture when i press the on button backlight comes on nothing else
Check the cable from AD board to TFT panel.. If not replace the AD board..
Jul 08, 2009 | Dell E197FP LCD Monitor
Dell E197FP - Screen turns off and on constantly
Check the video connector to make sure it is clean and tight. Look closely for broken or bent pins by GENTLY rubbing your finger across the pins.
Otherwise, it sounds like the monitor screen is failing or has faulty wiring or components inside.
Sep 03, 2008 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
could be dead, but check to ensure that you are using the monitor ONLY, not TV tuner device. as a standalone, not hooked to cpu if there is no power light when plugged in assume your buying a new monitor.
Jun 21, 2008 | Dell E197FP LCD Monitor
Dell E197FP LCD Monitor Logo
170 people viewed this question
Alun Cox
