Question about Aiwa HV-MX100 VHS VCR
More info on Aiwa HV-MX100 not powering up
Mine does something similar (AFAIK) to a recent question. When the power button is pressed the normal display apears and there are some mechanical noises. After about 10 seconds it shuts down, not ejecting any tape that had been inserted. I opened the unit to see what was going on, or not. The small motor that triggers the arms to bring the tape into position, does move a little in each direction, but not enough to move the arms. The large silver wheel (head?) spins fine. On the bottom of the mechanical section there is a belt that's in place,and spins freely, but I can't tell if this moves when operated. What I never see move are the white plastic cogs that rock into place to turn the spools. The VCR does not seem to be able to eject the tape, even if turned on and "eject" is his when a tape is sitiing inside. looks like something is not moving as it should, or is not being triggered to move. Thanks for any advice or things to try.
  • shaun wallace Apr 30, 2007
    I take that back about the front congs not moving, i saw them in action.
    also, after reassembly, it almost worked: Took a tape and started to "play" it. Fast forward seemed to happen too. However still couldn't eject.
    After this one-off reprieve it's back to its full failure state.
  • 68 Answers
Mechanical fault needs profesional technisian just not to make it worse , regards
Posted on Apr 30, 2007
On an AIWA HV-MX100, black and white picture OK but why not color?
If the remote works then it works. You might be missing a few functions but I can't imagine that it's capable of switching to B&W. I might be wrong but I think that the TV needs checking.
May 05, 2015 | Aiwa Televison & Video
Tip
Current location for the HV-MX100 VHS VCR User Manual download
The current location for the downloadable User Manual is http://www.docs.sony.com/reflib/docget.asp?manualid=16110&template_id=&region_id=1&DL=
The manual is at Sony's web site since Sony bought out Aiwa in 2002 (and discontinued the brand in 2006).
on May 06, 2009 | Aiwa HV-MX100 VHS VCR
Tape doesn't eject
Since how long? 90% probability is weak, aging Eject Motor belts. Replace
Nov 26, 2011 | Aiwa HV-MX100 VHS VCR
My Aiwa HV-MX100 vcr has not been used in about 18 months. When I insert a tape, I can hear a whirring noise, but the tape will not eject properly. Also, the power will not shut off completely - the...
Is your VCR fixed?
From what you have written, I understand that you have not used the VCR for many months. And since you are hearing a whirring noise, the eject motor is working, but the belts are spoilt, and are slipping. Hence your problem. I suggest you open the top cover of the VCR and observe the eject mechanism. As suggested, you will - in all likelihood, observe that the belt driving the eject gears is slipping.
May 27, 2011 | Aiwa HV-MX100 VHS VCR
Hi, I bought one of these from eBay and although the unit is in beautiful condition and plays perfectly, the display does not light up, nor does the NTSC button or STOP button work. I bought a remote...
HI, sorry to hear that. you have to buy another controller from AIWA. and bring the unit as well to let them know the exact model of your unit. to avoid damaging the unit
Feb 13, 2011 | Aiwa HV-MX100 VHS VCR
I have a aiwa HV-MX100u there is in need of service. I live in Abbotsford B.C. Canada, can you advice for a service center please.
You can contact nearest Sony service center for Aiwa unit service because Aiwa brand has been owned by Sony and providing service/ repair.
Hope this info will help you.
Thanks.
Nov 09, 2010 | Aiwa HV-MX100 VHS VCR
I have an Aiwa hv-mx 100 vcr Now some time the picure of my pal videos doesn't show in NTSC tv. Is it the problem of converter within vcr? or voltage regulater?
Pal and NTSC devices signal prequencies don't matches.Can't work to gether.U sure it different Pal and NTSC mix together devices before?
Oct 22, 2010 | Aiwa HV-MX100 VHS VCR
Aiwa HV-MX100u powers down after 5 secs, even without cartridge
Dave, your problem is most likely with the mode sensors. I had the same symptoms and it turned out that some lubricating gel had migrated onto the electrical contacts that make up part of the mode sensing system.
If you go over to the HV-MX100 page, I've posted a guide (with photos) under the Tips section showing how I fixed it.
May 01, 2009 | Aiwa HV-MX1 VHS VCR
Aiwa HV-MX100 multiformat VCR won't power on...
Too little information to give any information / help / opinion. What actually happens? Does the Display come on properly? Do you hear any mechanical Noises? Like a motor whirring? Are you able to load a cassette into the machine? Does it get ejected automatically? As you say that the machine switches ON, I assume tyhat the Power supply cicuits are Ok, and this leaves us with the possibility that there is a mechanical problem.Is it that the machine was not used for a long operiod of months or years? If that is the case, in all probability the belts are damaged / broken / loose. I really need more info, please.
Mar 07, 2007 | Aiwa HV-MX100 VHS VCR
Our Aiwa MX100 doesn't play our pal system tapes
Just Clean the Video heads with a Wet Type Head Cleaner. Do 2 or 3 runs. Should clear up the problem.
Feb 25, 2007 | Aiwa HV-MX100 VHS VCR
Aiwa HV-MX100 VHS VCR Logo
268 people viewed this question
Top Aiwa Televison & Video Experts
romy sibug
romy sibug
 Grubhead
Grubhead
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
