Question about Frigidaire GLGF376DC Stainless Steel Gas Kitchen Range
Oven not turning on f31 code kenmore
Push bake set temperture wait 3 sec and f31 come up
  • Frigidaire Master
  • 2,651 Answers
May be a real simple , lets try this. unplugh the unit, and uscrew rear panel of the unit, there is a thermostat that may have tripped, very small maybe the size of a quarter, with 2 wires on it, easy to sppot because it will have a small red button atop of it, its resettable, so if it did "trip" melrey reset and your on your way,there are actuallly 2 of theese thermostats on your unit, and actually a more common one to trip would be the one in the control panal, so id prblaby check this one first, to acces it remov eht knobs, then wehere the knobs were are "large plastic lock washers" holding down the control panel, one around earch knob opening, after ermoving htem the control panel will lift up and lean over. i belive there are 4 screws to remove the clock(plenty of slack in wiring no worry)after thats out of the way, if you look down under behind the switch to right is the same resetable thermo(lok for the the red button) and with a small long screw dricer youll be able to reset it, this should cure you issue. sounds like a ton of directions but should take no maore than 20 min, to check em both
Posted on Dec 30, 2008
I had a power outage and now my kenmore ultra bake glass top stove, has no power to oven.only when i hold cancel button for few secs"F2EO" shows up on screen. 4 burners still work,along wif oven light
The error code E0-F2 indicates that your touchpad has a stuck key. You might try disconnecting the electricity from the range and pushing and releasing the buttons on the touchpad several times. Be aware as you push them of any button that feels different. If you notice one that is stiffer or just doesn't feel like the others, give it several more pushes. Worst case scenario, you will need to replace the touchpad.
Jan 19, 2018 | Kenmore Kitchen Ranges
How to fix kenmore f 3 code?
f3 code is the code for the oven temperture sensor that control the oven temperture need be replace ok
Dec 13, 2017 | Washing Machines
Oven does not turn on
Hi! My gas oven is not turning on yet the burners work. When I try to set the oven to bake there is a beeping sound with a digital message that reads F31????
Jan 14, 2014 | Ovens
Oven wont start, shows F31 error on display
What is the complete model number of the unit?
Dec 04, 2012 | Washing Machines
I'll presume you have no "fault code" appear in the display, i.e. F30, F31 correct ? Is it both top and lower oven ? What happens when you select a bake cycle, anything ? Does it appear to be on, but no heat ?
Just need some clarification and details and I'll try to help.
Oct 30, 2009 | Thermador SMW272 Electric Double Oven
Oven will not heat on bake.
does the ignitor glow? if it does and the burner does not fire within 30-60 sec. replace it it is weak .if the ignitor does not come on at all youll need to check for voltage at the ignitor when the bake circut is on.
Sep 16, 2009 | GE JTP86 Electric Double Oven
How to set the oven timer?
To Program Oven for a Delayed Start Time and to Shut-Off Automatically 1. Be sure that the clock shows the correct time of day. 2. Place the food in the oven. 3. Push "Bake Time". "00:00" and the words "BAKE TIME" will glow in the display window. 4. Push and hold up or down arrows until the desired baking time appears in the display. 5. After the bake time has been set, "----°" will appear in the display and the word "BAKE" will flash. The display will flash and beep once until the oven temperature has been set. 6. Push "Stop time". The time when baking will stop, will appear in the display window. The words "BAKE STOP TIME" will glow in the display. 7. Push and hold up or down arrows until the time that you want cooking to be completed appears in the display. 8. Push Bake (or Conv). "---°" will appear, and the word "BAKE" will glow in the display. 9. Push and hold up or down arrows until the desired baking temperature appears in the display. 10. If the baking temperature is not set, the control will beep. "---°" will flash and the word "BAKE" will appear in the display.
Mar 11, 2009 | Electrolux Kitchen Ranges
F 31 Frigidaire gas range
if it cooler that the temp set its the theromstat f31 sorry don.t know
Dec 20, 2008 | Frigidaire FGF326AS Gas Kitchen Range
F31 error
it is a shorted oven probe sensor
Apr 09, 2008 | Ovens
Frigidaire GLGF376DC Stainless Steel Gas Kitchen Range Logo
999 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
