Question about Freezers
Freezer will not cut off except
It cuts off when i manually turn down the thermostat to 1.5 or 2 but then it wont cut back on by itself
  • 115 Answers
You either got a bad thermostat or low on freon if everything is frozen it is the thermostat
Posted on Dec 30, 2008
Freezer contents thawed, freezer cuts on but only runs a few seconds and cuts back off
Compressors do not usually shut down. Either there is a power interruption to the motor caused by the power switch or thermostat or the motor has developed an internal short whereby it uses excessive power causing it to overdraw/overheat and have the clixon circuit shut it down.
Jan 20, 2014 | Frigidaire Freezers
Kenmore upright freezer
Hello;
My name is Peter. I am a retired field service refrigeration technician.
I am going to assume your compressor and condenser fan is running. Your condenser fan is in the lower back of your freezer.
You will need to remove the back cover in your freezer. There are 6 screws holding it on.
Check the following (Cover Removed):
1.) Frozen Drain - Your freezer goes into a defrost mode every 8-10 hours, where your freezer shuts down except for the lights, and your defrost heater turns on for about 20-30 minutes to defrost your cooling coil. If you have a frozen drain, the condensate builds up behind the back wall and icing the cooling coil, restricting air flow. You must defrost the coil.
2.) Freezer Fan Motor Failure - Having removed the back wall observe if the freezer fan motor is running. If not replace.
3.) Refrigerant Restriction or Leak - If you observe a large build-up of ice in the upper right hand corner, then you have a restriction or leak. The cost of repair would be about $400.00
4.) Bad Thermostat - In the upper right hand corner of you cooling coil, attached is your thermostat. They can explode, where the back of the thermostat will raise up.
22602419-rljzekqxa22lq3uayqx0h0vi-3-0.jpg 22602419-rljzekqxa22lq3uayqx0h0vi-3-3.jpg
You can also check it with a multi-meter, set to the lowest Ohms (Omega Symbol). You need to cut the wires, leaving enough wire length to rewire back in. Put the thermostat in a glass of ice water for 10 minutes. After, it should Ohm out around 16. It is reads '0' or infinity it is bad. Below 15 or 16 it is bad
Jan 01, 2014 | Freezers
My upright freezer runs more than it is off
general design requires compressor on off ratio to be total run time to be 18 hrs on per 24 hr day off time allows compressor to cool down averaged over the day cool air is required around the outer walls of the fridge to cool the condenser coil at the rear also
Oct 03, 2017 | Frigidaire Freezer Refrigeration White...
Can only get freezer to work when quick freeze is turned on
Your thermostat is faulty. Run it in fast freeze mode until you can get it replaced
May 04, 2012 | Freezers
My freezer keep running all the time...meet and everything frozen but will not cut out. cannot find a dial inside to turn down.is it behind.
dear sir /madam
please find the thermostat setting controller in your freezer,s inside of door and on the control panel after make reset it on correct temperature .
i hope after that it will work with temperature setting.
hope answer the question
thank you
please vote!
Aug 18, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
My fridge freezer is running non stop
It is probably because it's not getting cold enough to cut off. If you slowly turn the thermostat to warmer it should cut off when it gets to that temp.If it doesn't cut off then it is a thermostat problem. When you have heavy ice buildup on the evaporator coils inside the freezer behind the back panel that will hamper the cooling. This is caused by a defrost system failure.
Aug 15, 2009 | Freezers
My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
Fridge freezer upright
Replaced the thermostat
Jun 22, 2008 | Freezers
Freezers Logo
131 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
