Question about Whirlpool LGV4634JQ Gas Dryer
No heat in my gas dryer
The machine runs but no heat.
(whirlpool lgv4634jq model)
Check your thermostat. Put a meter on it, if it has no continuity, it's open (blown). They are not resettable.
Posted on Jan 02, 2009
2 Suggested Answers
hiltonjug
  • 612 Answers
SOURCE: Whirlpool Gold LGV4634JQ Gas Dryer Heating problem
Replace the thermostats. they are round pieces with a oval base. They have 2 wires, sometimes 3 going to them. They can be checked but it's kinda complacated.Although if you would like me to walk you through it I would be gale to if you will get back with me.
Please rate solution if helpful
Posted on Aug 25, 2009
I have a whirlpool gold gas dryer model#GGQ8858JT1. When I push the start button the dryer starts and spins but the heat does not come o
does the igniter glow? If not check for 110 volts at igniter .
Check for 110 volts at gas valve if no volts check hi limit thermostat , operating thermostat, safety switch on motor,
the coils on the valve & the timer contacts that feed the voltage to the burner.
Mar 02, 2014 | Whirlpool LGV4634JQ Gas Dryer
We have a 10 year old Whirlpool Dryer Model #LGB6200KQ0 drum is turning but no heat. Could you please advise?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 02, 2011 | Whirlpool LGV4634JQ Gas Dryer
Dryer will not heat, plus timer will not move
heatman101
Apr 09, 2010 | Whirlpool LGV4634JQ Gas Dryer
Aug 25, 2009 | Whirlpool LGV4634JQ Gas Dryer
Runs, but no heat
First of all if you have fuses check for one of the fuses being open, if circuit breakers be sure they are ok. Next check for 240 volts to the heating element, if you have that and no heat replace the heater
Jan 04, 2009 | Whirlpool LGV4634JQ Gas Dryer
I replaced the heating element, OLD ONE CRACKED STILL NO HEAT
You have to let us know what it is doing, and what it is not doing. Is the new heating element getting red hot? Is the motor running? Did you clean the face of the flame sensor, a little gizmo attached to the firebox?
Nov 24, 2008 | Whirlpool LGV4634JQ Gas Dryer
Dryer Wont Spin
most likely a motor, If machine runs but not turning, either belt broke, if direct drive, motor
May 01, 2008 | Whirlpool LGV4634JQ Gas Dryer
My Dryer does not heat
Have you checked the thermal switch? If this is bad it will run but give no heat.
Apr 01, 2008 | Whirlpool LGV4634JQ Gas Dryer
Gas dryer lgr4634eqo GAS
check the thermal fuse located at the back of the dryer for continuity and let me know how you make out
Sep 13, 2007 | Whirlpool LGV4634JQ Gas Dryer
Whirlpool LGV4634JQ Gas Dryer Logo
112 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
