Question about HP OfficeJet 6210 All-In-One InkJet Printer
Im coming up with an error 388* on my fax it used to work but we moved when the phone line is in 2-ext i can use the phone, and the fax wont work, but when i plug the phone line into 1-line the fax works and the phone says in use. but my fax just will not go for some reason.
  • 193 Answers
Check canon website...hardware!
or call canon call centre.
Posted on Dec 30, 2008
Keep getting error code 388* when im faxing something
Pls do the following
Error Code:
388
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
On lexmark 7170 printer-when trying to fax-always get ''phone line error''-- connection is good from directline--phone works- Can't fax even without using pc I am using a Lexmark7170 printer with windows...
Hello. The "phone line error" usually comes up when the printer/fax is not connected properly to the fax line. Try to check behind the printer. There are two phone ports - Ext. and Line. The telephone cable should be plugged in to the Line port of the printer and the other end should go straight to the phone jack in the wall. If it is, try to use a different phone cable. Also, make sure that you assigned the correct fax number in your printer. Hope this helps.
Mar 20, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Faxes do not send or receive using Magic jack
if its ooficejet,then u shud use 2 prong cable,wire that is coming out from wall jack shoud be directly connected to the line port of the printer and if u are using a tam that shoud be connected to the ext port of the printer,and if this doesn't work,then 1 thing you can do,remove the tam from the phone,and in case if you cannot remove,turn off the tam and then try to send,you wud be able to,and use only two prong cable,and i beleive you are not using voip connection....
Aug 25, 2009 | HP Officejet 6500 Wireless All-in-One...
Problem faxing-error message
Error 388:
Definition
Solution
Error 403:
Definition
During a V.34 transmission, the local machine is unable to connect (handshake) with the remote machine and is consequently unable to send a T30 frame. This occurs when the line is disconnected or if line conditions degrade during the session.
Solutions
  • Remove any pass-through devices from the phone line, and then try the fax again.
  • Confirm that the fax/phone cable is no longer than required, and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
  • Try to send the fax at a different time when telephone line conditions have improved.
May 29, 2009 | HP Office Equipment & Supplies
Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
Solution
Solution
Please Click here and follow the instructions to resolve the issue.
May 21, 2009 | HP Officejet 6310 All-In-One InkJet...
Can't get the fax to work. It WAS working before.....
follow this simple steps:
1 .Connect the phone cable that came with the printer to the back of your modem to the port that says tele 1.
2 . connect the other end of the phone cable to the port on the printer that says "1-line"
3. connect the phone cable or cord that came with your telephone line to the back of the printer port that says "2-EXT" and the other end to the back of your telephone ..
This should solve the problem..best of luck
Mar 26, 2009 | HP Officejet 7210 All-In-One InkJet...
What is error 388
there is not error code for the OfficeJet 4315. however, there are similar code for other Hp printer.
error "388" is lised as unable to detect T30 frames. in other words, the machine fail to establish comparable connection. this can be the machine trying to send out fax in high speed, or the phone line problem.
consult the user manul how to set a lower transmission rate, or try to send the fax at a differnt time of the day . If that still give you problem, please call the phone company and have they look a the phone line.
Nov 10, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Sending faxes
Error 388 is for telephone line conditions being bad, have you called your telephone company and head you telephone line checked...?
If not please have it checked.
For more details on the error message check the link bellow with Error codes any their reasons:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&cc=us&lc=en&dlc=en&product=79477
Good Luck
Oct 11, 2008 | HP PSC 2410 All-In-One InkJet Printer
Fax not working Error 388
We had the exact same problem. Static on the line. We had the cable company check and sure enough our digital modem for the phone line was bad. The new replacement fixed the problem instantly.
Aug 06, 2008 | HP Officejet 5610 All-In-One InkJet...
Fax
error code 388 says :-
Unable to complete the handshake.
*Try to send the fax at a different time when telephone line conditions have improved.
Mar 06, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
87 people viewed this question
Seeker5211
Seeker5211
