Question about Sony Uncharted: Drake's Fortune
Turning the 4 statues, which way do each face?
The 4 statues in the sanctuary chapter.
  • 903 Answers
Hit "Select" to check the journal entry, then use that to line the statues up. Each statue corresponds to a Gospel - Matthew, Mark, Luke, and John. Figure out which statue is which, then use the compass painted on the floor to point them in the right direction. Each statue has to face a certain direction (north, south, east or west), and when they're all properly aligned a door will open.
I got this from gamefaq
I hope it helps
Posted on Dec 30, 2008
How do I find the ratio of a statue made from a mixture of copper and zinc? It is a ratio of 11:4
11 parts copper and 4 parts zinc for a total of 15 parts.
Thus 11/15 copper and 4/11 zinc.
11/15 of 75 pounds is 55 pounds. 4/15 of 75 pounds is 20 pounds.
Hence 55 pounds of copper and 20 pounds of zinc.
However, if you really want to know the ratio of the statue, then it's given in the problem as 11:4.
Oct 06, 2014 | Cars & Trucks
Cannot pick up the statue in the rotating room for Mystery of the Mummy..level 3. I can get into the next room and solve the water puzzle and get the chess board but I can't solve that puzzle because I...
I found this walkthrough for the DS version By: perseaphone@yahoo.comHopefully it will work for pc as wellTo help keep yourself oriented in here: there are a total of 4 statues. Two on eachside that face each other. On one side you will see that the statue closest to the door has a crooked staff in hand and the other statue has a spear. The opposite wall has the statue with the spear closest to the door and the other statue holding the crooked staff in the back. Click on the center of the room until you are facing two of the statues and can reach them. Click on each statue once. Turn and click on the center of the room until you are facing the other two statues and can reach them. Click on each of these statues once. A panel in the floor next to the door you came in should pop open if you did it right and you need to work your way back there and pick up the STATUE. Click on the center of the room until you are in the center again. Your objective is to now reach the door opposite the one you came in. *NOTE: I found that once I got to the center of the room and then clicking towards the statues OPPOSITE the door I really wanted to go to, I was able to get to the door I needed.
Mar 21, 2011 | DreamCatcher Interactive Sherlock Holmes...
4 statues
Point the statues in the correct direction according to the Journal.
Sep 13, 2009 | Sony Uncharted: Drake's Fortune
I dont understand the 4 statues they're facing the right way when i come to that part am i doing something wrong ? an when i do get statues in the right place where do i go then? i have been stuck on this...
If you look on the floor you will see where north, east, south and west is facing. If you check your journal, each statue will need to face the correct direction. Just match what the journal says to the compass on the floor.
Jul 12, 2009 | Sony Uncharted: Drake's Fortune
4 statues
There is a compass on the floor. Match the direction of the statue to what the journal says. The direction of each statue is written in the journal.
Jun 27, 2009 | Sony Uncharted: Drake's Fortune
Which way do the statues face inward or outward
4 statues
please describe moar
Jun 21, 2009 | Sony Uncharted: Drake's Fortune
I cant figure out the 4 statues
if your on about the ones in the Library Climb up each shelf that each point of the compass on the floor is pointing at and point the statue on the shelf in the direction the journal specifies (Angel should face North, Goat Angel should face South, Lion Angel should face West or O as the compass on the floor says and the Bird Angel should face East).
Jun 03, 2009 | Sony Uncharted: Drake's Fortune
Yomb raider underworld
SHIVA/KALI STATUE COURTYARD – MOVABLE STATUES WITH FANS: Approach the 2 small statues of Thai dancers holding fans. You'll notice these are set on tracks in the floor, enabling them to move. Face the big Shiva/Kali statue to get oriented and then go to the dancer statue on the right. Press Interact to grab it. Slide it along the straight track to the left. Then push it clockwise along the circular track, almost all the way back to the straight track. When it reaches the correct spot, the beam of light shining from the gem in Shiva's hand reflects off the fan the small statue is holding.
Now go to the statue on the left. Take hold of it and push it counterclockwise along the circular track all the way around to the straight track. Then slide it to the left all the way across the straight track. Finally push it forward (clockwise) just a little bit along the circular track until the sunbeam from the gem above reflects off the fan. (The diagram at right shows the sequence.)
When the statues are positioned correctly, the two beams of light strike the Kali statue and the floor opens up, revealing a doorway.moz-screenshot.jpgmoz-screenshot-1.jpg
Mar 12, 2009 | Eidos Interactive Tomb Raider Underworld
The sanctuary
Hit "Select" to check the journal entry, then use that to line the statues up. Each statue corresponds to a a Gospel - Matthew, Mark, Luke, and John. Figure out which statue is which, then use the compass painted on the floor to point them in the right direction. Each statue has to face a certain direction (north, south, east or west), and when they're all properly aligned a door will open.
hope it helps
Dec 27, 2008 | Sony Uncharted: Drake's Fortune
Sony Uncharted: Drake's Fortune Logo
723 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
