Question about Amana ABB1927DE Bottom Freezer Refrigerator
Freezer is working but the fridge part is warm?
I pulled it away from wall there is nothing there, vacuumed under the coils but still warm. It is not quite 3 years old. My niece had the same problem today, we just had a power outage for a second on Sunday could that be the problem?
  • Amana Master
  • 4,654 Answers
Lot of possibilities here that could effect your refrigerator, defrost timer, defrost element, leak of freon etc. Click on link below and you will get a lot of answers...........Hope this helps, Sea Breeze
http://www.youtube.com/watch?v=nzzI68oD9_Q&feature=related
Posted on Feb 01, 2009
Chef Base is cool but not cold enough and way to adjust this..
  • Check the thermostat control. Even if you've not touched it, something may have knocked it and adjusted the setting. The thermostat may also need to be adjusted depending on the temperature of its surroundings and the coldness of the weather.
  • Make sure any food stored in the fridge or freezer is not blocking any air vents. This can stop air circulating properly.
  • If the fridge is too close to the wall, the condenser coils will not function properly.
  • Defrost the fridge and freezer thoroughly and clean the inside surfaces with warm water. Check any air vents to ensure they are not blocked.
  • Clean the condenser coils at the back of the fridge using a vacuum cleaner, making sure all dust and any dirt are removed. Clean any stubborn dirt away with warm soapy water, being careful not to scrape the coils. Turn your fridge off and unplug it before doing this.
  • Make sure the fridge's fans are not clogged and are able to function properly. Again, you need to turn your fridge off and uplug it before attempting this.
  • Check the door is closing properly. Make sure nothing is obstructing it or pushing it slightly open. Ensure the seals around the edge are working well.
Jun 03, 2015 | Refrigerators
Fridge not cold. Compress or runs 5/10 seconds smoothly then kick s out . DW
Jun 02, 2015 | Refrigerators
Samsung Fridge Freezer (Freezer on top) Model SR-52NXA Freezer is cold but fridge is not cooling ?
remove evrything from bottom of freezer. take out the shelves . You will see a panel on the back of the unit with screws holding it on take these off . under it is the freezer exchange coils they got froze up,
and frosted full so now no air is circulated between the cabintes, refridge and freezer do not use any sharp object to clear it use a towel and blow dryer to thaw it even a spray bottle with warm water, but don't pick at it!!!! you can puncture the coils . take your time and you will save your unit. also while your at it pull it away from the wall remove that small panel from the back, and the grill from the front and with your long reach nozzle vacuum the heat ex changer coils under the unit. put back together carefully and it will run for a while longer i have one that is a 72 model still runs great Oh any change you find is mine!
Sep 06, 2012 | Samsung Refrigerators
Too warm both freezer and fridge recently ice cubes melted when opened a lot.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 28, 2009 | Admiral Refrigerators
Refrig temp not cold enough..drinks are almost warm
Aug 27, 2009 | Frigidaire FRS26H5AS Side by Side...
Kenmore refrigerator will not cool. Freezer works
Aug 27, 2009 | Kenmore Refrigerators
My Daewoo FRS2021IAL has a warm fridge
Aug 26, 2009 | Daewoo Refrigerators
I have a GE Refrigerator model # TEX21J1SRRAD 20.6 cubic feet top freezer. a couple of days ago i noticed the refrigerator was getting warm but the freezer was working fine. Could this be a fan problem and...
Aug 26, 2009 | GE Refrigerators
2000 Amana BX21Vl fridge: ice maker and freezer not working.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of. after the freezer freezes again, your ice maker will work again.
Aug 18, 2009 | Refrigerators
8 yr. old GE Refrigerator/Freezer has started becoming too warm -milk spoiling
hi. thanks for the question. look at the freezer, is there frost build up on the freezer wall . is the fan running in the freezer. also pull fridge away from the wall ,clean all coils thanks the appliance doc
Oct 05, 2008 | GE Refrigerators
Amana ABB1927DE Bottom Freezer Refrigerator Logo
100 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
