Question about Hitachi 61SDX01B 61" Rear Projection Television
Hitachi 61udx10b hi i have a hitachi 61udx10b projection tv i have red ghost on my screen tried the magic focuse did not work i tried a manaul convergence and couldnt get the red lines to line up but when i exited out of this the magic focus got turned off any ideas thanks matt.
  • 1 more comment
  • hauffs Jan 03, 2009
    i replaced the stk392-110 with the stk392-180 and didnt make a difference tried to manually align the convergence and the tv went blank and the red light in the front started flashing and now thats all it does.tried turning it on and off and unplugging it didnt make a difference red light in the front just flashes when you turn it on.any suggestions thanks matt.
    no i didnt change any of the resistors i will have to order them just got back from local radio shack of course they dont carry any of them so i will have to order and give that a try thanks matt.
    i dont see a ik01 or qk01 on my board the two chips of ik05 and ik04
  • Hitachi Master
  • 5,138 Answers
Replace Both of your STK ICs they are your convergence ics they are big black ICs will have Part# on them for example STK392-110, if they are 110s use 180s, if 020s use 040s other wise replace with exact same number. To get Parts call Electronix 1-800-223-3205
Posted on Dec 30, 2008
  • ladywinn
    ladywinn Jan 03, 2009
    Go back to convergence board recheck where you have solder ,make sure you havent solder wrong two connections together Also did you change out any of the resistors There is Six of them (RK42) 3.3 ohms. (RK46) 1.8 .(RK50) 2.7 (RK54) 1.5 ohm (RK58) 3.9 (RK62) 2.2 ohms----- I work on so many different tvs i forgot about resistors, Resolder IK01 and QK01.
  • ladywinn
    ladywinn Jan 04, 2009
    IK01&QK01 Transistors 3 legs up front on convergence board there is a setup switch on that board at the very front of board both are next to it. If you go to Front of TV remove speaker cover behind it you should see whole chassis from front on convergence board is convergence setup button press it and hold for 3sec with TV on ,release then convergence Pattern should come up.
Ghost image in red and alot of red color. This occurs all the time. I have tried magic focus and manuel focus. No change
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv have a dead convergence board.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.Fixing the tv convergence board,will solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 09, 2011 | Hitachi 51F500 51" Rear Projection...
Hitachi 53swx01w HD rear projection tv was fine until i ran the magic focus. now i have blue & yellow ghosts.
Ur convergence is dead.U must know how to solders?Must replaced 2 STK convergence ICS and some or all the resistors.Tries Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300 for parts and labors.
Mar 17, 2010 | Hitachi 53SWX01W 53" Rear Projection...
Picture has green and red ghosts. went to magic focus and it will not continue thru the red focus, then a #5 is on the bottom of the screen
Ur convergence is dead.Know how to solders?Must replaced two convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit.Tv shop will cost u $300 dollars for parts and labors.
Jan 26, 2010 | Hitachi 51F500 51" Rear Projection...
HITACHI 57UWX20B has blue ghost shadows how do I
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 05, 2010 | Hitachi 57UWX20B 57" Rear Projection...
Red convergance appears tp be off, seeing ghost images shifted left
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Televison & Video
43fdx15b Hitachi 42in red vertical lines magic focus inop for red
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors.Shops usually charge from $200-$300
Sep 26, 2009 | Hitachi Televison & Video
''Magic Focus'' doesn't fix ghosting problem
YOU HAVE CONVERGENCE PROBLEM THE PARTS NUMBERS STK392-110 YOU HAVE 2 OF THEM THEY ARE BAD
Aug 28, 2009 | Hitachi Televison & Video
Hitachi projection tv
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Using your original remote go-to the tv settings then goto the convergence or magic focus section
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Dec 29, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi 61SDX01B 61" Rear Projection Television Logo
326 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
