Question about Philips Magnavox 27MT5405 TV
Philips Magnavox 27MT5405 TV problem with color
I have had this tv under 2 years. At this moment, and this just started, I have color distortion on the corners of the tv. On one corner is a bright purple,the bottom corner under that is green with white, the opposite bottom corner is also bright purple, and the top corner above that is light purple. This is on the TV with the dvd and cable on. What is it and what am i looking at in price and repair?
  • 71 Answers
Hi sir that thing hapen when the magnetic field around the screen is varies evry time the tv set is switched off then on after an hour may be , it comes to its normal magnetic field state and when not so there are two reasons 1- check for around the tv for any magnetic items ,speakers , cassette recorder or any magnetic motors clear the around electric items if not working after an hour of reset then refer to 2 2- there is an electronic element inside calles PTC it should be deffect it is a small three legs element and is giving the first power to the colis around the screen to make proper magnetic field check it by qualified person please please don't forget to rate the solution and remember i am here at your service regards ]
Posted on May 08, 2007
SOURCE:
The picture is out of focus for all inputs.
the tv is not worth fixing,get a flat screen lcd hdtv,here is the manual, Philips Magnavox 27MT5405 Product Manual
May 08, 2015 | Philips Magnavox 27MT5405 TV
Magnavox tv about 11 years old does not turn on at all what is the problem? all connections are ok
Magnavox are a generally cheap brand of television so 11 years out of the product is a good run
i would assume that the power supply inside the Tv has died, you could probably get it repaired, but it would be most likely cheaper just to buy a new TV.
Mar 05, 2011 | Philips Magnavox 27MT5405 TV
Picture does not stay on when set is turned on
its a switch fault, you need to get a tecnition but cheaper buying a new tv,hope this help
Jan 24, 2010 | Philips Magnavox 27MT5405 TV
Distorted picture
tv has red & blue converge problem,tried to fix it with remote by multipoint lining the t,s up didn,t help
Jan 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
Hooking up dvd
Brad, AV-1 INPUT, be advised this will use up the AV1 port so if you have another item that uses regular AV cables you`ll then have to use AV2 for the video in and L&R audio in, enjoy, BMW Rider
Jan 07, 2008 | Philips Magnavox 27MT5405 TV
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Need help connecting a playstation.
purchase an AV Scart Hub (a switching box/scart box),and connect all of your devices to your tv directly.
Apr 24, 2007 | Philips Magnavox 27MT5405 TV
Philips Magnavox 27MT5405 TV Logo
163 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
