Question about Insignia NS-13CTV
Need instruction booklet for this tv
Someone gave me this small tv for my home office. I connected it to my cable in the wall but i can only get a few standard channels when i choose other channels it says air i dont know how to switch to comcast cable\
  • Insignia Master
  • 1,213 Answers
The command you seek is in the remote. You will have to experiment as to what menu item will separate an over the air signal to cable. It should say on the menu screen and it will direct you....seek and ye shall find.
Posted on Sep 12, 2009
Phillips t v codes "Locked"
It will explain how to child lock or hotel mode you tv in your instruction booklet.
Aug 29, 2017 | Televison & Video
Panasonic plasma flashing red light
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 11, 2013 | Panasonic Silver Tilt/Tilting Wall Mount...
I need an instruction booklet showing how cables areconnected
connected to what buddy? need more information. which two device do you wanna connect
Mar 30, 2013 | Exercise & Fitness
How to get lan connection (home connection network)
After you get cables and a D-link or router you will just need to configure it on your computer, open control panel and click Network and Internet connection then create new connection, with the LAN its a work or small office and then follow instructions when the wizard tab comes up. You will need to choose cable because that is what Lan will use or wireless connection if you have a wireless network then follow the instructions carefully
Jul 04, 2011 | Computers & Internet
Hi Someone gave me this old Sanyo TV Model # 31C4760, When I connect it with my cable it catches only basic (13 channels) instead of 60 channels. How should I see all the channels? What should I do?
If it is very old (with rotory/manual channel changer), you are out of luck unless you get a cable box from your cable company - this will let you set your TV on channel 3 or 4 and the cable box will find all stations for you. The cable box goes between your wall cable and your TV.
It your TV has an electronic tuner with a remote, try going into the setup menu and select signal source as CATV instead of antenna.
Please rate me.
Nov 20, 2009 | Televison & Video
Connection between harmon receiver and A-bus in wall speakers...
There is a CAT5/RJ45 A-Bus interface on the back of the HK AVR 435. That needs to connect to your A-BUS "hub". HK has two hub products: ABH-4000 and ABH-4 (older). Then CAT5 cable can be run from this hub to Wall-installed room-specific controls. HK has the AB-2 product, but any ABus compatible wall control will work. From the wall control, you wire regular audio cable to the speakers. So, some of the questions/issues to solve are: where do the existing wires go that are connected to the in-wall speakers? Typically that location is where to place your in-wall volume and source controls. Then the CAT5 gets wired from those controls back to the hub. And all that's required is a single CAT5 from the AVR to the Hub.
Apr 04, 2009 | Audio Players & Recorders
Gpx Under Cabinet TV
Have you tried to fine tune the channels? Other wise you need to set channels for cable and not air.
Jan 27, 2009 | GPX KL858S 8.1 in. Under Cabinet TV
42" Plasma Displays only Green Screen
dds426's reply:
The problem was not a cable connection. A chip needed to be replaced at the tune of over $600j (includes $200 for the repairmen coming to my home to dismantle and take to the shop and return it).
Jan 02, 2008 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Insignia NS-13CTV Logo
41 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
