Home | Sony | SDM-HS73P (Black, Silver) 17" LCD Monitor | Sony SDM-HS73 Not Sta...
Sony SDM-HS73P  17" LCD Monitor
Problem for Sony SDM-HS73P (Black, Silver) 17" LCD Monitor
Sony SDM-HS73 Not Staying On
By Tigers02 on Apr 30, 2007
I have a Sony SDM-HS73 17" flat panel LCD that is malfunctioning on me. I usually keep my computer on all the time and turn the monitor off at night. When I tried to turn it on this morning, the screen came up as usual but then went blank after about 10 sec. The green power light was still lit but there was no picture. I turned the power off and then turned the monitor back on and had the same thing happen. I saw my computer screen (perfectly fine in terms of size, brightness, etc.) for about 10-20 sec and then the screen went blank again.
Having some knowledge about computers, I tried the monitor with a different video card and on several different computers but still had the same result. I also called Sony, but since the LCD was out of warranty, then wanted a lot of money to send it in to get fixed. I wanted to see if someone knew how to fix this problem or if I should just ditch the monitor and get a new one. I think it is a power board issue, but I'm not sure. Any advice/suggestions would be most helpful. Thanks in advance.
Same Problem
Mar 19, 2009
-   I have the same problem. Just started today March 18th.
JT -   jtdigitalvid
Feb 12, 2009
-   Monitor is on and cycling power on the monitor, I can see the screen for about 5 seconds or less. I tried with another computer and same results so confirm that the monitor is at fault. This monitor isn't that old! My HP monitor on a different computer has lasted twice as long and is still going under similar use model. Sony just lost me!!!
I'll attempt the suggested capacitor replacement. -   plmdco
Jan 24, 2009
-   Same problem, switch on, screen comes on for an instant then goes off. -   greenmin
Jan 07, 2009
-   I have the same problem. Stays on for a sec, long enough to show the 4 color bar and then goes black. -   tallwall
Dec 31, 2007
-   I too have had the same problem. After more than four years of flawless service, it went on a blink today. Tested with other connectors, tested it on two computers, got the same results - thus the flaw is in the monitor, not the cables not the video card. Monitor turns on, green power light is on, can see the picture for about a second, then monitor goes blank (and black). About a week ago, for a few hours, it had made a few buzzy, sporadic noises that went away, but as soon as I heard that, I knew the days were numbered. Really loved this monitor and would hate to scrap it. I still think of it as new. Isn't there anything from Sony on this? If all of us are having this problem, it's seems like a single component going bad at the same time.-   Hubble
Best Solution
posted on Feb 20, 2008
Very Helpful)
grinder139
Rank: Apprentice
Rating: 100%, 6 votes
The problem is with power inverter, usually the capacitors go bad and need to changed, they might be bulged and or leaking. Very cheap fix, less than a buck apiece and an hour with a solder iron. Google it to find more info.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on May 14, 2007
Somewhat Helpful)
sweetanne
Rank: Apprentice
Rating: 80%, 9 votes
IT seems sony built a lemon with this monitor..
I have the same one (see my post) having similar problems.
sweetanne
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Feb 26, 2008
Very Helpful)
manytasks
Rank: Apprentice
Rating: 100%, 1 votes
Have a sony with the same issues, changed about 4 caps no such luck. Noted that the owner had the the brightness setting on high and the brightness control at 100%. Changed it to low light and brightness setting to 75. The monitor has of now been running for over half an hour. Will now resolder the transformers, do you guys think it is a bad or cheap transformer as there are no flyback transformers in these flat screens.
Was this helpful?
Yes
No
Solution #4
posted on Oct 12, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have same monitor same problem. Sometimes if i leave it on for about 2 hours it will show up and be working. Anyone have the real fix? Cap and transformers are an idea, buts whats really necessary to fix? Hate to scrap..Sony is starting to shy me away...
Popular Solutions for Sony SDM-HS73P 17" LCD
Questions and Unsolved Problems for Sony SDM-HS73P 17" LCD
Do you recommend Sony SDM-HS73P (Black, Silver) 17" LCD Monitor?
Answer
Answer
thin green like 3.5 inches long on the right side from the bottom
Answer
will not show display power button does not work(stays on) when connected to 110 display says -no... (More)
Answer
I have a Sony SDM-HS73 Monitor and the screen gets distorted and them will go crazy with lines and... (More)
Answer
plugged it into my laptop and did the same thing, so it is the monitor which is only 5 yrs old. Is... (More)
9 Other Users Have The Same Problem - Continued
Comment by mlamb751, posted on Dec 17, 2007
Same Darned issues..... on for 10 secs then goes blank..... any help out there??
Comment by Guest, posted on Dec 08, 2007
I'm having the same problem with my four year old monitor. While surfing the web, the monitor went black. I disconnected power, restarted computer, etc. Now, when I turn on the monitor, it stays on for a few seconds and then reverts to black. I can turn it on again and again, but the same thing happens. Any solutions?
Comment by Guest, posted on Dec 03, 2007
Same deal here! Everything was working great, now monitor won't stay powered up...never get anything other than the "no input signal" "go to power save screen. Disconnected...reconnected...rebooted. Light doesn't stay green for more than a few seconds and then it goes yellow. Saw the other post...don't know what they are referring to with regard to bulging electrical something or other? Anyone else?
Comment by Guest, posted on Nov 03, 2007
whenever i put my computer on the monitor just stays black. the monitor just doesnt show up. it stays black and wehn i put it on it just says 'no input power. go to power save' in a box. i checked the cables and everything. has it got anything to do with the back of teh monitor, the removable plastic board.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony SDM-HS73P 17" LCD...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 482
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
