Question about Olevia LT23HVX 23 in. LCD Television
My 42" olevia hdlcd will not power on. the green lcd is on howev
This tv was stored for about 10 months and now I am trying to connect it to satellite and it will not power on. The small green lcd light will come on or go off with the master reset button on the back, but the poweer button on the front does nothing.There's no sound, no snow, no nothing. Any ideas? thanks
  • 3 Answers
Main board problem olevia has that problem look up olevia parts go there you might be able to find a mainboard for it and from here on never buy olevia the support sucks and very high to buy from these tv s know some how warranty is up and go out they are very easy to work on
Posted on Feb 04, 2009
Olevia 42" tv no sound no power sometimes
Start with having the power supply capacitors checked, common problem on older Olevia sets!
Dec 01, 2012 | Olevia LT42HVi 42 in. LCD Television
I have an Olevia 42"
The issue you are having is your power supply
Thank you
www.orlandolcd.com
Dec 07, 2010 | Olevia LT42HVi 42 in. LCD Television
How do I program the tv to use without cable?
1.Power on the television and press the "Menu" button on the Olevia TV's remote control.
2 Choose the "Programming" option to view all of the Olevia setup options.
3 Choose the "Channel Program" option, then select either "Antenna" or "Cable" (select "Cable" when using a satellite receiver).
4 Select "Start" and the Oleiva TV scans over all the stations it receives. Once complete, is stores the information into its memory bank, so when you attempt to change the television station you only see programs that come in clear onto the TV.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 26, 2010 | Olevia LT42HVi 42 in. LCD Television
Picture rasterization
It sounds like the LCD controller board problem, usually if you cool it down the problem will go away, and comes back when it heats up again.
Nov 23, 2009 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Tv will not switch from box format to full screen or anything else..what's up?
If the TV is connected to a HD cable or Satellite box, they might be incorrectly set up not allowing for a wide screen picture.
Nov 11, 2009 | Olevia LT42HVi 42 in. LCD Television
Channel Scan
If you have not discarded your old conventional TV or can borrow one, I would connect it to the same signal source you are using with the Olevia. If you get reception with the substitute set, then the Olevia is defective. If you live in a metropolitan area, you could also try sticking a piece of copper wire into the input of the Olevia and selecting antenna input as the source from inside the Olevia's setup menu. If you still get no signal indications (quality is not important for this), then the Olevia is defective.
I'm disappointed to see you having trouble with this set as we own one too. Also disturbing is Olevia's current state; they are in bankruptcy so I would start complaining soon and loudly if you have satisfactorily   identified the Olevia as the problem.
Nov 24, 2008 | Olevia LT42HVi 42 in. LCD Television
Olevia 42" model # 542bl
Facing the back of television, if it occured while putting top right screw, that is because, you screw touched power module casing and the fuse inside the TV is gone. All you need to do is goto radio shack or any local store and get a replacement fuse (250v x 5 Amp) and replace it. It may cost you less than 2 bucks.
Symptoms:
TV powers off and never turns on.
May even power in that room or house may have been tripped.
Resolution:
lay the TV face down on the floor.
Remove the screwes ( may be 10 - 15 screws)
Remove rear casing of the TV. It is single casing covering entire rear face of the TV.
Fuse is visibe as soon as you remove the casing.
Replace the fuse.
Put the casing back.
Start enjoying the TV.
Prevention:
Do not use longer screwes to mount monitor brackets on TV casing.
GOOD LUCK!!!
Sep 17, 2008 | Olevia LT42HVi 42 in. LCD Television
Olevia 540
My tv is crap to. Green tint and washed out colors. Mine is 13 mos old. and the first one they sent had green tint to. They sent another one but now Im past warrantee! Ill never buy another tv or anything from them again!!!
Feb 09, 2008 | Olevia LT42HVi 42 in. LCD Television
Olevia Syntax 42 inch turns green through hdmi
I had this problem running my pc through my television through DVI to HDMI as well as a normal HDMI cable. Now, I'm not sure about the ps3 but my problem was stemmed from the digital color format settings. When set to component video color settings rather than RGB or HDMI the screen looks great with no issues. I believe this is an issue with the tv itself which is why I had to "trick" it into working. However, I don't own a ps3 so I don't know if it's possible to change settings like that. I know it's not much, but I hope it helps.
Dec 01, 2007 | Olevia LT42HVi 42 in. LCD Television
Televison & Video Logo
257 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
