Question about Curtis Lcdvd193a 19" 720p Hd Lcd Tv/dvd Combo Television atsc Tuner 199314
We have a TV DVD combo and the TV is working fine but the DVD player isn't reading discs anymore. It takes them in and sort of
    New Friend:
  • 74 Answers
May I would recommend buying an external DVD player.
Posted on Oct 05, 2012
SOURCE:
My old dvd player will not play some discs it says wrong disc what is the problem?
the reason why your old dvd player doesn't read the new dvd's is that might not compatible format or not the same region.
Nov 15, 2012 | Televison & Video
My Road view in the vehicle was working fine...2 day's ago..it's saying 'bad disc' the disc's are all clean and new..I unplug it.. and still saying the same thing.
see this causes and fix it. God bless you
If your mini DVD player reads "No Disc" after you've loaded the disc, it means the machine isn't reading the DVD. Take the DVD out again and clean it. It's quite possible that the disc is simply dirty and cleaning it will solve the problem immediately.
However if the problem persist test the following:
  1. Bad connections to one or more buttons or sets of buttons.
  2. Microcontroller failed to reset properly.
  3. Missing/bad voltages from power supply.
  4. Defective microcontroller or other logic.
go to the repair shop FOR fix it.
Oct 15, 2012 | Roadview Rd615 DVD Player
My VHS-to-DVD Burned Disc used to work and now it doesn't
Richard,
It could be your disc is scratched or DVD+R can't be read in the DVD player. Check for any scratches. Then pop in the disc in to your PC DVD, to see if it's readable.
May 31, 2012 | Daewoo DV-6T834 DVD Player/VCR
I have a Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo. But the DVD player shows some error. It said "playback feature may not be available on this disk" and it dosen't read the disk.
Try some other discs if you have not----If all show the same or similar error you have either a dirty or bad optical pickup in the player (it reads the discs).
Apr 25, 2012 | Philips Magnavox 20MC4304 20 in....
I have a Polaroid TV/DVD combo. It took the DVD in, won't play it nor will it eject now. How do I get the DVD back?
Tries the tv unplug/replug the tv back for about an hour later for the tv power to reset itself.At this time u will able to eject the DVD disc out.Don't tries to used the tv intergrated DVD player anymore.The tv intergrated DVD player laser head and the spin motor for the dvd disc spinner it is defective now.Buy a portable cheap or a moderate unit of a outer DVD player and hook up to the tv AV input.Play it through the tv input video 1,2,3 u should have a DVD player capatablities again.
Nov 30, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
I have an advent DV1418A and my built in dvd player wont work when i put a CLEAN WORKING disc in it says loading then it says "no disc" please help!
The READ head is dirty or damaged...very difficult to get to the back of TV to disassemble DVD player.. clean read (light diode) head with light cleaning fulid or don't take apart & use official cleaning DVD disc. Look on web site for CD\dvd cleaning disc.It looks like a CD but has 'fuzz' or a very thin " rug" on 'read' side of disc.
Aug 08, 2011 | Recoton Advent Advent DV1418A 14 in....
Just got an RCA TV from a friend. It is the 32 inch DVD combo. The DVD player isn't working. I can slide the DVD in and it will attempt to play it but it can't seem to read it. Does anyone know how to fix...
Now u put in a DVD movie disc into the DVD player slot.The DVD disc still register on the tv LCD screen,but just don't read the DVD disc?Yes.Tries websites like Amazon.com,Ebay.com to buy a DVD cleaning disc kit to used to clean the DVD laser eye of the DVD player slot,after this it should work.If tv still have the same result,than this tv problems DVD player slot can't be fix or worth fixing because the DVD player slot laser eye is bad or dead alredy.
Apr 24, 2011 | RCA L32HD32D 32 in. LCD HDTV
I have a Haier HLC19K1 19" tv/ DVD combo that
If you have tried more than one commercial DVD and are getting the same results then the problem is the player has failed. Actually what happens is the heads go out of alignment and it doesn't have the accuracy to read the tracks any more. This is a typical failure of dvd players in desktop and laptop computers and standalone players. While the heads can be aligned it isn;t worth doing. It was when a dvd or cd player was $1500 but not now.
Unfortunately the only cost effective fixes are replacing the dvd drive or replacing the entire unit. The replacement dvd would cost more than a new replacement tv/dvd combo. So you can buy a new tv or buy an external player ($40ish).
Feb 02, 2011 | Haier HLC19K1 19 in. LCD TV
Curtis Lcdvd193a 19" 720p Hd Lcd Tv/dvd Combo Television atsc Tuner 199314 Logo
429 people viewed this question
Top Curtis Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
