Question about Logitech 967437-0403 Keyboard
Logitech Wireless CE 0682 Keyboard won't work but mouse does
We brought computer to another location and tried to connect everything. Computer works, monitor works, wireless Logitech mouse w orks, but Logitech CE 0682 wireless keyboard (with brand new batteries) does not work. Any suggestions?
    Genius:
  • Logitech Master
  • 1,102 Answers
Did this come with software
and you might need to do a uninstall reinstall
if it worked on same pc before it should work now.
if you have a reset button on transmitter try resetting it.
Posted on Jan 20, 2009
I have a vio sony 64bit laptop and want to use my logitech CE 0682 BATTERY KEYBOARD.WHAT VERSION SOFTWARE DO I NEED TO to make this work
It is blue tooth and comes with its own USB dongle. All extra software, if required, is with the keyboard. Plug in the dongle that is in the mouse and put batteries in it. Of you go.
Dec 08, 2016 | Sony Computers & Internet
I have a logitech wireless mouse and keyboard (7 months old)- I recently moved my computer and when I hooked verythign back up it no longer works- I have tried everything from restarting, plugging the...
Underneath the mouse and the keyboard will be buttons labeled "Connect", you will need to resync with the receiver plugged into your computer. Press the connect button on each device in turn and it will attempt to resync.
If this does not work the next thing is to test with fresh batteries, however it is unlikely that both the keyboard and the mouse would run out at the same time.
Finally try with the receiver right next to the keyboard/mouse, sometimes other devices can interfere with wireless signals (WiFi networks, microwaves, vacuum cleaners etc...).
Feb 28, 2011 | Logitech Cordless EX 100 Mouse
The wireless keyboard and mouse are not working.
  • Check to ensure that the wireless receiver is plugged into your computer. Press the "Connect" button on the bottom of the receiver to attempt reconnecting your mouse and keyboard to the computer. If your mouse and keyboard use Bluetooth, ensure that your computer's Bluetooth is active and detects the mouse and keyboard.
  • Check to see if the keyboard and mouse are turned on. If the power indicator lights on the keyboard and mouse are not green, press the "Power" button to turn the keyboard and mouse on.
  • Check the batteries of the mouse and keyboard. If the batteries are dead, replace them with fresh batteries and reconnect the mouse and keyboard to the computer by pressing the "Connect" button on the bottom of the wireless receiver attached to the computer. If your mouse and keyboard use rechargeable batteries, let the batteries recharge before using the device again.
  • Uninstall and reinstall your wireless keyboard and mouse drivers. Sometimes, the Logitech drivers are at fault for a bad connection. Use the Control Panel to uninstall the old drivers, then visit the Logitech website and install the latest drivers for your keyboard and mouse.
  • Search the Logitech Support Database. If your keyboard and mouse are still failing to function properly, visit the Logitech Support website and browse the support page for your product for specific solutions.
Feb 04, 2011 | Logitech Computers & Internet
I can't get my wireless keyboard to work even after trying everything can think go or told by Windows XP. Anything else i could try? Lee
First try changing the batteries, reconnect the dongle or the connection device of your wireless keyboard and mouse, then restart your computer. If the step wont work reinstall the Bluetooth/Infrared software driver the wireless keyboard and mouse then restart the computer. If this fails still look under Ad/Remove programs if you have a Setpoint installed then remove it and restart computer, both or at least one of the devices should work. If one or both wont work then you need to contact the manufacturer and have the defective device/s be replaced. Just a heads up, they may ask you to reinstall your operating system / do a reformat of your computer so you need to back up your data ahead of time using a wired keyboard and mouse. Have a nice day ahead!
Aug 13, 2010 | Logitech Wireless Access Duo Optical...
CE0682 logitech mouse
"Normal" batteries are 1.5 Volts per "Cell" However Ni-Cads, rechargeables, each "Cell" is only 1.2 Volts. So the rechargeables simply may not work... If they do work, then there is NO reason why not.
Feb 14, 2010 | Logitech Wireless Access Duo Optical...
Keyboard has stopped working. have replaced batteries, tried to reconnect wireless channel and still nothing. I then rebooted and still nothing. Is is time to give up? Also, a side note the keyboard...
I have had the same problems on an XP configuration. You need to completely uninstall the Logitech drivers and first connect a wired keyboard.
Then reboot and follow the installation instructions for the Logitech keyboard/mouse combi. This probably means running the installer and then connecting the USB device.
It can actually take a few reboots before everything works, very annoying stuff.
Oct 20, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
My logitech wireless mouse works but the wireless keyboard does not. When I try connecting the keyboard the mouse stops working. I can get the mouse working but can't get the keyboard working. The only key...
The keyboard is not recognized by your PC. By the way, do you have the software installer for your keyboard.? Run the installer in your PC, and try again
if it now recognize the keyboard.
Sep 24, 2009 | Logitech Wireless Access Duo Optical...
Can't get cordless mouse and keyboard both working. Can only connect one or the other.
disconnect the small wireless dongle from the back of your computer..reboot the computer..put it back in,,and then press the connect button on bothe mouse and the keyboard to check,,the battery of teh mouse and the keyboard shud be checked if possible
May 08, 2009 | Logitech Wireless Access Duo Optical...
Wireless keyboard & mouse (S510) crashes my computer
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Dec 29, 2008 | Logitech Cordless Desktop MX 5000 Laser
Logitech keyboard quit working
hi,
almost every wireless keyboard / mouse has a connect button somewhere. its located on the bottom or on the side. what you need to do is to press and hold on the connect button to synch the device with the transmitter connected to the computer. if the transmitter on the computer has a connect button you might need to press them both at the same time. do the same if the wireless mouse stops working.
Oct 16, 2008 | Logitech Cordless Desktop MX 3000...
Logitech 967437-0403 Keyboard Logo
2,833 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
