Question about Refrigerators
Fridge too cold
Fruits and veggies freeze in fridge
problem exists top-to-bottom in fridge
temps set to warmest settings, both freezer and fridge
kitchenaid ksrp25fnss00
  • 334 Answers
The temp sensor or the thermostat is bad.
It is reccomended that the sensor be replaced whenever a T-stat is replaced.
You can purchace both for less than 50 bucks with most models at your local appliance parts warehouse.
(The T-stat is the part that you turn up or down to adjust temp and the sensor is the wire coming off of it to a remote location in the fridge. With some models it is all one part, with others the sensor can be removed seperatly.)
Posted on Dec 30, 2008
My gsh25jsxjss fridge is too cold. the electronic settings do not change the temp in the fridge.... even if I put it on the warmest setting... food is freezing in the fridge area
HELLO,
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, please do check that to confirm the deflector is okay or not....
Hope this will help in solving the problem......
Jan 12, 2011 | General Electric GSH25JSXSS Stainless...
My fruit and vegetable drawers keep freezing my fruits and vegetables. What could be causing this to occur?
Hello, Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.the air deflector....
As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control I hope this will help....
Oct 31, 2010 | Refrigerators
My Frost Free Fridge-Freezer has a problem. Upper portion, freeze all the fruits and vegetable, and lower portion not freezing any poultry meat etc. We have contacted a local dealer, and he need spare...
Check the cold control and the air deflector. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout .....
Aug 08, 2010 | Refrigerators
Bottom freezer model... the refrigeration veggie/fruit bins are freezing up?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jun 07, 2010 | Maytag Refrigerators
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
21' bottom freezer kenmore refrigerator-no ice maker-the fridge is super cold and freezes all my vegetables and fruit. We have cleaned the coils, cleaned the fridge, and it just keeps freezing. Fridge is...
Oct 02, 2009 | Kenmore 21.0 cu. ft. Bottom Freezer...
Why are my veggies freezing even thought the temp is set to 40?
Most fridges have crisper drawers that have a selection lever on either the front or side of the drawer that allows you to select eiher veggies or meat. Veggie setting is supposed to keep the crisper drawer warmer, while Meat setting makes it the coldest possible.
If you don't have the selector slide levers, I would suggest you use the highest possible crisper drawer available, as the lower in the frdge compartment you go, the colder the air will be. That should resolve the problem you're having, other than lowering the fridge temp setting slightly.
You might notice a cold air exchange vent next to your crisper, which supplies cold air from the freezer section into the fridge section, so that could be contributing to the colder temps in the crisper where you keep your veggies.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Jenn-Air JBL2088H 20 Cu. Ft. Cabinet-Depth...
Temperature too cold even when on lowest
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Refrigerators
My refrigerator freezes my food solid
There are vents that allow the cold air to flow from the freezer to the fridge. If those vents become clogged with ice or fail mechanically, they can become stuck open or closed. The temp adjustment should move the damper in the vents. But if they are frozen open, then the fridge will become too cold.
Thank you for contacting us.Please do rate fixya if you like the solution.
Dec 10, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
169 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
