Question about GE JVM1860 Microwave Oven
No power I have a GE JVM1860 microwave and have no power displaying.  I have checked both of the fuses and they checked fine.  Where can I go from here or where can I get a service manual for this.
  • GE Master
  • 9,098 Answers
If the fuse is good, you probably have an open TCO or a problem on the control panel.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There are four TCOs in this model. 3 have black views, and one has violet / blue wires connected. Ignore that last one.
It will read normally open, but the others should read normally closed.
To check the cavity TCO, you will need to pull the oven from the wall and remove the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Jan 01, 2009
G.E Microwave model JVM1860 Burning Smell
you must open inside see the diagram, and see 1) burn cable 2) fuse 3) diode 4) capacitor 5) magnetron 6) bulb etc.
God bless you
Nov 22, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Model JVM1860 burning smell
check 1) power cord for burn 2) wires 3) connector, 4) motor 5) switch, etc see the photo attached. and replace it.
God bless you
GE MICROWAVE JVM1860CD NO POWER
It is time to replace the microwave oven, it is 11 years old and prices in microwaves has dropped considerably. To repair the old! magnetron would need to be replaced, "most expensive part" and other unknown problems would need to be addressed.
Apr 24, 2012 | GE Microwave Ovens
Buzzing sound on all functions, including when light is turned on;fan vent not opening when fan turned on; not heating. is this a short/malfunction of control board?
sounds like a control/display board issue but if you microwave has a noise filter board (fuse is mounted on it) it could be that
Feb 04, 2010 | GE JVM1860 Microwave Oven
My GE microwave JVM1860 is dead, no power. I checked the electric outlet and the fuse/breake panel. Nothing.
One of the most common problems with Ewave microwaves is a loose blade on the cooling fan, causing the magnetron to overheat.
At this time looks like the magnetron, the magnetron TCO and the fan blade have to be replaced.
Aug 29, 2009 | GE Microwave Ovens
Microwave not heating food and is making loud noise.
You have burned out the magnatron (heating element) which is common on GE microwaves. most service companies will charge about 200-250 to replace it
Jan 31, 2009 | GE JVM1860 Microwave Oven
GE JVM1860WD001 microwave
CONTROL BOARD HAD FAILED your magntron is starting but the cooling fan for it is not , the control relays that control them enegerize at the same time . if not this is what happens . repair is very costly . ge has had probles with there microwaves for years , when you replace think about another brand . good luck
Jan 18, 2009 | GE JVM1650 1000 Watts Microwave Oven
The top vent broke
I called GE and got a new model since the JVM 1860 is discontinued.
Sep 13, 2008 | GE JVM1860 Microwave Oven
Microwave jvm1860
I had a repair man out to fix my microwave and all it took was to reset the unit. We shut off the power source ( at the breaker box ) and turned it back on. This had the effect of a reset. Now it works fine. Hope this helps.
Jan 09, 2007 | GE JES1851 Microwave Oven
GE JVM1860 Microwave Oven Logo
146 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
