Question about Zanussi 18 in. DCS12W Free-standing Dishwasher
Pump problems mine is the 14w. all that happens when i turn it on is the pump tries to drain the water, but there is no water to drain as the cycle has not started. all you can hear is the pump sucking water. no water comes into the washer either. somebody please save me.......
  • Anonymous Jan 07, 2009
    Soon as you turn it on the pump starts draining the machine and wont stop, no water comes into the machine either
  • kajeal Feb 15, 2009
    hey mate ive the same with mine ive had it 2 years from new.i took it apart last week.i took the pump off and had a look.i couldent see anything wrong i had a look all over the machine put it together and it was fine for a week until today.i think it could be a switch??the pump that drains the water just keeps running and it wont change cycle so i have turned it off by the mains.
I have an amana front load washer nfw7200tw10 I replaced the drain pump and still get ND error
I had the same problem, not sure it was your pump, load it with a bucket of hot water and some bleach, turn it on and let it run through a short cycle, the hot water and bleach can clean the sensor and the screen in the bottom going down to the pump, did water drain out when you took the lines loose, if it did its a good sign, most people dont realize you use only a quarter or less cup of soap in this washer, it will get the sensor water sensor dirty and the washer thinks it has water when it doesnt, the pump cant drain cause there is no water, . try the hot water trick, rmember use a bucket and as hot a water as you can, probably hair sudds and who know what is blocking the sensor, mine was hair, from my little girl, Matt
Jan 27, 2015 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Kenmore laundry center model 92702 burning smell during spin and water doesnt drain
mine does this regular easy job if your desent at diy are you missing socks or wires from bra's as it probably the pump blocked take the pipe of the pump and see if there is any thing stuck in the pump remove it as long as pump not damaged should be fine probably get some loose change as well lol
Aug 17, 2012 | Kenmore 92702
My Kenmore dishwasher does not fill with water when switch is turned on. What could be the problem?
First thing to distinguish is which motor are you hearing working is it the wash motor or is it the drain motor. Describing what you have above I would tend to think that it would be the drain motor that you are hearing on the drain pump itself. This happens for a couple reasons in a dishwasher. One your Float switch could be defective. Two you could have a leak condition in the unit and the drain pump is trying to pump out the water due to this issue. Three you could have a clogged drain line or exit port where your drainlines goes into your sink or in the drain line itself. Four would be a clog in the drain pump itself or the impellar of the pump is not turning. How much water do you have on the inside of the machine and is the machine draining if it is draining then I would look at the float switch first in the unit. I will await your reply as to your finds and if you have any further questions message me back
Thank you
Rick
Nov 19, 2011 | Dishwashers
Clothes still saturated with water after spin cycle
Check pump is not jammed or pump / drain filter is not blocked , if so clean /free and re-try , may not require any parts . refer to handbook for location of filter .
Nov 09, 2009 | Washing Machines
WHSB8000B not draining. goes into cycle and tried to drain. You can hear the pump running and a small amt of water drains but the drum is full. This problem happens when you get to the rinse cycle. Is the...
the pumps are cheap and don't even have a bearing. likely the pump has been jammed by a bit of clothing thread or something like that. If you remove the back panel you can try and turn it by hand (backwards first to unjam the stuff) it should turn freely but sometimes just a little convincing will do the trick. (you can take them apart and bring them back to life if you don't want to buy a new one)
Aug 16, 2009 | GE WHSB8000B Top Load Washer
Washer will not drain water out properly
you may need to take the pump apart as it may be clogged.
Apr 09, 2009 | Fisher and Paykel Fisher & Paykel Washer
Drum not filling up with water, it's draining straight out.
That means that the drain pump is always on.
That can happen because of a faulty or stuck water level switch (the one with floating sensor), because of a faulty drain pump solenoid, or because of a faulty pump.
Oct 24, 2008 | Washing Machines
Bosch dishwasher is stuck on drain cycle
cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
Oct 19, 2008 | Dishwashers
DISHWASHER IS LEAKING A LOT OF WATER
I had the same problem with my machine - ie lots of water coming out front about two thirds of the way through the cycle - engineer (local and very reliable) knew as soon as he came in that I had started bying Powerball 5 dishwasher tablets - they produce too much foam (try opening the door during the cycle and see the amount of foam) and it therefore comes out of the overflow parts on the door. I tried Magnum 5 and got the same problem. Now I stick to either Asda's own basic (not the 5) or I buy the Magnum ones and cut them in half. Has never leaked since!
Jun 11, 2006 | Hotpoint 24 in. FDW60 Free-standing...
Zanussi 18 in. DCS12W Free-standing Dishwasher Logo
44 people viewed this question
Top Zanussi Dishwashers Experts
Mike Cairns
Mike Cairns
Owen Barnes
paulcarew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
