Question about Sansui Televison & Video
TV isn't displaying pc image
I just recently bought a 19" flat lcd tv to hook my laptop into. I've tried several times to get the image to appear with no success. I've adjusted the laptop settings as instructed by the manual, but still no luck. Is there something I've missed in the book or in the settings? If you could please respond with any help I'd appreciate it. Thank you.
  • Sansui Master
  • 520 Answers
Double check your refresh rate. It must be set for 60hz for Sansui tv's.
Posted on Dec 31, 2008
Why is desktop green like theres way to much yellow hue
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 03, 2014 | Emerson LF320EM4 32" 720p 60Hz Class LED...
Standby light stays on and does not allow me to turn screen on
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | Sylvania LD195SSX 19 in. LCD TV
Screen keeps displaying "adjusting...."
- Flickering screen
- Dim screen
- Slow start
Apr 08, 2014 | Hannspree HANNS.G HU196D - LCD display -...
Desktop off of the screen
That might be the possible resolution the TV can recevie. Nothing more can be done.
May 20, 2013 | Sansui 19 in. LCD TV
Hook gateway intel n450 to flat screen television
You'll need a cable that will connect from the computer to the tv. The easiest way is if you get a cable that will have the same type of connection for both the tv and the laptop. Otherwise you will need to have an adapter that will go between the two.
Once you have them connected by a cable then turn the tv on and select the input (source) which in most cases will be PC or Computer or HDMI etc. Boot the laptop and the image should appear on the tv. If not you will have to Press and Hold the FN function key near the bottom left on the keyboard then hit the F1 thru F12 key that toggles the display. The correct F1 thru F12 key to hit will have LCD/CRT on it or it will have the icon of a display.
May 04, 2012 | Gateway Netbook N450
I just bought a 19 inch flat tv with the dvd player and pc input. I hooked it up to my computer with the vga cable and it says it doesn't recognize the format. what am I doing wrong?
Set the screen resolution, on the PC, to a low initial setting say 800x600 32bit, and also ensure your Video Out is set right either PAL or NTSC depending on what your TV receives. Make sure you have activated dual display "Extend windows desktop to here" under Video Properties, (Right Click Desktop)...and finally plug in to TV, turn on, and THEN boot up.
Feb 03, 2010 | Emerson LD195EM8 19 in. LCD TV
No picture
If model of your TV is LC19SB25U, TV powers up, TV has back light,but on picture or menu, The problem is the part called main unit.
Oct 14, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
I have a tv i want to hook up to my computer
I have the same emerson set.
I had the same problem the first time I hooked it up to the computer.
All I had to do was change my display settings.
To do this, click the start button, go to control panel.
In control panel, double click the display icon.
Click the settings tab.
Look for the screen resolution slider bar, and move it all the way to the left (CLICK APPLY)
NOW HOOK UP YOUR TV, AND IT SHOULD WORK FINE (YOU MAY NEED TO ADJUST THE SLIDER TO FIT YOUR SCREEN SIZE)
Good luck to you
Mar 15, 2009 | Emerson LD195EM8 19 in. LCD TV
LINES ON SCREEN
Have you unplugged the power for a few seconds and plugging it back in?
Maybe the people at this number might help. 317 581 6365.
May 26, 2008 | Proscan 19LA25Q 19 in. LCD Television
Televison & Video Logo
115 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
