Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE3 will not hold water leaks into the pedestal
My Kenmore HE3 leaks water immediately once operation starts. Water leaks into the pedestal and out onto the floor.
  • 91 Answers
Run you fingers into the door boot and inspect for holes ,, that probably what it is ,,,,,,big tear
Posted on Jan 04, 2009
Why does my Kenmore Elite HE3 fill with water when it's off
The water valves are leaking usually from grit in the seat of the valve. They are a pair and can be easily replaced.
Aug 03, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
Kenmore Elite HE3 front loading washer, model 110.45872400 - completely drains and runs correctly but sometimes an hour later there will be water in the tub
Your water inlet valve is leaking it needs to be replaced.You need to remove the top to access it.There are screws along the back edge holding it on.
Jul 24, 2010 | Kenmore Elite 45986 Front Load Washer
MAJOR leak in new JUST installed WCVH6800 front load washer
If you hear of a solution, let everyone know. Our machine did the same thing. From the research I have seen, GE makes **** machines and I will NEVER buy a GE product again.
Feb 07, 2010 | General Electric WCVH6800J Front Load...
How to remove drawer on pedestal
You need to remove the 2 screws holding the black rails on both sides of the drawer. Took us a while to figure this one out also.
Jan 01, 2010 | LG WM2487HWMA Front Load Stacked Washer /...
Water leaks into drum and machine intermittantly
The mixing value is leaking. I ordered a new one and will replace it.
Dec 20, 2009 | Kenmore Washing Machines
Whirlpool pedestal w/ Kenmore Elite HE3 washer
no - the base is a different size.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 19, 2009 | Kenmore 15.5 in. Pedestal
Water leaks from bottom.
This model is OLD , time to get a new one
May 22, 2009 | Kenmore 42822 Front Load Washer
Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore he3 series washer keeps filling with water when not in use
Remove the 3 screws at the back of the machine that hold the top on. pull back on the top and lift the top off. Remove the hose from the inlet valve and remove the screw that holds the inlet valve.
Aug 12, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
772 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
