Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
On my Philis 51PW9303/17F projection TV, the colors are weak. Adjusting the color and tint have no effect on the color intensity or hue. I was given this set and it was worked on. THANKS Mike
  • mikeborg Jan 26, 2009
    This very closely reflects the problem. It is a bettwr explanation then then the service manul offered.
Tv haz no picture but haz zound
Posted on Feb 23, 2010
  • Philips Master
  • 3,459 Answers
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Jan 26, 2009
  • Edward
    Edward May 07, 2009
    Your TV most likely has one or more possible problems.
    Problem #1: Convergence Chip Failure ( common problem )
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    Solution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
    Problem #2 CRT Fluid is Cloudy
    Picture of a set that needs the fluid changed.
    TV set after fluid change
    Solution #2
Tv screen is high in green color what settings do I need to be on
If your TV has a color temperature setting; it is probably on medium. Try it on warm. This will decrease the amount of green and increase the red.
Otherwise you will need access to the tint/hue controls; adjusting it more toward red will help.
Dec 21, 2014 | Televison & Video
Color and tint looks different. There is a green hue to the screen, and adjusting the tint and color does not help.
There is a problem with the connectors desoldering in the tv. My mother in laws tv did this after 2 months. Should be warranty issue if less than year old
May 10, 2010 | Insignia IS-LCDTV32 32 in. Television
Color section in tv receiver
can I know what is the answer for that question.
Feb 23, 2010 | SAMTRON 96B 19" CRT .22MM 1600X1200...
Picture is clear but with a yellow tint .
Make sure, if your using component cables ,that they match up color for color and are plugged in.If it looks good try adjusting your colors on the TV.You can also try unplugging the TV for 5 min. and then plug it back in.This might be a TV issue.
Jul 07, 2009 | Hitachi 53UWX10B 53" Rear Projection...
TV background in green and most of the people have green tint
http://www.breakitdownblog.com/class-action-lawsuit-against-sony-for-green-haze-or-green-blob-sxrd-problem/
Dec 17, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
Projection tv has a reddish tint on the screen and appears to look hazy and flushed. Flesh tones have a red/orange hue.
first try adjusting the color-tint on the menu if this does not solves the problem you have a failing proyector and has to be replaced
Apr 03, 2008 | Televison & Video
RCA 52" big screen tv
sounds like one of your tubes got weak, im thinking the red tube, needs to be adjusted manually
Dec 26, 2007 | RCA P52937 52" Rear Projection Television
Bad color on sony kv-36fs16
Possible bad CRT....check video out on C board,video drivers on
A board.........................T.
Dec 23, 2007 | Sony KV-36FS16 36" TV
JVC AV27320 Screen too dark
Check the lumans circuit. may be jungle IC
Nov 02, 2007 | Samsung HC-P4241W 42" Rear Projection...
Poor color issues.
try adjusting the convergence. good luck and happy valentine!
Feb 14, 2007 | Sony KP-53S65 53" Rear Projection...
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
434 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
