Question about HP Pavilion dv9000t Notebook
Screensaver won't activate
I have two Gateway GM 5048 PC's and the screensaver won't activate on either of them. Any ideas? Thanks.
How do i set my timer for my screensaver-when my laptop is idle?
The option is under Screen saver options or there is an idle time shut off selection under Power Saver options as well. When you select your screen saver there is are specific options to customize how it shows and how long before it activates. Some screen savers have more options than others.
Oct 29, 2010 | Computers & Internet
My laptop screen will go black. If I tap on the mouse or mousepad, it will come back on. Sometimes it stays on and sometimes on and off for awhile
I would check the Power features under "Display Properties", "Screensaver" tab, then monitor "Power" located at the bottom of the "Screensaver" tab. Check the settings located there and see if that helps.
Jan 02, 2010 | Gateway M320 XL Notebook
No screensaver will activate on my computer
To activate screen saver right clik on the desktop go for properties click on screensaver tabselect screen saver adjust the time to 5 and click on apply and ok button. so that ur screen saver is activated to the selected time.
Jul 07, 2009 | HP Pavilion dv9000t Notebook
No screensaver or power mangement
Hi there.
Right click on the desktop and select properties, then select the screen saver tab, you can set screen saver from there, select a screen saver and set the time you want it to activate.
Remember that the screen saver will not work unless you leave the computer to idle.
Good luck and thanks for using FixYa!!
Apr 03, 2009 | Dell Inspiron 530 PC Desktop
Screensaver works till i restart my PC then it
Pull out your memory cards and clean them with an eraser then replace them i had the same problem make sure macine is off..steve
Feb 27, 2009 | Gateway Computers & Internet
Hi, my screensaver acer aspire one doesn't work. can you help ?
To set up your screensaver, right click on your desktop and choose Properties. Choose the Screen Saver tab. In the drop down menu for Screen saver, make sure something is selected instead of (None). Next click the Preview and it will give you a glimpse of what the screensaver you chose will look like. Move the mouse to get out of it and select apply if you like that one or choose a different one.
Jan 14, 2009 | Acer Aspire One PC Notebook
Screensaver want work
Go to:
Start >> Control Panel >> Display >> Select the tab ...Screensaver
Modify the settings of your screensaver there and also (enable - disable)
Oct 27, 2008 | Gateway Computers & Internet
Error Tab
Turn off the, or better yet uninstall, the Acer Screensaver. Something you installed, possibly a screensaver program? has corrupted the Acer screensaver causing that error message. That add-on screensaver is notoriously buggy anyway.
James Smith
A+ NET+ Server+ M.C.S.E. CCNA
Sep 09, 2008 | Acer Aspireā„¢ T180 PC Desktop
Hi , on desktop right click click screen saver just follow on screen instruction.
Jun 11, 2008 | Microsoft Windows Vista Ultimate Edition
Screensaver will not activate...
I would remove the software for your keyboard. This will hand control of the screen saver back over to windows. Some keyboards come with third party software that conflicts with windows. If you want a functional set of "extra stuff" on your keyboard, then your best bet is to try one from another manufacturer.
Jun 16, 2007 | Logitech Cordless Laser Desktop MX 3000...
HP Pavilion dv9000t Notebook Logo
65 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
